03-26-2024, 04:17 PM | #23695 |
90
Rep 124
Do you have a link to them? I can only find 380mm fronts when I search. Looking to go with OEM sizing for the time being.
03-26-2024, 10:26 PM | #23696 |
Rep 1,612
9
reidetailing602.00 roastbeef11586.00 jmeenach89.50 CTMike262.00 e92BMW///M3123.00 Bimmer Barney1250.00 1FastSicilian481.00 omgzirra_exe1489.50 PACarGuy683.50 |
03-26-2024, 10:31 PM | #23697 |
Alex - IG @screamer
602
Rep 473
Instagram: @screamer
- 2013 Subaru STi Hatch - White - Racecar - 2011 BMW E92 M3 - Moonstone - Collector Car - 2008 BMW E90 M3 - Silverstone - Racecar |
03-26-2024, 10:33 PM | #23698 | |
Alex - IG @screamer
602
Rep 473
StripclubDJ omgzirra_exe okusa turbo_joe Cmassey3
03-27-2024, 05:24 AM | #23699 |
65
Rep 68
See this thread.
https://www.bimmerpost.com/forums/sh...php?p=28008378 I’m in the middle of this now. Removed charcoal cannister, secondary air pump, associated hoses and EGR valves and plugged the holes on the back of the engine with the plates from NRW Design. Just received hoses yesterday and a discriminator valve to build a new tank vent routing. I have an Epic tune to code out the CEL. One unresolved question for me is what to do with the hose that runs from the charcoal cannister to the idle control valve on top of the engine (beneath the wiring harness). Do I plug it? That’s what I’ve done and car seems to run fine, but I’m only able to test drive it up and down my driveway. |
reidetailing602.00 |
03-27-2024, 06:52 AM | #23700 |
Rep 1,588
I removed the entire evap system from the rear of my car. I didnt mess with anything under the hood though.
2012 E92 M3
Instagram Turbo__Joe |
03-27-2024, 07:15 AM | #23701 | |
Rep 492
Drives: M4 GTS
03-27-2024, 08:16 AM | #23702 |
Rep 1,588
Its just a DIY build, nothing special. What would you like to know?
Old setup had the exhaust going through it, just kind of figuring it out as I go. The diffuser took some damage from racing so I had to rebuild my rear mounts. Decided at the same time to change it up some, lower it and bring the exhaust out above the diffuser. The entire diffuser is 6' long and goes a good bit past the rear diff. I also run a diff cooler since I am not getting any airflow to the diff now Old Untitled by Joey Hutchinson, on Flickr New setup, you can see how much shorter the strakes are so I can reduce the angle of the diffuser. Untitled by Joey Hutchinson, on Flickr This was before finishing things up but this is the front half under the car before I added 1" strakes to this piece (which have no been mostly ground down flat lol) Untitled by Joey Hutchinson, on Flickr
2012 E92 M3
atopa2002202.50 Bimmer Barney1250.00 |
03-27-2024, 09:12 AM | #23703 |
Rep 492
Drives: M4 GTS
This is a great DIY right up. Thanks for sharing the detail. I’m going to tackle a diffuser sometime this summer and am just gathering details on how to do so
turbo_joe1615.50 |
03-27-2024, 10:16 AM | #23704 | |
Derbo Tuning
3610
Rep 3,022
Like omgzirra_exe said, there is paragon rear rotors. I run their front rotors with AP 9660 calipers with no issues so far. I have friends who also replaced their AP Racing J hooks with replacement rings from them without any major issues that I know of. I'm currently running stock rear caliper/rotor with pad swaps. I haven't seen a need to replace the rotors with upgraded ones but I definitely would be exploring the Paragon rears in the future when the time comes.
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
jmeenach89.50 |
03-29-2024, 03:13 PM | #23705 |
Rep 1,502
Hi All - Does anyone have measurements from their 3DM Ohlins Track Day kit? I'm trying to baseline my settings because I've narrowed down the clunk noise to the Driver's Side front coilover. I can't use the Ohlins R&T manual settings because the Track Day kit has a shorter swift spring. I've called Ohlins and they say "Call 3DM" but after about a month of follow ups and calls, no response from Barry. Argh...
