EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3 / M4 Photos and Videos
      03-15-2024, 12:28 AM   #1211
NCTaxman
Jeeper turned Bimmer
NCTaxman's Avatar
21
Drives: BMW M4 Cabrio F83
Replaced the stock paddle shifters with longer aluminum paddle shifters from Kies Motorsports. Build quality is excellent but the additional length doesn’t do much because the stock plastic mounts that attach to the steering wheel are somewhat flimsy. When you try to tap the shifter near the top of the paddle, the shifter twists and doesn’t make contact with the spring mechanism. You really need to shift by pressing the center of the paddle, but it’s still nicer and looks great.
____________________________
2017 BMW M4 Convertible F83 DCT
Mineral White Metallic Exterior
Black Merino Leather Interior
      03-16-2024, 12:59 PM   #1212
noemon
46
Drives: BMW M5
Replaced rear coilovers with stock so I can send all 4 Tractive coilovers for a maintenance service.
Also tried to replace rear pads but failed on the right side as the pins are totally shot, ordered new pins.
And gave the wheel arches a good scrub & a wash. Lots of tyre on them.
      03-16-2024, 10:06 PM   #1213
Drifter2090
Drifter2090's Avatar
910
Drives: E90 M3 | E92 335i | E90 335d
Remeber having a nightmare of a time with the pins on my old c63 front caliper. Ended up having to cut and drill it out.
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD
JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD
SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD
AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD
noemon46.00
      03-16-2024, 10:09 PM   #1214
Drifter2090
910
Installed my new vrsf single mid pipe, now it's paired to my mpe and vrsf catless downpipes. Sounds awesome! It was definitely nerve racking cutting my mpe midpipe though.
Cars still in winter mode too, hopefully only a couple more weeks!
Appreciate 4
heymarkv108.50
noemon46.00
M_Torx328.00
Boznien73.50
      03-18-2024, 12:39 AM   #1215
Rockshaker
Rockshaker's Avatar
Drives: 2018 M3, MG 318i 1997
Originally Posted by Dan_Q View Post
Rears are 19x11 ET44 with 305/30
Fronts are 19x9.5 ET22 with 275/30
I figured when I was walking around the McLaren/Aston/Lambo dealer last weekend and didn't see a single car with tires that were wider than 305, that was a good indication it might be wide enough!
Looks nice! Are you at stock height?
      03-19-2024, 10:55 AM   #1216
Dan_Q
Dan_Q's Avatar
117
Drives: F80 M3, F15 X5 50i
2018 M3  [9.50]
2015 X5 xDrive50i  [10.00]
Yes, stock at the moment. Debating if I want to go with an M Performance HAS kit or a KW DDC kit. One of those will be installed by the time the snow melts and I get it back on the road for summer.
      03-19-2024, 11:04 AM   #1217
noemon
46
Drives: BMW M5
I thought it was going to be a nightmare so called my mate instead who took them out in a few minutes. He didn't use a drill, he basically used a tiny chisel, light tapping and lots of wd40, he was using the "chisel" very gently to basically get the wd40 all around the pins and with minimal power but lots of quick movement he managed to get them out flawleslly. He'd done it before on the same calipers.
Guy is insane, he is the only 22 year old lad that I actualy hang out with. I'm 40 this year.
He is the electrician in our business but a huge car enthusiast.
He is now building a very unique E34 with an F80 engine on his own.
Crisis averted.
It seems the pins had been shot for a while and that is why that side was squealing. I changed the brake pads because of that noise but when I took them off they were worn but still had a few months of life in them. The seized pin also destroyed the lamination on the disc so changed both discs in the end as well.
Note to self: next time you hear brake squeal it might just be the pins instead of the pads.
