04-20-2013, 08:59 PM | #1 |
Rep 121
Leaking power steering fluid.
Just wondering what most of you guys have done/ replaced to fix the leaking (power steering) fluid when tracking your M3. Thanks guys
04-20-2013, 09:22 PM | #2 |
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
Sweat band zip tied around the cap.
04-20-2013, 09:24 PM | #3 | |
Rep 1,144
If it's leaking from somewhere else, that not a good sign. I recently replaces a PS rack...ug. |
04-20-2013, 09:25 PM | #4 |
Grown Azz Man
429
Rep 3,021
Or a old sweat sock.......Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
04-20-2013, 10:16 PM | #6 |
248
Rep 2,271
Yup, what the others said.
2011.75 E90 AW | DCT | ZCP | ZCV | ZCW | ZP2 | Prem Sound | Moonroof | BMW Apps |
Mods List: Evolve Exhaust | M Perf Steering Wheel | Tint | Lux | Hardwired V1 | KW V3 | Volshlag CP | Brembo BBK | BBS FI | Yokohama AD08 R| Schroth 4 Point Harness | Challenge GT Diffuser | OEM GTS Wing| GTS Lip| I lied earlier, I wasn't done with mod, but I swear, I'm done now, no more mods... |
04-21-2013, 02:27 PM | #9 |
Rep 1,470
a BMW GT4 power steering cooler.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
04-21-2013, 03:24 PM | #10 |
Rep 206
04-22-2013, 03:15 PM | #13 | |
Havin' a blast!
125
Rep 4,847
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
04-22-2013, 04:36 PM | #15 |
8211
Rep 18,823
Drives: BMW
All current production BMWs are using the new reservoir (sans M3). The new unit has a slightly improved venting system.
Here's a shot of the revised version on my M3, which sees regular track use.
04-22-2013, 04:45 PM | #16 |
IG: limited.slip
332
Rep 1,918
04-22-2013, 05:13 PM | #17 |
IG: limited.slip
332
Rep 1,918
I have it narrowed down to a BMW motorcycle rear brake fluid reservoir. Hose/fitting is just a vaccum line. Maybe battery vent tube will work too.
Found it, from the F650GS. Has the mounting ear too. Part number 34217706055 Vaccum line: 11727545323 (1meter) Straight or 90 degree connector/fitting : from local auto parts store Last edited by kaiv; 04-22-2013 at 05:48 PM.. |
04-22-2013, 06:13 PM | #20 | |
Havin' a blast!
125
Rep 4,847
04-23-2013, 11:24 AM | #21 | |
8211
Rep 18,823
Drives: BMW
A hose adapter will be needed for the bottom outlet, as its a bit larger than the M3's.
04-23-2013, 04:00 PM | #22 | |
Rep 206
I've used zip tie for the installation. I'll take a photo tomorrow. |
