01-18-2014, 06:10 PM | #111 |
European Editor
10628
Rep 22,992
Parts guy is wrong. NA model spark plugs last 100K. N54 or N55 plugs should be changed at 45K miles. And if your car has a tune change them every 30K like BMW says to on the 1M's.
I would say only use BMW bought plugs. There are cheaper sources around. I would hit up Jason@Ticher or Dan@United. Both can beat that $26 price. And don't forget to order a spark plug socket tool - since its a odd ball size plug(12mm, 12point edges). PS: to be sure of your ECL I would first read your car's fault memory. Also if your car is still under warranty BMW will pay to replace your spark plugs.
01-18-2014, 11:04 PM | #112 |
59
Rep 232
So I took one spark plug out. Here are the pics:
Not that great looking, but not too terrible either. BTW, there was a fair amount of black residue after taking the spark plug out: I would like to vacuum it out but I don't have such a narrow vacuum hose. For now I just put the old spark plugs back, but you convinced me that it's probably better to replace them. Will order OEM BMW parts online. |
01-25-2014, 07:02 PM | #114 |
59
Rep 232
AARGHHH....
I ordered new OEM spark plugs online. Replaced the spark plugs and.... misfires!
So put the old spark plugs back. Same misfires! What happened? Damaged coil packs maybe? Are they so delicate? I have re-seated them a couple of times....still no good. SES light comes on right away and and engine feels unbalanced. Can I drive the car to a shop? |
01-25-2014, 07:14 PM | #115 | |
European Editor
10628
Rep 22,992
01-25-2014, 07:15 PM | #116 | |
European Editor
10628
Rep 22,992
THIS is a GREAT TIP!!
01-25-2014, 07:48 PM | #117 |
59
Rep 232
Update
I was able to read fault codes:
P0206: Injector Circuit/Open - Cylinder 6 As far as the connectors etc.: Yes, everything is seated properly. There's not much to do--push down coil pack, press-in connector. It's all pretty snug. At least this narrows it down to one cylinder. Suggestions? |
01-25-2014, 08:43 PM | #118 | |
European Editor
10628
Rep 22,992
I would also make sure you did not bump/touch the #6 injector connector.
01-26-2014, 12:14 PM | #119 |
59
Rep 232
Update 2
I swapped coil packs between cyl. 6 and 1, and I get the same fault code.
So I think there's a problem with the injector in cyl. 6. At this point I am going to give up and bring the car to a mechanic. I still do not understand how replacing a spark plug can damage the injector. I did not pull any wires and I was very careful while doing the job. All the wiring looks OK from outside. |
03-22-2014, 04:50 PM | #121 |
Rep 522
I'm going to tackle this tomorrow. Is there a consensus on dielectric grease? If you're changing plugs every 30K miles then maybe there's not a need?
03-22-2014, 05:54 PM | #122 | |
European Editor
10628
Rep 22,992
Some guys have posted here on 1Addicts that they used a little bit of ANTI-SEIZE on the spark plug threads. Its up to you, but I did not use anything when I did my plugs.
03-22-2014, 06:23 PM | #123 |
Rep 522
Since I'm in a fairly dry climate, and I'm driving about 6K miles/year (so 5+ years between plug changes), I may try it to keep the coil pack from sticking to the plug. I think you're right about the anti-sieze, not much to worry about there.
03-29-2014, 11:53 AM | #124 |
Rep 1,623
Drives: Alpine White 128i Cabrio
Why, on realOEM, there are a bunch of different part numbers for the spark plugs on the 128i. Is it a continent difference, year difference, model difference?
Which one do I use for the 128i N52? If I were to go to the dealer to buy the plugs, would they give me the correct plugs?! Lmfao that sounds like kind of a stupid question, but sometimes shit happens.
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
03-30-2014, 03:11 PM | #125 | |
European Editor
10628
Rep 22,992
03-30-2014, 06:46 PM | #126 | |
Rep 1,623
It's part number 12122158253. Is that the same for the N54? Thanks, -PJ
03-31-2014, 06:42 AM | #127 |
European Editor
10628
Rep 22,992
No. The N54 uses different spark plugs. And the N55 plugs are different that N54 spark plugs too. N51 and N52 plugs are different too(I believe). This is why its important to look up things via your VIN. Sometimes ther can be model changes with in a model year... so using your VIN is the way to go.
04-18-2014, 06:15 PM | #130 |
European Editor
10628
Rep 22,992
Realoem.com is your friend... N54 = BOSCH ZGR6STE2 bmw p/n 12120037244 http://realoem.com/bmw/showparts.do?...17&hg=12&fg=05 N55 = BOSCH ZR5TPP33S bmw p/n 12120037582 http://realoem.com/bmw/showparts.do?...17&hg=12&fg=05
05-26-2014, 06:15 PM | #131 |
Ex '87 Carrera
248
Rep 1,259
Hey Folks,
Just finished this up without any real issues, not a terribly difficult job. Unfortunately I still seem to get a bit of rough idle and some small pops after a cold start, although it's not throwing any codes... One thing I did notice which I didn't read any other reports of here however, was oil down on the plug holes. At first, when I only found it on cylinder 2 and 3 (not sure of the firing order, but just counting straight back with#1 at the front), I wondered if it could just be spillage from the oil filer cap. There was some oil around the plug cavities, but not nearly as much as in the cavities themselves. I did find some in#6 though, which is nowhere near the fill cap, which got me started thinking about the failure mode of the coil packs themselves. Old conventional Bosch coils were filled with oil, for cooling I guess. Every once in awhile you find one leading oil down onto the coil wire and causing problems. Could the coil packs be oil filled as well, and leaking down onto the plugs, causing misfire issues? BTW, the Burger Motorsports socket worked great and was reasonably priced. As usual, thanks for the great post Dack, you made it easy! ianc |
05-26-2014, 08:04 PM | #132 |
Rep 522
