Where can I get a parts diagram for the coolant lines?
01-11-2023, 12:39 PM | #1 |
Rep 418
I have a coolant leak on a hose. I think its the o ring and I'm having trouble finding a part number. I attached a picture of the line. 2011 328xi.
Thank you |
01-11-2023, 01:05 PM | #2 |
175
Rep 344
Realoem.com
although I don't think you can buy the orings thru BMW. I bought an entire o-ring kit for the N51/52 from AliExpress |
racerbruce3855.50 |
01-11-2023, 01:34 PM | #4 |
Rep 1,105
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
+1 on realoem.com. My go-to resource for part numbers.
racerbruce3855.50 |
01-11-2023, 02:08 PM | #6 | |
Rep 4,086
https://www.realoem.com/bmw/enUS/sho...diagId=17_0350 Inserting that part# in Autohaus, ECS & Amazon site search boxes yields: https://www.autohausaz.com/pn/17127531579 https://www.ecstuning.com/BMW-E91-32...h/17127531579/ https://www.amazon.com/s?k=BMW+17127...f=nb_sb_noss_1 I would be VERY CAREFUL HOW you remove the Upper Radiator Hose from the Radiator. Plastic that is 16 years-old, and has been through several thousand heat cycles is VERY BRITTLE. A cracked radiator will greatly increase your time & expense. ANYONE who has successfully separated those fittings, please offer specific tips. I have NOT, but my understanding is that you do NOT Twist the fitting, as there is a locating notch. George |
StradaRedlands4994.00 ppointer750.00 |
01-11-2023, 03:27 PM | #9 | |
Rep 815
All I can recommend is to be gentle and go slow removing it. Try NOT to leaver it with a screw driver or something that would be likely to put pressure on the radiator fitting and crack it. I have heard that a bit of heat helps, but again, be careful because everything there is plastic. Ideally, you'll pop off that metal clip, and the fitting will pull off the radiator with just a little tug. Pull as straight back as possible...no twisting. Last edited by jsunma; 01-11-2023 at 03:52 PM.. |
01-11-2023, 03:32 PM | #10 | |
Rep 815
https://www.ecstuning.com/Search/Sit...h/64219178427/ It actually costs more than the radiator hose (for which the $25 Rein hose is fine...no real need to spend 3 times more for the BMW-labeled one, IMO). I'd suggest getting the radiator hose and trying that first. It's an easy fix assuming nothing breaks. In my case, I bought the heater hose too, but never installed it as replacing the radiator hose fixed my issue, and I would just as well not have to bother with the heater hose unless necessary (the EASY end of that is the front end...getting to the end at the firewall requires more work). BTW, I'd suggest FCP as the parts source if you're intending to keep the car for any significant length of time. Their lifetime guarantee is great for stuff that you KNOW you'll be replacing more than once...such as coolant hoses and radiators. |
01-11-2023, 03:49 PM | #11 |
Rep 815
One last thing. The more I look at your photo, the more I suspect that it could just be the o-ring inside of that fitting on the heater hose. If so, and you have another car to get yourself to the autoparts store (or even a good sized hardware store), you might pop that off, remove the o-ring and go get it sized up properly and buy a new one. That would be much preferable to spending $45 bucks on the hose (which has the o-rings in it) and digging out the far end of the heater hose at the firewall.
From what I can tell (recall that I have this hose uninstalled, so I just went and looked at mine), the o-ring in question is quite possibly a 22 X 4mm. But I have a 22 X 4 and it seems a hair too big around...so perhaps there's such a thing as a 21 X 4. Anyway, I'd remove the old one and compare it with what's available at the hardware or autoparts store. Good luck! |
Mike K325.00 |
01-12-2023, 09:47 AM | #13 |
Rep 418
I've tried looking for the orings locally before and I had no luck. Thanks for the measurements. I will try looking again. BMW doesn't sell the orings. The radiator hose looks like it might have been replaced before. If I can't find an original I will replace the radiator hose first. The leak isn't real bad but it makes me worry when I drive out of town.
01-12-2023, 01:47 PM | #16 |
Rep 1,682
There are o-rings in the upper radiator hose large connectors too. The o-rings are the primary seals, and proved to be less reliable than a plain rubber hose end with a hose clamp. The factory hose connector (including the Mickey flange) obviously is made of a cheap plastic than what is on the radiator.
I also have a Gates upper hose on there now. The old one I cut with a Dremel to help protect the radiator, after hearing all the cracked radiator stories. The Gates upper hose does carry lifetime warranty. A heat gun seems to be the best "non-destructive" method of removal. My Gates upper hose: The old factory hose cut, as well as a failed Mickey flange upon removal: You can use this search function. 4 mm CS o-rings are usually huge, like 100 mm ID. So I played with smaller CS like 2.65 mm. You can adjust the numbers and see: 2.62mm CS x 15.88 ID, FKM is Viton, like the new OFHG from Japan: https://www.marcorubber.com/store?se...15.88&offset=1 Metric o-ring size chart: https://www.marcorubber.com/o-ring-s...art-metric.htm From BMW of Silver Spring's catalog using jsunma's part number. It is quicker just to get a hose in case you cannot find the correct o-ring and still waited for shipping. Last edited by mainbearing; 01-12-2023 at 01:57 PM.. |
Mike K325.00 |
01-12-2023, 06:34 PM | #17 | |
Rep 4,086
HNBR, Nitrile, Buna-N, Other(?) compounds are available. It is my understanding that HNBR (usually green) is best for refrigeration systems. ANYONE have knowledge of type of "Rubber Compound" that is best for a particular use? I have simply used "Imported" supplies from HFT & Amazon, with NO issues in any application from R-134a refrigeration fittings to plumbing Here are some examples: https://www.amazon.com/s?k=o-ring+ki...31&ref=sr_pg_1 George |
01-13-2023, 05:49 AM | #18 |
30
Rep 71
I always struggle with that question as well. Time to do some reading and googling. For now my simple rule is: You touch an old hose, you replace that old hose. Which is what I am doing today when I replace my water pump and thermostat at 142k. (So, I am doing alright from what I read...)
01-13-2023, 01:15 PM | #19 |
Rep 418
I will probably try ordering both the hoses so I have them on hand. I would rather to only replace the radiator hose but it sounds like the oring in either one could be the problem.
01-17-2023, 05:13 PM | #21 |
Rep 4,324
1 o ring on each connection that has a C-clip
Radiator hose has 2 clips, so 2 rings, 1 at radiator connection and 1 at oil filter housing connection. Line going up to radiator hose has 1. They’re in a groove in the hoses. |
