BMW M3 Forum (E90 E92)
BPM
      07-05-2012, 09:43 AM   #1
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
Arrow DIY: Differential Fluid Change
I will make this plain and simple...
Things you need.
3 500ml OF DIFF FLUID +FM BOOSTER PART#83 22 2 282 583
14mm HEX socket
Small Torque wrench.
JACK and Jack Stand
towels
oil pan...
STEPS....
1. JACK THE CAR AND PUT THE JACK STAND.
2. UNBOLT THE TOP BOLT FIRST (FILL BOLT)
3. AFTER TAKING THE FILL BOLT OUT TAKE THE ONE BELOW. (SORRY NO PHOTOS OF THAT... BUT YOU CAN SEE ON THE 2ND PHOTO THE 2ND DRAIN BOLT. Make sure you have the oil pan cause it will drip even taking the fill in bolt out...
4. LET IT DRAIN, MAKE SURE ITS LEVEL AND WHEN IT STOPPED DRIPPING PUT THE DRAIN BOLT BACK IN
5. NOW ONCE YOU HAVE DONE STEP 4 YOU WILL NEED AT LEAST 2 1/2 OF DIFF FLUID. (THE ONE ON THE left)
6. THEN YOU HAVE TO SQUEEZE THE BOTTLE CAUSE ITS PRETTY THICK..(DO THIS YOU WILL ONLY NEED 2 1/2 BOTTLES. I HAD 1/2 OF 500ml LEFT...
7. AFTER YOU PUT 2 1/2 KEEP THE FILL IN BOLT OPEN AND LET THE EXCESS OIL DRIP...MAKE SURE TO LOWER THE CAR SLOWLY IF YOUR JACKING THE CAR ON THE RIGHT SIDE (PASSENGER)
8. ONCE IT STOP, SLOWLY JACK THE CAR UP AND PUT THE FILL IN BOLT.
9.. DONE... DRIVE IT AND DONT GUN IT... I SUGGEST TO DRIVE IT FOR AT LEAST 5-10 MILES AT LOW RPM...
Appreciate 6
      07-05-2012, 03:14 PM   #2
schnell325
Bored at work....
schnell325's Avatar
890
Drives: 2016 F82 M4 GTS//2022 M235iGC
Oh nice! Just what I was looking for!!
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      07-05-2012, 08:47 PM   #3
spdy330
spdy330's Avatar
Drives: 05 Tundra, 15 FIT, 17 CRV
Good job!
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
      07-07-2012, 11:41 AM   #4
mendez
20
Drives: 2008 e92 M3
Nice DIY!
How many miles you had in your car before changing the trans fluid?
      07-07-2012, 11:44 AM   #5
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
Originally Posted by mendez View Post
Nice DIY!
Last time the Diff Fluid was replaced when i had 30k miles. I now have 70k
      07-19-2012, 04:40 PM   #6
jjw2331
jjw2331's Avatar
54
Drives: 2011 JtBlk e92 M3
Thanks for the DIY Sean!
It made my diff oil change so easy and simple.
      07-20-2012, 07:47 PM   #7
edwinm3
edwinm3's Avatar
Drives: F82
What's the torque values for both of the plugs?
Grigio Telesto M4, 6MT.
Coyote 5.0 F-150
991 GT3
      07-22-2012, 12:06 AM   #8
mdosu
314
Drives: Double Vanos'd Civic-M3
does the bottle come with the nozzle?
      07-22-2012, 12:45 PM   #9
edwinm3
edwinm3's Avatar
Drives: F82
Each bottle comes with the nozzle/tube
Coyote 5.0 F-150
991 GT3
      07-22-2012, 01:19 PM   #10
mdosu
314
can you just remove the bottom drain bolt and drain all of it without removing the top?
      07-22-2012, 01:44 PM   #11
jjw2331
jjw2331's Avatar
54
I torqued the bolts to about 45lb/ft (approx. 60 Nm) per my service tech. However, he was saying that off the top of his head when he met with me without a direct reference. I don't have any leaks, and I'm pretty sure I didn't tear any threads. If you don't feel confident you might want to get a hold of the TIS manual to get the exact figures.
      07-22-2012, 01:48 PM   #12
jjw2331
jjw2331's Avatar
54
You can, but if you can't get the top bolt off, it will be extremely difficult to fill it back up. lol Besides, opening the top bolt helps it drain more efficiently. Similar to opening your oil filler cap when draining the oil.
      07-22-2012, 02:38 PM   #13
XR_SIX
Bading-dong!
XR_SIX's Avatar
Drives: '11.5 E93 M3 AW, '09 R6
2011.5 E93 M3  [0.00]
Nice write up! Galeng mo
      07-22-2012, 04:28 PM   #14
edwinm3
edwinm3's Avatar
Drives: F82
I just looked it up on my TIS copy and it is indeed 60nm. thanks
Coyote 5.0 F-150
991 GT3
a5m614.00
      07-22-2012, 09:18 PM   #15
mdosu
314
duh! got it. I plan to flip my car upside down to fill the fluid
      08-21-2012, 03:35 PM   #16
Dannys M3
Dannys M3's Avatar
Drives: Jaguar F Type R
2008 M3  [10.00]
Does anyone know what torx size that is? Largest I have is a T55 and it is too small.
      08-21-2012, 03:47 PM   #17
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
You only need the FM (aka Friction Modifier) booster if your diff is making grinding noises. All it does is make the noises go away. Otherwise you can use the regular LSD diff fluid which is a lot less expensive.
      08-21-2012, 06:00 PM   #18
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
mine never made noise but still opted out for the friction modifier which is a lot compare to the regular..
ALSO FYI if you guys are interested on 15 bucks a bottle contact MERC... they have it without the Friction Modifier for less than half a bottle compare to BMW...
Here you go...
      08-21-2012, 06:32 PM   #19
Z K
Z K's Avatar
1889
Yeah, BMW also has a non-FM boosted LSD diff fluid. Much cheaper than the FM booster version. Dunno the part # off the top of my head.
The FM-boosted version has more FM in it for people who complain about diff noises. Most of the time the noise is because people drive the cars too conservatively and don't break in the differential.
      08-21-2012, 07:11 PM   #20
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
Merc still sells it a lot cheaper... its about 10 bucks cheaper..
      08-21-2012, 09:26 PM   #21
Dannys M3
Dannys M3's Avatar
2008 M3  [10.00]
No takers on the torx size?
      08-21-2012, 09:39 PM   #22
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
Hey Danny what torq size are u talking about ...where are u planning on using them...
m3post
