      05-16-2023, 08:02 PM   #111
BigZ88
Cap'n Winky
BigZ88's Avatar
23
Drives: e90 330i
So, if I want to pull the pins and add camber (this brace is already on my car) I’ll need to remove the rings on the tops of the struts completely? Also, is there adjustment built into the bar to allow the camber adjustment?
      05-16-2023, 09:58 PM   #112
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
Yes.
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
      05-18-2023, 03:01 PM   #113
BigZ88
Cap'n Winky
BigZ88's Avatar
23
Drives: e90 330i
Sweet!
      05-21-2023, 12:46 PM   #114
n54pete
n54pete's Avatar
Drives: e82
Actually just a quick note, yes the bars allow for some adjustment for camber, but you will be limited in the amount of camber you can run because the holes aren't that much bigger than the threads so adjustment is minimal, and the rings mount over the old brace mounting point with minimal clearance.
For reference I have -3.5 deg, and in order to make the 1M brace work, I had to slot the holes on the bars, and grind down the old brace mounting point to get the 1M rings to fit over them.
Easy access to rebound adjustment tho is priceless, well... $350 from bmwpartstore lol
Tesla M3P - Because Daily
E82#2 - Because Racecar
RIP: S550/F82/R35/F30/E82/E46/S197
      05-21-2023, 12:56 PM   #115
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
n54pete , are you on stock or m3 arms? Reason why I ask is I am at 3.8 degrees camber and did none of that. Just bolt up the brace and adjust my camber plate to max. But I am also running m3 arms.
Is that a carbon wrap on the bar?
      05-21-2023, 07:10 PM   #116
n54pete
n54pete's Avatar
Drives: e82
Update: I'm an idiot, looking at it again, its cuz the previous owner slotted the strut tower holes to get the camber he wanted, but not sure why, as it has camber plates so he could have done the same as you and adjusted the camber plates to max to do the same, o well, its done now.
and yes wrap on the bar cuz rice life lol
houtan707.00
      05-22-2023, 12:57 PM   #117
wu2x
wu2x's Avatar
36
Drives: 2011 E90 M3 6MT
Yes, you only need to adjust your camber plates to get that amount of camber. Hopefully not too much damage was done to your strut tower.
