      02-27-2017, 01:45 PM   #67
fe1rx
Drives: 135i, 328i, Cayman S
As many have found out, at about -2° rear camber and you will run out of toe-in adjustment with the OE toe arms. (At -2.1° rear camber my toe adjustment was maxed out to give zero rear toe.) I made my arms OE length so still had this issue with version 1. I have now made a version 2 that is 3 mm longer to give me some more toe adjustment at my desired rear camber setting. I was able to extract the ball joints and reuse them but the the swaged material had to be machined away rendering the version 1 parts scrap.
Name:  Revised Toe Arm.JPG
AndyW669.00
ppointer743.00
      02-27-2017, 03:45 PM   #68
WhatsADSM
Drives: 2011 135i
Attachment 1580862
Thanks for all of the info!
You really should do us a favor and make those arms for consumption by the public
Its too bad the rear guide rod is the one to replace and not the upper camber arm (as the guide rods are notably more expensive). The upper arms are actually pretty cheap (about $40 a piece) anyways. I may replace them "just because" they would be newer bushings and should provide some (partial) un-sprung weight savings.
Maybe I missed it but do you have an data on the overall weight of these various pieces?
      02-27-2017, 07:43 PM   #69
fe1rx
Guide Arm 135i - 970 g, M3 - 785 g
Upper Arm 135i - 1115 g, M3 - 840 g
Toe Arm 135i - 1000 g
Camber Arm 135i - 3000 g
Trailing Arm - 515 g
WhatsADSM227.50
lab_rat394.50
      03-05-2017, 10:14 AM   #70
titium
Drives: 2009 BMW 135i
@fe1rx thanks for all the info.
question what do you think the effect of installing the guide rods the wrong way would be. I recently realised the shop I got them installed at put the ball jointed end on the hub... can't trust anyone
      03-05-2017, 02:12 PM   #71
fe1rx
That definitely won't work well. The rear uprights have concave conical seats at the attach locations and the corresponding end of the rear guide rod and wishbone have convex conical mating ends (per the centre image below). Turned around, things simply won't fit correctly.
      03-05-2017, 02:52 PM   #72
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Are you sure? I don't even even see how that is possible! Lol. Man, they should be ashamed to be in business. I would try and get a refund. Keep in mind, those bolts are one time use and if they did t replace them, they would be reused for a third time if you do t replace when you fix them.
      03-05-2017, 03:05 PM   #73
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
Attachment 1580862
The $64K question is this: When can I buy a set of fe1rx toe arms?
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
      03-05-2017, 03:21 PM   #74
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
+1.
      03-05-2017, 03:35 PM   #75
ShocknAwe
1Addict
ShocknAwe's Avatar
3233
Drives: E82 Mutt, M57 Truck
Making do with a set of velocity motorsports rear toe arms for now. It really did help things. I'd love to have a set of well built arms though. Not that the velocity arms aren't doing well, I just question how long they will last.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      03-05-2017, 07:52 PM   #76
titium
Sure looks like it. Will be taking a proper look under the car tonight.
EDIT:
Confirmed they are installed the wrong way around.
vtl1493.00
      03-27-2017, 12:55 AM   #77
vtl
vtl's Avatar
Australia
1493
Drives: 2008 BMW 135i MT
I ended up making my own ball jointed toe arms:
http://www.1addicts.com/forums/showp...&postcount=128
I figure the best idea is to just use oem parts so looked at whether it would be possible to fit a ball joint into the factory toe arms. The stock factory rear upper link has a ball joint and is available separately for repairing an arm.
I found that while the ball joint is not avilable as a part number from BMW, it is available as a joint from Meyle or in my case FEBEST BMAB-044Z:
http://www.ebay.com.au/itm/172556729...%3AMEBIDX%3AIT
Theres an error with the listing saying it is compatible with the toe arm bushings. This is wrong and it is actually the bushing for the upper control arm.
The width of the bushing is identical to the toe arm but the diameter is slightly larger. If I remember correctly it was around 45.50mm. The diamter of the toe arm bushing is approximately 44mm, but needed to be slightly oversize to press in snugly. As I have a lathe, machining off a mm is not a big deal and can be done pretty easily. These bushings will not work unless theyre machined down.
I tried using combinations of threaded rod to press the machined bushings in but did not have luck. The threaded rod tools would not reliably press the joint in squarely and usually resulted in the joint not going in straight. I managed to get one joint in but couldnt get the 2nd joint into the arm to complete it. The project sat on the shelf for several months and I almost forgot about it.
