E90 Aftermarket Suspension Guide (aftermarket options list)
11-25-2013, 07:47 AM | #177 |
Rep 3
Drives: 2007 328xi E92
Hey guys…..I have a 2007 328xi coupe and I need to replace all struts and shocks
which is the best and cheapest set I can get pLz help me anyone. |
11-26-2013, 02:34 PM | #178 |
628
Rep 2,808
Does anyone have any info on the Cobb sway bars that came out recently? MSRP is $530. They are hollow.
http://www.cobbtuning.com/BMW-135-33...t-p/9b1250.htm Their site says it has a: 28mm Front Bar 15mm Rear Bar Where do you get this front/rear bias info from? . . And there's the adjustable RD Sport hollow bars, MSRP $425: http://www.pyspeed.com/ProductDetail...e=RDSPORT-8102 30.2 mm front bar 25.5 mm rear bar See below for its settings. . . Last edited by Lotus99; 11-26-2013 at 03:13 PM.. |
04-12-2014, 08:00 PM | #179 |
Rep 3,051
Drives: 2009 BMW 335d
04-14-2014, 12:08 PM | #180 |
628
Rep 2,808
LOL, why don't you now delete your post, since whoever's post you are talking about is now gone. It looks like you're talking about me!
04-14-2014, 06:37 PM | #182 |
Rep 3,051
02-27-2015, 03:36 PM | #185 |
In search of MT parts
Rep 14
Drives: '11 335d
B12 kit
As I found out the B12 kit is now a special order item and it will be 12 weeks from when you order it to when it ships out. If someone is telling you otherwise they have not talked to their rep recently or if you are really lucky they have it in stock...good luck with that btw spent a week trying to find 46-180650 B12 kit for 328xi.
06-22-2015, 06:12 AM | #187 | |
Rep 4
08-13-2015, 01:38 AM | #188 |
Das it.
69
Rep 358
Hey guys,
I have an E93 325i sitting on 20" wheels (20x10 at rear, 20x8.5 or 9 at front) and wouldn't mind dropping the car a bit. Not looking for stance - I mainly want to close the gap between the wheel & the arches. I also want to keep the ride comfortable - don't want to feel every pot hole/bump. Which sort of springs would be best? Have no idea with this technical info lol.
F82 M4. |
08-29-2015, 07:45 PM | #189 | |
Rep 57
08-31-2015, 03:03 AM | #190 |
36
Rep 306
I have a 330i sedan, with performance suspension, however, the height is great, I m trying to find more stiff struts and shocks, comfort is not what I m looing for.
which ones would be recommended. (I m keeping the springs)
M.Etreby
F M double Grills, 19"313, Perf.Exhaust with dimisatips, RPI red scoops, K&N filter, LUX-H8 160, Aluminum strut bar, PBX, Perf. Suspension, F30 M-Perf. Brakes |
04-15-2016, 12:38 AM | #191 |
Rep 24
So I have an e90 325i, and would like to lower the car a tiny bit. Nothing crazy. I was looking at the 335i Springs, noticed there are different spring codes. Which one should I be looking for? Just want to close the gap a little bit with my 18s that I have on the car.
stefstef1.00 |
05-12-2016, 12:21 AM | #192 |
Rep 12
Drives: BMW 2009 328xi sedan
BC Coilovers would be the best street ride in NYC
05-18-2016, 12:50 AM | #193 |
67
Rep 231
What are part numbers for the OE Stock Sport Suspension springs which lower the car by just over half an inch? I can't seem to find these on RealOEM at all.
08-09-2016, 01:29 PM | #194 |
Rep 49
Does anybody know if Eibach pro kit part # 2092.140 (for E92 335i) will fit an E90 328i xDrive? Has anybody tried? If so, what is the drop like?
Not sure if there is really any difference between 2092.140 and 2085.140 (2085.140 is for E90 328i, which also fits xDrive). Thanks. Nevermind, sort of found the answer (and doesn't really apply to me anymore): http://www.e90post.com/forums/showthread.php?t=1006536 Last edited by cul8erppl; 08-09-2016 at 02:30 PM.. |
08-12-2017, 01:37 AM | #196 |
50
19
Rep 230
05-06-2018, 04:36 PM | #198 |
Rep 1
Basic suspension info request
Hi, I'm new to this forum and unsure how to post an undoubtedly basic question on suspension so I'm hoping someone on this thread can help. I have an '07 E90 318i SE. N/S rear suspension spring was cracked. I sourced replacement used springs from a vehicle of similar age. Was advised by seller they were compatible. Only when changing broken spring did I realise the existing one was stamped "C2" and the replacement was "C1". Although it fits fine and subsequently passed the MOT can I assume there's a slight difference in the coil diameter as I didn't have any means to accurately measure? My question is; Should I swap the other spring for the "C1" and would it alter the handling if I didn't? (I've driven it for a couple of days and there's no noticeable difference). Grateful for any advice. Cheers.
