      10-12-2023, 04:56 PM   #1
HappyDuck
HappyDuck's Avatar
Drives: 2011 BMW 128i 6MT M-Sport
2011 BMW 128i  [0.00]
Wear Sensor after upgrading to 135i calipers on a 128i
I upgraded to 135i Calipers and rotors for my 128i. However, the pads I have, from Brembo, do not have a wear sensor. Since it didn't seem to come off the pad that was on there before, nor do these Brembo pads seem to have a place for it, I cut the cable. My assumption was without a sensor making electrical contact with the rotor the car would think there is always plenty of pad.
However, my brake light is on and I can't clear the code.
What is the solution for adding a wear sensor to a 135i brake setup on my 128i?
2011 128i M-Sport 6MT Coupe
Space Gray
Style 372 Wheels
Red Manual Sport Interior
      10-12-2023, 06:23 PM   #2
SKI-R
Working towards usefulness
159
Drives: 128i, Tundra, B8S4
Close the sensor loop……don’t bother with the sensor itself - waste of time and money IMO.
09 128i Slicktop - TCKlines, KMac Plates, M3 RSFB, M3 RSB, Hotchkis FSB/endlinks, 1M brace, Wavetrac, Coolerworx, JKVK headers, RPM Motorsport Tune, Yokohama A052 255/40/17s
      10-12-2023, 07:49 PM   #3
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
Yep just twist the wires back on each other and tape it. Other option is to just unplug them and code them off, which is what I did.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      10-13-2023, 07:57 AM   #4
HappyDuck
HappyDuck's Avatar
Thanks!
Space Gray
Style 372 Wheels
      10-13-2023, 07:58 AM   #5
HappyDuck
HappyDuck's Avatar
It's good to know the solution is so simple. Thanks
Space Gray
Style 372 Wheels
      02-01-2024, 10:29 AM   #6
MAMSport
MAMSport's Avatar
87
Drives: '13 128i M-Sport coupe
Sorry for being a bit slow with this, but how does simply cutting off the sensor (with or without taping the wires back) close the sensor loop? Wouldn't disconnecting the sensor loop be similar to cutting the wires, leaving the circuit open and thus having the warning light always on?
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
      02-01-2024, 09:13 PM   #7
SKI-R
159
You need to actually connect the wires together after cutting off the sensor = ‘close the loop’.
mkeiser435.50