Recently I just got a shop press, as I found I really needed one for a lot of small jobs. Made it really easy to press in the joints, I really should have made them more oversize and relied on the brute force of the press to get them in. I did around a 44.15mm sizing but shouldve gone 44.30. This would have resulted in a much tighter fit. A couple of them were a little loose. So I ended up having to tack weld them in to ensure they don't move. Not ideal but looks like the bushings survived ok. Once my old toe arms are removed I will make a 2nd set with a tighter fit and keep these ones as spare.
Gave the upgrade toe arms a lick of paint to cover the tacks and ready to go on the car!
I still have not fitted these to the car yet, I have just fitted an LSD and want to evaluate the handling of the car before changing the toe arms.
lab_rat394.50
      03-27-2017, 10:22 PM   #78
ianc
Ex '87 Carrera
ianc's Avatar
Drives: '10 TiAg 6MT 135i
Great solution, and a great find on the Meyle joint!
Would love to try it, but I don't think any machine shop here in CA would touch it because of liability... :-(
ianc
      03-28-2017, 01:45 PM   #79
xerox445
Damenslip-Tropfer
23
Drives: 2008 SGM 135i
How do you guys feel about the whiteline poly bushings? Coming from a honda background, we use them for some of the stock locations, but not others, as the poly bushing does not have compliance in 2 directions, where as the stock rubber ones do, IE the rear trailing arm bushing.
      03-29-2017, 07:12 AM   #80
fe1rx
Interesting approach. Getting the press fit right is definitely desirable, and installing with a Loctite bearing retaining compound is probably a good idea too. Tack welding risks cooking the dust boot or the internal bearing. The tack will likely crack if there is any movement in the fit anyway, whereas Loctite will fill any gaps. A proper interference fit is obviously best though. Luckily the way the parts install prevents the joint from coming fully apart in service, but I would suggest chalking any arm without a proper interference fit to experience and tossing it. Prototypes and test articles are part of the process and the cost of developing parts.
Here is an equivalent Lemforder part, with the pertinent dimensions noted:
Name:  Lemforder 30679 01.jpg
Incidentally, when you press a ball joint (or any bearing) in, you should press on the outer race, not the inner, to prevent overloading and damaging the bearing. Bearings are generally not designed to take high loads in the axial (push-in) direction.
titium326.50
lab_rat394.50
      03-29-2017, 05:36 PM   #81
vtl
vtl's Avatar
Australia
1493
Attachment 1597281
Yep definitely wont be using these arms for long, the tack welding is definitely not ideal. I pressed from the outer race and used a 36mm socket which fit and worked very well in pressing them in.
The bushings only cost $20 each so wasn't a big investment in R&D, ill need to get around to fitting them and testing them out
      04-19-2017, 04:15 PM   #82
3k1n
Drives: Subaru Sti
So what is the moral of this thread? Are the M3 front and rear control arms worth buying or not?
N55135i269.00
      04-19-2017, 04:39 PM   #83
fe1rx
Moral
noun
1. a lesson, especially one concerning what is right or prudent, that can be derived from a story, a piece of information, or an experience.
In this case, no moral is implied or intended. You have to make your own value judgment based on your own values. "They look nice" is an entirely sufficient reason if that is what you value. This thread was intended to provide food for thought for people that value, um, thought.
Appreciate 5
titium326.50
tetsuo1111227.00
lab_rat394.50
bchalks31.50
      05-25-2017, 09:00 PM   #84
d k
Drives: BMWless for few weeks
Great post!
Awesome technical info.
With all that said....what is the best bang for the buck as far as upgrading our suspension arms/pieces?
Id like to upgrade my 135 for track duty with moderate downforce and R comp tires.
Stick with the oe?
Go full M3?
Somewhere in between?
      05-25-2017, 10:50 PM   #85
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
These members provide the functional equivalent of a double A-arm suspension
Any musings on the trailing arm bushings? As part of the primary "A", it seems like a "joint" upgrade of some kind would be beneficial. Is there a thread I may have missed?
      05-27-2017, 10:16 PM   #86
fe1rx
For a track car maybe. I do note that Bimmerworld offers a spherical bearing kit for the trailing arms:
http://www.bimmerworld.com/BimmerWor...ing-Set_2.html
They also have one for the inner camber arm:
http://www.bimmerworld.com/BimmerWor...aring-Kit.html
I expect a definite increase in NVH with the trailing arm kit, although they claim no significant difference with the camber arm kit.
I would be interested in hearing people's experience with both kits.
      05-28-2017, 06:03 PM   #87
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
I was eyeballing the Group N stuff at Turner as a street upgrade, a compromise between the stock rubber and full balls. https://www.turnermotorsport.com/p-1...ubber-e82-e9x/. Sounds like I'll have to find out for myself.
      05-28-2017, 10:37 PM   #88
fe1rx
In my (self-interested) view, the only reason to go Group N would be to fit into a ruleset. Go full ball and report back please!
