02-26-2021, 05:50 PM | #45 |
Rep 37
Watched that today, Matt's car is gorgeous
Agreed Last edited by wbM3; 02-26-2021 at 05:57 PM.. |
02-26-2021, 09:08 PM | #46 |
2367
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
I'll corner weigh my E92 6MT ('07 with lightweight OEM flywheels) with stock 19" Fuchs wheels when I have time. I believe official data suggests 3527.40 lbs, mine should be a tad lighter as I have a bucket seat on the LHS.
Pass me if you can.
02-26-2021, 09:25 PM | #47 |
Emperor
1614
Rep 2,753
Idk what your setup is, but a bucket seat is one of the most significant weight reductions you can make. That was a huge portion of getting my e46 coupe under 3100 lbs.
02-27-2021, 06:52 AM | #48 |
Rep 3,337
Having owned my E39 M5 for 15 years along with many years together with the E90 M3, the two car are substantially different...enough so that I wouldn't put them in the same category really. Even with all the mods I had done to the M5 (Dinan springs, Konis, monoballs, Dinan rear swaybar, Ground Control camber plates, 9.5/275s up front), it was still a pig and much more suited to highway travel versus even when the M3 was totally stock.
I've written extensive comparisons, detailed, after autocross and track sessions, before, so no need to rehash all that. The M5 is much quieter, much softer riding (even with all the mods it was still like a living room sofa compared to the stock E90 M3) and a *lot* heavier (i.e. E90 6MT slicktop versus my M5 = well over 300lbs difference). In any event, many have found they do not view the E90 M3 as a replacement for the use they employed the E39 M5 for at all and were disappointed with the M3. I would *much* rather take a cross-country trip in the M5 than my M3 for example, much. However, by a factor of a hundred, I'd much rather drive the M3 spirited, on track, on course than the M5 any day. As an aside, the front suspension on the E90 M3 vs the E39 M5 is hugely different, from the design of the overall arrangement (i.e. tension arm arrangement on the E90 versus the compression arm on the M5) to the rack and pinon in the M3 versus the push from behind the wheel centerline recirculating ball setup in the M5. The E39 V8 steering design is truly a carryover type arrangement dating all the way back to my first BMW, the E3. The camber profile under compression is much more favorable in the E90 versus the E39 also. Are they both strut suspensions, yes like almost every car these days, but that's where the similarity ends really. In fact that rear pointing compression arm bushing in the M5 is a source of problems as it's fluid filled and fails rather quickly -- replacing that with the monoball really helps although that does increase NVH, especially with the GC camber plates not insulating NVH as well. Many use an inverted placed X5 bushing there.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 Last edited by CSBM5; 02-27-2021 at 07:04 AM.. |
SYT_Shadow11494.50 |
02-27-2021, 07:14 AM | #49 |
Emperor
1614
Rep 2,753
To be clear, my point was that the e90 M3 driving experience is more similar to the e39 M5 than the e46 M3 driving experience– not that it’s the same.
02-27-2021, 12:04 PM | #50 |
Driver
2692
Rep 2,714
Both the E9X and E46 feel soft as hell on track in near stock config. I can't imagine the E39 M5 feeling close to the E9X, but if that's your experience I won't argue.
E90M 6MT Slicktop Single Humper in need of a diet
02-27-2021, 12:44 PM | #51 |
Rep 3,337
It doesn't...the M5 is much softer than the E90 M3, sloppy, has a lot of push on turn in, feels lethargic and very heavy compared to the M3. Seriously, back to back drive them on track as they are really much further apart in just about every aspect. Brakes? The M5 is way undersized in brake department and the E39 is known for very squishy brakes with poor feedback and too much travel. I replaced my stock ones with Stoptech BBK, and that helped a lot, especially at VIR where the Stoptech BBK with PFC01 pads was incredible. Prior to that I had melted a brake piston seal using the stock M5 brakes with HT10 race pads at VIR (two long very high speed straights on full course there). By comparison the stock M3 brakes are much better with a firm, solid pedal with excellent feedback. The driving experience of the S62 versus the S65 is very different also...they're both V8s (5L and 4L), but vastly different powerbands.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
Bartledoo2691.50 SYT_Shadow11494.50 |
02-27-2021, 03:15 PM | #52 |
Emperor
1614
Rep 2,753
The M5 is certainly another step towards the luxury side.
