      03-21-2016, 02:33 PM   #89
titium
Drives: 2009 BMW 135i
do you need to modify anything to get the m3 bar to fit? some people say you do some don't?
      03-21-2016, 03:52 PM   #90
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
The bracket that bolts to the bulkead has to be cut and rewelded at a different angle to match the angle of the bulkhead below the windshield of the 1-er. HPA sells their kit with the properly modded bracket.
(V-shaped bracket at the top of the photo.)
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
Dackelone10588.50
      03-24-2016, 10:11 PM   #91
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Ended up ordering the 1m package from ecs. It dropped another $7 to $215 shipped.
      04-16-2016, 03:19 AM   #92
titium
Installed this today.
For those worried about it throwing out your alignment (camber) if you do it with the car on the ground, the weight of the car holds your alignment in place. It's definitely a DIY job.
I did have one issue where even when the center bolt was torqued to spec the bars either side still had vertical movement an extra washer on the bolt fixed it. Not sure why this was an issue maybe these bolts are one time use?
      04-20-2016, 12:22 PM   #93
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
Wow no shit? That's cheap!!
      04-20-2016, 01:25 PM   #94
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
yeah, I agree. I test fitted the black ac cover thingy last night and it hits the studs on the strut tower rings on both sides. the studs are about 1 cm too tall. Going to grind them down with my angle grinder this weekend. Just a heads up for others considering this mod, that it is not 100% plug and play, at least for me. I could bolt the plastic cover down and it would probably work the way it is, but I like things to fit 100% so I will be grinding down the studs.
      04-23-2016, 10:32 AM   #95
chris82
chris82's Avatar
Drives: 128i
So when you removed the nuts on the botls, they didn't move at all when the car was on the ground?
      11-20-2018, 03:07 PM   #96
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I'm replacing my shocks and suspension with the M3 links. Seriously considering also doing this mod to my 135i(N54)... I just don't know IF I should go with a 1M version or with the M3 version of this strut brace.
The M3 has that one piece center "V" while the 1M uses two arms with an open "fork" and a bolt to secure the center sections. I'm leaning towards the M3 unit.
Any thoughts?
EDIT... I just priced out both braces online over here on Leebmann24.de... Schmiedmann.de was even more expensive!
M3 unit = 410 euros
1M unit = 194 euros
I think I will be going with the 1M brace.
Dackel
      11-20-2018, 03:18 PM   #97
John_01
John_01's Avatar
Australia
232
Drives: E90 325i, E82 135i
I suggest using the 1M strut bar because it is a direct fit on E82 cars without needing any modification of the plastic components. If you choose the M3 version there is work needed to create sufficient clearance to fit the alloy fork in the centre section.
The advantage of the M3 version is that its made entirely from alloy. The 1M version has alloy strut top yokes from the M3, but uses steel tubes similar to the basic E82 version. Weight difference will be very minimal IMO.
Dackelone10588.50
      11-20-2018, 03:19 PM   #98
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
I don’t think the M3 part fits. I believe hpa includes a modified piece with their m3 kit that allows it to fit with the 1er.
Dackelone10588.50
      11-20-2018, 03:47 PM   #99
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
houtan
John_01
^^Thanks guys. Seeing how the 1M is a direct bolt-on AND is half the price of the M3 unit... I think I will go with the 1M one.
Dack
houtan707.00
      03-14-2022, 10:02 AM   #100
ferocity02
Drives: 2013 135is
We're you able to get the cowl to fit? I have the same issue, the bolts are too tall and hit the cowl.
      03-14-2022, 10:36 AM   #101
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
I removed the studs and replaced them with M8 bolts.
houtan707.00
      03-14-2022, 11:45 AM   #102
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
I used my angle grinder and shaved down the studs. When I have the nut installed, the stud is flush with the top of the nut.
@suprgnat, nice solution!
      03-14-2022, 09:02 PM   #103
ferocity02
Drives: 2013 135is
Are the studs removable?
Edit: the studs on mine are welded on. I'm contemplating drilling them out and tapping the holes. There isn't much room for nuts underneath on the right side.
      03-26-2022, 04:14 PM   #104
ferocity02
Drives: 2013 135is
Nevermind! The studs are indeed threaded in. Super easy to back them out with a pair of vice grip pliers. I chased the threads with a tap after removing the studs. Then I replaced them with 25mm long low profile socket head cap screws from McMaster. They are still very close to the cowl, so I put a piece of foam tape on the cowl to absorb any noise if they hit. I also tried ultra low profile screws but the hex cannot take 25 ft-lbs before it rounds out.
https://www.mcmaster.com/nav/enter.a...tnum=97050A141
Suprgnat2317.00
      03-28-2022, 06:07 PM   #105
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Sorry I missed this. Glad you got it sorted.
      10-04-2022, 08:31 AM   #106
Carficionado
Drives: BMW 135i
Angry Ridiculous
$78 just for the 6 countersunk nuts. F***ing ridiculous. I got a used M3 strut brace kit, thinking I was gonna save some money, but didnt come with the damn nuts. Now I gotta buy the 2 1M strut bars and these overpriced nuts....Maybe I can recoup some money by reselling the M3 brace arms and center piece.
      01-24-2023, 05:13 PM   #107
Moc05
Drives: BMW 135i, Alfa Stelvio QV
I know this is an old thread but are there any issues with running something like the Cusco Front Strut Tower brace with this?
      02-19-2023, 01:20 PM   #108
Grimm5698
Grimm5698's Avatar
33
Drives: e82 135i / e36 M3
2009 BMW e82  [0.00]
I just did this mod, went with the 1M set up and M3 cowl, now I can access the coilovers for camber/damper adjustments easily 😎
      03-09-2023, 10:21 PM   #109
Grimm5698
Grimm5698's Avatar
33
2009 BMW e82  [0.00]
What parts did you use for this modification to add a cross brace in between the stock braces? Looks like it ties in the whole thing together pretty well
      03-10-2023, 03:34 PM   #110
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
I welded some stuff up to the stock M3 aluminum braces.
houtan707.00
