ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > BMW Z4 Photos, Photoshops, Videos and other Media
  TireRack
      03-17-2014, 06:56 PM   #67
avsbmw
Drives: 07 Z4MC
Originally Posted by David@ApexRaceParts
Your M coupe looks great avsbmw. Was your car wrapped or repainted?
Dipped
      03-22-2014, 05:14 AM   #68
Beedub
423
Drives: 2007 Z4 M roadster vt2-500
Originally Posted by intoflatlines View Post
I imagine 275/35/18x10 ET25 would be just fine on stock suspension, as David suggested then. Thanks!
edit/update, the 265/40 section rear is too close to comfort on "normal" driving, i managed to see a very slight scuff on the plastic fender liner, I'm since put my semi slicks on in 265/35 and even under full compression their is no contact, if your running the Et22 out back id definitely stick with a 35 section, FWIW my ad08 265 is basically 278mm in width and their is room so on a Street tyre a 275 should fit nicely.....
just giving a small update :-)
as you were
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      03-22-2014, 03:39 PM   #69
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
Thanks for the info. I ended up going with 18x9 ET42 and 18x10 ET25 with 245/40 and 275/35... no rubbing on the highway over bumps and dips, or at full lock in parking lots. The last test if autocross but that won't be for another month and a half.
Dirty car/cell phone pics... I will get some proper photos when it warms up.
Apex ARC-8 Hyper Black, BFGoodrich Rival
Front: 18x9 ET42, 245/40/18
Rear: 18x10 ET25, 275/35/18
      03-23-2014, 11:09 AM   #70
Beedub
423
the 10" 25 offset looks like it pokes slightly not to keen on that look tbh, great choice on tyres btw....
      03-23-2014, 11:43 AM   #71
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
To be on the safe side, you can always try the full compression test by jacking up one of the front corner to see if there's anything touching on the opposite rear. That 10" et25 does look pretty perfect, especially with those meaty tires
      03-24-2014, 02:42 PM   #72
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
Awesome, thanks for the feedback Beedub and great photos intoflatlines.
      04-07-2014, 01:07 PM   #73
intoflatlines
Washed and waxed the car yesterday, and took out my DSLR to get some slightly better pics than what I posted previously.
ARC-8 Hyper Black w/ BFGoodrich Rival
245/40/18x9 ET42
275/35/18x10 ET25
      04-07-2014, 04:08 PM   #74
Expert@ApexWheels
3530
Drives: M3
Great looking Z4M Roadster, intoflatlines, thank you for sharing. Hyper Black looks really good on your Silver Grey Z4MR. How are the BF Goodrich Rivals?
      04-07-2014, 04:41 PM   #75
intoflatlines
Thanks David. The Rivals are good so far, but have only driven a couple hundred miles on them. I am anxiously looking forward to the first autocross event of the season. They do seem pretty durable though, along with the ARC-8 wheels. I hit two nasty potholes which I thought would definitely bust a tire or bend a wheel (from past experience). But thankfully the tires and wheels held up brilliantly!
      04-10-2014, 03:09 PM   #76
cogriff
cogriff's Avatar
69
Drives: 2006 Z4MC
2014 Audi  [0.00]
2006 BMW Z4MC  [9.00]
1977 Honda CB750K  [0.00]
2007 Kawasaki ZX6-R  [0.00]
wheels Apex EC-7 in Satin Black
18x8.5 et35
18x9.5 et43
tires
Hancook Ventus V12
235/40R18
265/35R18
suspension is stock for now.
      04-10-2014, 04:39 PM   #77
Expert@ApexWheels
3530
Drives: M3
Great looking Z, cogriff. Thank you for sharing your specifications with us!
Awesome, that is great to hear. Thank you for the feedback!
      04-11-2014, 02:36 AM   #78
Beedub
423
18x8.5 et35
18x9.5 et43
tires
Hancook Ventus V12
235/40R18
265/35R18
Attachment 1009079
Attachment 1009080
Attachment 1009081
Attachment 1009082
Attachment 1009083
this needs a drop BADLY......
      04-11-2014, 08:01 AM   #79
cogriff
cogriff's Avatar
69
Drives: 2006 Z4MC
2014 Audi  [0.00]
Agreed! H&R coiloevers are shipping out on april 17th. along with other goodies
      04-12-2014, 06:28 AM   #80
Beedub
423
this will look very cool lowered!! post up pics asap!
      04-23-2014, 01:27 AM   #81
donoman
Rookie
33
Drives: 03 Z4 2.5i 5MT
Originally Posted by i2ichal2dZ4M View Post
18x9.5 +35 squared
Hello,
Are you running spacers and/or camber plates? I want a square setup to be able to rotate tires for longer life!
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      03-21-2015, 08:08 PM   #82
schobyb
schobyb's Avatar
15
Drives: 06 Z4M Roadster; 2012 Cayenne
2006 BMW Z4MR  [0.00]
Apex ARC-8 Hyper Black on Titanium Silver, Michelin Pilot Super Sport
Rear: 18x9.5 ET25, 255/40/18
Stock suspension.
The rear tires have less than 1000 miles on them, when they wear, I plan to replace with 265 or 275.
The front is a very tight fit, only 5 or 6 millimeter clearance from tire to strut. I believe there is a slight rub, but only occurring at full-lock turn.
      05-18-2015, 07:45 PM   #83
Sliktop
31
Drives: 07 Z4 M Coupe
I just swapped wheels from the M3 to the Z4. Rides fine, no rubbing at all with stock suspension.
Apex ARC-8 18x9.5 et35 Square
Hankook R-S3 265/35/18 Square
Apex 5mm Front Spacer
Apex 12mm Rear Spacer
Apex 75mm M12 Wheel Studs
I plan to stack a couple sets identical to this so I can run them on both vehicles at the track or autocross. If I can scrounge the $$$, I'll do the widest staggered EC-7 setup that I can fit as my street setup on the Z4.
      05-19-2015, 08:44 AM   #84
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
Here are a couple shots of my very dirty car at Circuit of the Americas in March
Anthracite APEX EC-7 - 18x8.5" ET35, 18x9.5" ET22
245/40/18, 275/35/18
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      05-19-2015, 06:50 PM   #85
Expert@ApexWheels
3530
Drives: M3
Amazing Z's, thanks for sharing!
      05-19-2015, 07:44 PM   #86
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Do you have stock suspension? Any rubbing with this setup? Thanks.
      05-19-2015, 08:52 PM   #87
TexasZed4MC
stock suspension and no rubbing anywhere. My plans are to get to either a 265/35/18 square setup or better yet a 275/35/18 square setup
      05-20-2015, 12:41 PM   #88
GomboRombo
Roadie B4 Roady
GomboRombo's Avatar
Drives: Z4 M Roadster
Very nice. Is that on stock suspension or is there a drop?
Remus, ZHP, Stubby, H&R Coilovers
zpost