2011.5 E90 M3 DCT ZCP Slicktop
03-29-2024, 04:11 PM | #23706 | |
1491
Rep 2,021
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
03-29-2024, 05:10 PM | #23707 |
Rep 1,502
I asked Barry “What are the measurements from top of spring mount to camber plate and measurement from bottom of spring mount lock ring to top of shock length lock ring.” Basically spring and shock measurements like they’re referenced in the Ohlins manual. I wanted to know how Barry sets them up and ships them out.
Put differently, how much preload on the swift spring and what’s the shock length measurement.
03-29-2024, 10:08 PM | #23708 | |
Rep 5,548
03-29-2024, 11:38 PM | #23709 |
Rep 1,502
It’s the 3DM track day kit. No helper springs. I need to measure the Ohlins R&T springs versus the swift springs.
03-30-2024, 11:21 AM | #23710 | |
Derbo Tuning
3610
Rep 3,022
My wifes Ohlins RT had an issue where they updated the internal piston and the tolerance was just large enough to cause clunking noises over slow bumps. Ultimately they had to rebuild the front dampers to resolve that. Not sure if it is related to this but certainly a possibility.
IG:ruhrohz_m3
04-01-2024, 01:19 PM | #23711 |
90
Rep 124
For everyone that has been giving me insight to my current alignment issue:
I waited to realign the car until my new tire/wheel combo arrived. With changing to a square setup, I wanted to avoid potential need to setting the car up twice. The shop I go to for alignment told me the instability problems I'm experiencing are likely due to the rake on the car. After the springs settled, the front sat substantially lower than the rear. The front of the car was raised 3/8", with the rear being dropped minimally (I think he said around 1/16"). I'll be testing the car out this weekend at Spring Mountain, so I'll have to wait a few weeks until I can do the true test at WSIR. New alignment specs: -3.25 w/ 0 toe F, -2.7 w/ 1/8" toe-in R. Below is a (crappy) pic from when I picked the car up Saturday in the rain. |
tsk941522.00 reidetailing602.00 |
04-08-2024, 09:14 PM | #23712 |
Rep 1,612
13
roastbeef11586.00 Bimmer Barney1250.00 mikerunt306.00 rhyary1563.00 turbo_joe1615.50 donald22.50 omgzirra_exe1489.50 jmeenach89.50 RalliartRsX12.00 reidetailing602.00 1FastSicilian481.00 Cmassey3416.50 JobanM73.50 |
04-09-2024, 09:11 PM | #23714 |
Alex - IG @screamer
602
Rep 473
04-10-2024, 12:24 PM | #23715 |
1491
Rep 2,021
So I installed a GT4 spoiler (because I had it, and because I wanted to balance out the GT4 lip). I made custom reinforcement plates by just aping Burkhart's design (would've bought theirs but they were on backorder and it's literally just a rectangular plate with 2 holes in it) and having sendcutsend make it.
Problem is that it's behaving like I thought it would. Terribly. I can move the spoiler front to back byt an inch or two without much effort, and when you shut the trunk it vibrates like a cheap antenna. I know the GT4 spoilers don't really have that much downforce but I'm still not loving the idea of it being that loose. Anyone have better ideas? Otherwise I might try to fab up a brace that ties in the fenders or something.
04-10-2024, 02:48 PM | #23716 |
Rep 1,588
Ready for race weekend at Summit Point
Gonna be more of a shakedown weekend working on tuning the new suspension. [IMG]Untitled by Joey Hutchinson, on Flickr[/IMG] Untitled by Joey Hutchinson, on Flickr Also finally got around to modding the driver door to be able to remove it to load it in the trailer. Untitled by Joey Hutchinson, on Flickr Made an easy mount on the wall with some e-track and J hooks to hold the door during transport by Joey Hutchinson, on Flickr
2012 E92 M3