      03-21-2024, 11:15 AM   #1218
Drifter2090
910
Should you not be running 275/35 up front? Tires look pretty small
      03-21-2024, 02:21 PM   #1219
HotRodM4
HotRodM4's Avatar
Drives: 2018 M4
  [10.00]
Failed NY state inspection today due to emissions. I had flashed back to stock from my bootmod3 tune yesterday but I didn’t drive enough miles.
?18 M4 Comp
      03-21-2024, 04:58 PM   #1220
M_Torx
M_Torx's Avatar
328
Drives: M
lucky here don't have any emissions at all it's nice just safety car and put on insurance couldn't imagine dealing with that BS
TTP
HotRodM4687.00
      03-21-2024, 09:24 PM   #1221
6ixSpd
Save the manuals!
6ixSpd's Avatar
6016
Drives: '16 M3, '23 718 Spyder
Hunted down a set of dual staggered 763M!
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
Appreciate 4
HotRodM4687.00
M_Torx328.00
      03-21-2024, 11:08 PM   #1222
Thekidhodges
215
Drives: 2018 Bmw M3
Added KW V3 coilovers
KW rear adjustable control arms
Ground Control Camber Plates
HRE 520 Wheels
Appreciate 10
6ixSpd6015.50
Boznien73.50
Andi-M2192.50
Solo_G69.00
W///7494.00
Frözpeed144.50
M_Torx328.00
      03-25-2024, 08:16 AM   #1223
Drifter2090
910
Had to swap back to the stock oil filter cap as the BMS was making contact with the charge coolant hoses after the huge CSF went in.
M_Torx328.00
      03-25-2024, 05:20 PM   #1224
louielouie
Drives: '18 F80
The MAF sensor placement on the Burger intake would drive me nuts. You couldn't feed it through another way?
      03-25-2024, 05:46 PM   #1225
Drifter2090
910
Haha yeah it looks pretty dumb, maybe if I tied it down to something but then I'd have to cut the tie everytime.
Doesn't bother me anymore so I've just left it
      03-26-2024, 02:45 PM   #1226
HotRodM4
HotRodM4's Avatar
Drives: 2018 M4
  [10.00]
Got the AliExpress exhaust tips to match the Chitanium exhaust 😅
?18 M4 Comp
M_Torx328.00
      03-30-2024, 10:20 PM   #1227
boogiePls
Drives: BMW M4
No more gross rusty wheel hubs.
M_Torx328.00
      03-31-2024, 12:43 PM   #1228
HotRodM4
HotRodM4's Avatar
Drives: 2018 M4
  [10.00]
Did a bunch of driving recently to get my emissions monitors ready. I should pass my NY state inspection now, right? 😬
?18 M4 Comp
m3rxn978.00
      04-02-2024, 01:29 PM   #1229
TanzM4
TanzM4's Avatar
Drives: BMW M4
Added yellow DRLs and carbon fiber splitters
Boznien73.50
M_Torx328.00
      04-03-2024, 04:44 PM   #1230
shapiros
shapiros's Avatar
19
Drives: 2013 E92 M3 ZCP 6MT
Gave her a bath. Now need to swap my wheels to get my summers back on
2018 F80 M3 ZCP 6MT
2014 E63 S AMG Wagon
2013 E92 M3 ZCP 6MT (gone but not forgotten)
M_Torx328.00
      04-04-2024, 01:43 AM   #1231
Eighty8M
26
Drives: E90 M3
Finally got to test fit my LM's, went back to OEM triple 6's until i get my rear arms in then the LM will be dialed in
Appreciate 5
Boznien73.50
heymarkv108.50
M_Torx328.00
      04-04-2024, 09:16 AM   #1232
Boznien
Boznien's Avatar
Drives: 2018 BMW M3 ZCP (Avus Blue)
2018 BMW M3  [9.50]
2018 BMW M3 ZCP - Avus Blue - DCT
2014 BMW 328i xDrive - Black Sapphire - FBO Stage 2+ (SOLD)
1995 BMW M3 - Alpine White - 5MT
Instagram: @boznien
M_Torx328.00
f80post
