      03-12-2024, 04:54 PM   #1
danix
14
Drives: e39,e46
Moving sideways?
So, my son has a 2008 135i. We did VRSF downpipes and intercooler, and he dropped a tune on, stage 2+ I think. Holy cow.
This thing pulls like a freight train, but I also noticed an instability - it feels like as the boost comes on, the car is shimmying sideways.
I suspect it's revealing some wear in the control arm bushings or similar.
Any thoughts?
      03-12-2024, 08:13 PM   #2
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
Did power before chassis.
Car was designed with run flats in mind. Needs a lot of work to sort out even at stock power levels.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      03-12-2024, 08:28 PM   #3
N55e82Simon
N55e82Simon's Avatar
151
Drives: BMW 135i
2011 bmw 135i  [9.33]
I would look at the rear subframe bushings and visual check with a pry bar around ball joints and really all suspension parts. It shouldn’t feel like what you describe even stock. It’s not great stock but very manageable. Could be poor alignment exaggerating it too.
Is everything stock on the suspension?
      03-12-2024, 09:59 PM   #4
danix
14
Drives: e39,e46
Yes, suspension is stock. https://carsandbids.com/auctions/3vW...bmw-135i-coupe
      03-13-2024, 11:06 AM   #5
danix
14
Drives: e39,e46
Rear control arm bushings were changed to M3 spec. Alignment may be slightly off as we just had the steering rack loose for the downpipe install, but it tracks straight.
      03-13-2024, 12:29 PM   #6
N55e82Simon
151
Drives: BMW 135i
I see the m3 subframe bushings which is a big help. Hmm. Seems to be a well cared for car too.
Happens with traction control on and off?
Some alignment places with give you an alignment check for cheap and you can see if something is just way off?
      03-15-2024, 03:45 PM   #7
WeryPert1
105
Drives: 128i
Agreed, replace the RSFB's with something better. Either the M3 parts or I went with the Whiteline 2-pc delrin parts. The consensus seems to be that BMW chose to use super soft RSFB's to compensate for the harshness of the crappy gen-1 runflat tires they put on the car. And now with more compliant tires the whole rear end just feels disconnected.
Olgeezer1184.50
      03-20-2024, 09:44 PM   #8
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Any thoughts?
Bushing deflection. You will likely need solid subframe bushings and spherical end toe arms to keep that rear button down.
Feel free to PM us with any questions.
      03-28-2024, 03:32 PM   #9
danix
14
Drives: e39,e46
Had the car aligned today and it was quite a bit off. Tracks straight, but when you hit the juice, it still feels like the back is moving. I'll look into some of the options suggested.
      03-28-2024, 06:03 PM   #10
Eyeman
Eyeman's Avatar
121
Drives: 2008 135 blk, blk, step
As long as not too bad, I kinda like the way our cars want to go wild when be up the boost. I have a higher hp car that is very well composed (AMG GTS) and it can be kinda boring at times. But yep, the stock 135 suspension sux.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
      03-29-2024, 02:21 PM   #11
Olgeezer1
Drives: 2010 128i 6MT Sport Pkg. 18"
Rear subframe bushings. Fairly big job as subframe should be dropped. E90 M3 subframe bushings, Whiteline 2 pc. poly bushings ( that's the way I went ), or solid aluminum bushings will all be a major improvement. There are also bushing inserts, cheaper , easier install but are really only a halfway measure. My research before buying the car 10+ years ago showed the major E82 weaknesses were the soft subframe bushings and cheap shocks/struts. Dealing with those 2 issues along with premium tires will transform your ride.
      04-01-2024, 01:27 PM   #12
HP Autosport
Drives: F80 M3
We also like the Whiteline inserts that is the all the budget you have for parts and labor.
If you are dropping the subframe for the bushings, it is also a great time to replace the two flex brake hoses at this time.
Feel free to reach out to us for Whiteline, solid alum. subframe bushings and Stoptech SS brake lines.
danix13.50
      04-02-2024, 10:46 AM   #13
N55e82Simon
151
Drives: BMW 135i
His cars and bids link shows it having m3 rear subframe bushing and arms. Kinda a weird situation. Unless the PO just lied about it. Idk
      04-02-2024, 11:24 AM   #14
HP Autosport
Drives: F80 M3
If that is the case and alignment is good, have a look at the deflection in the toe arms. Toe changes under load will steer the rear of the car causing instability.
      04-10-2024, 12:59 PM   #15
AshwinLB
47
Drives: 2008 BMW 135i 6MT
I agree with the other posters, rear subframe bushings and toe arms made a big difference to straight line stability on my 135i.
I went with condor speed shop solid uhmw rsfb and I noticed no increase in NVH but it made a MASSIVE difference in how the chassis reacts in straight lines and around turns. I’d recommend getting the eBay tool to remove the stock bushings if you’re DIYing as it made it a lot easier than the struggles I’ve seen online. I’d also recommend removing the middle brake lines from the subframe so you can drop it a little bit lower. And might as well change the lines at the same time, I went with UUC stainless lines just cause they use factory style mounting faces so you don’t have to counter-hold while tightening the lines. Really doesn’t matter though
For toe arms, you can’t use e90 m3 toe arms as they’re too long so I went with Megan Racing Toe Arms which have spherical bearings on both ends and put on seals it rod end boots to keep them from eventually clunking (they already had seals but they were kinda wimpy). If you don’t wanna bother with that, the Manzo Toe Arms are the exact same design except with rubber bushings on each end which should be more durable but would have some compliance due to the nature of rubber (still better than stock). I also added a SPL eccentric lockout so all the toe adjustment is from the arm itself instead of the eccentric bolt.
I also did an mfactory LSD but it’s hard to justify/recommend it due to cost vs benefits (especially if it’s just a street car), but also made a huge difference to straight-line stability and handling around corners. The car just feels like it’s on rails. Still, the rsfb and toe arms have a much better cost to benefit ratio so I’d recommend just doing those initially.