But, at the end of the day, stock the e9x M3 is the heaviest generation of M3, the most sound deadened generation of M3, and the softest riding generation of M3. The e46, stock, is the harshest riding generation of M3, had the smallest weight gain over the previous gen (pre turbo, but those aren’t real M3s), and conveys the most mechanical noises into the cabin. This is why I think they’re suited to different priority sets. |
02-27-2021, 06:42 PM | #53 | |
Rep 512
02-27-2021, 06:56 PM | #54 |
Rep 3,337
Without a doubt and a monster increase over the F80...almost E39 M5 heavy.
As an aside, the single biggest weight decrease item between the E90 and F80, btw, was the Li battery which saved 31lbs over the E90 normal battery which it well should given its MSRP is $1900. If you substitute an Li battery into the E90 using something like the Antigravity design, that saves even more at 40lbs lighter...just a PSA on weight of F80 vs E90.
Current Stable:
02-27-2021, 07:20 PM | #55 | |
134
Rep 117
I really don’t buy the different in “rawness” you’re painting between the e46 and e9x - I’ve driven so many e46, many e9x and a spectrum of e36 versions, and the arguments you are making are more applicable to an e36 than e46 when it comes to rawness. The “rawness” stuff that always comes up with the e46 is merely a reflection of the eras they were built. An e46 doesn’t feel that much lighter then an e9x in practise, but has away less chassis rigidity and creature comforts. A great car? No question. But it’s not a miata or a race car - it’s still a daily driveable sedan/coupe. |
02-27-2021, 07:38 PM | #57 |
Rep 512
You can tell how stiff the e46 is by looking at all the welding that needs to be done on the subframe to keep it from ripping out of the car.
02-27-2021, 07:55 PM | #58 |
134
Rep 117
02-27-2021, 08:18 PM | #60 |
Driver
2692
Rep 2,714
Just throw in 95A trans mounts and boom raw AF.
leftfootbr8king569.50 |
02-28-2021, 05:03 AM | #61 | |
Rep 3,337
As to the rear subframe mounting points ripping out on an E46, one would assume the designers clearly underestimated the factor of safety needed for that area of the structure (since they obviously underestimated the amplitude of the cyclic stresses experienced). It's clearly not the best design by a wide margin, but it does come from earlier days still in CAD/FEM (i.e. early 1990s design work). I'm sure if they could do it over again, they'd easily fix that area plus the front strut top mounting area along with many other improvements. How cool would that be if BMW did a run of E46 body-in-white shells with greater than 100% improvements in torsional and bending rigidity along with fixing all the poor design locations plus using modern E9x era and forward ulta-high strength steels?
Current Stable:
SYT_Shadow11494.50 Headhunter.M3197.50 |
02-28-2021, 07:02 AM | #62 | |
Emperor
1614
Rep 2,753
E36 m3: 10,500 nm/deg E46 m3: 18,500 nm/deg E90: 22,500 nm/deg F80: 40,000 nm/deg E39 was ahead of its time. E39: 24,000 nm/deg |
TractionControlDelete4594.50 |
02-28-2021, 07:04 AM | #63 |
Rep 3,337
I don't have the E90 M3 specific data, but it also has additional stiffening compared to the base E90 number quoted. In any event, BMW themselves outlined in their white paper the substantial improvements made in the body structure of the E90 not only in terms of torsional (which is what you've quoted) and also bending rigidity, but significantly in crash safety and occupant protection/reduction in g-loads/etc. That continued progress simply marched onward. I have the actual paper PDF file on my server, so I can hunt for it as it directly compares the E90 to the E46 in heads up manner.
Current Stable:
02-28-2021, 08:01 AM | #64 | |
Emperor
1614
Rep 2,753
That said, it's not really relevant to what people get something different from the e46 to the e90. It's probably similar to why you have an M2-- it drives smaller, which just makes it a more fun, more involving experience.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
03-09-2021, 04:35 PM | #65 |
2367
Rep 2,362
AFAIK E92 M3 has 33,000Nm/deg of torsional rigidity.
Pass me if you can.
03-10-2021, 02:21 AM | #66 | |
Rep 1,408
I rate the car on how it feels when driven at the limit, the e46 at the limit is slower and more forgiving making it a softer car. While the e92 is faster and less forgiving, which makes it a more "hardcore" car to drive faster. Clunking usually comes from age - they both clunk S54 is a nice engine, but the way the S65 feels and sounds above 7k rpm can only be matched by supercars. If you think the e90 is a successor to the e39, you probably should drive them again. We are all entitled to our opinions, I personally think they both have their own unique feel, but to call the e92 "soft" is really funny to me. The damn thing grunts, loses traction and nearly tries killing me every time I drive it hard in the cold (DCT violence). Whereas the e46 has always been much friendlier. |
