      09-02-2022, 11:13 AM   #23
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
I did not. But fastest time I have seen on the 1er with ps2 is 6.8s 100-200. I’ll see if my buddy can post his time.
      09-06-2022, 03:13 AM   #24
mwpa71
20
Drives: 2010 E88 135i
Thanks mate
      09-06-2022, 04:01 PM   #25
mfindigital
Drives: 2011 135i
i still don't see this on pure's site. Is there a discount for ps2 owners? Making 580whp comfortably sounds amazing. what tires are u running? I'm on 255's contact xtremes and spin in 4th. Ordered new wheels and planning on mounting federal rsr to see if I can find some grip.
2011 Space Grey 135i DCT:
Pure Stage 2, Fuel-it Stage 2 LPFP, ST XTA Coilovers, Berk Street Axle Back, MHD Stage 2+, VRSF Catless DP, VRSF 5" FMIC, VRSF LCP, BMS UCP, M3 FSB, e92 M3 Drivers Seat.
      09-07-2022, 01:05 PM   #26
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
I think they are a couple months out from releasing the final production version for the n55 pwg/ ewg cars. They haven’t forgotten about us. From what I understand they are improving the design which is awesome.
I am running federal fz201m tires, 255 front/ 265 rear. Once they are warmed up they can hold my max power setting from third and up. Pretty awesome.
      09-15-2022, 02:36 PM   #27
mwpa71
20
Hey hoots
Are you xhp?
      09-15-2022, 03:01 PM   #28
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Yup. XHP. Mostly got it so I don’t get any auto shifts when the tires spin up. But use some other features as well like creep disable.
      09-16-2022, 07:13 AM   #29
mwpa71
20
Creep disable is a winner. Have you changed torque punch/reduction?
      09-16-2022, 10:37 AM   #30
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
I messed with it a little but got lazy and reverted everything to the stock stage 3 settings. You find any changes worth while?
      09-16-2022, 04:56 PM   #31
mwpa71
20
Same. Increased punch to 3 was my happy place.
Changed launch to 4000. My fastest dig times are from using DTC on.. Dont lauch often as you know, they are not the best for this.
I have maxed out my ps2 25psi 14deg direct port wmi. I have a built motor with 9.5 comp.. The lower comp robs me a few hp up top. Could potentially up the timing but not worth the risk...A bigger turbo needed..I checked out your maf/gs. They say this reflects power somewhat but not so sure.. yours is similar to mine but my 100-200 is only 7.3 ! (Its a vert so 165kgs heavier)
houtan707.00
      09-22-2022, 04:18 AM   #32
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Nice! You have any logs you could share?
7.3 is still fast. Best I have seen on a PS2 is 6.8 100-200. But that is a coupe so a lighter car.
      09-23-2022, 01:46 AM   #33
mwpa71
20
Cheers. Cool weather would help a little to.
https://datazap.me/u/mwpa71/port-wmi...og=0&data=4-15
houtan707.00
      12-28-2022, 12:47 PM   #34
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Posted a small update in the OP on my runs at NFZ in Gila Bend, AZ on 18DEC2022. had a blast.
      12-28-2022, 04:18 PM   #35
mwpa71
20
Hey Hoots.
thats a massive improvement!! well done'
165 with 26psi ?? :-)
      12-28-2022, 05:11 PM   #36
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Thanks. I probably had 3-5 mph left on the table for sure.
      12-28-2022, 06:49 PM   #37
mwpa71
20
it gets as little frustrating when you get the gremlins affecting your car. Hope you sort it easily.
ps do you know if pure are on holidays atm?
      05-09-2023, 07:40 AM   #38
bmwboyee
59
Drives: 2011 BMW 135i
Sorry to bring this back from the past but do you have any pictures of your exhaust? Looking to get one built.
      05-09-2023, 11:08 AM   #39
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
bmwboyee , yeah I sure do. Here you go.
This is a 2 x 2.5” to 1 x 3.5” Y pipe going to a 3.5” straight through Magnaflow muffler. Hope that helps!
      06-29-2023, 06:47 PM   #40
ByeByeVTEC
24
Drives: 2012 135i
Awesome results, that must be fun as hell!
As a new DCT owner I am happy to see it can handle that much torque!
I guess we'll see how reliable it remains at that power level? Seems like I have nothing to worry about with a MHD Stage 2.
Sounds like you know tuning, I used to tune on COBB AP back nearly 10 years ago but am new to MHD and trying to figure how this is all done. In my COBB days they had accesstuner available to everyone and you could use their OTS maps as a basemap for your own tweaking. As far as I can tell this is not possible with MHD?
Is there anywhere you can find a basemap (or even stock map) for N55 that I can open up in TunerStudio (or similar that you may recommend) to and flash on using my MHD?
      06-29-2023, 11:57 PM   #41
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
ByeByeVTEC , thanks for your post.
The DCT is in many different cars that come with much more power than the 135i, such as the F series m3/4, some m5s, etc, so it is capable of handling a lot of power. My torque comes on later as well which the DCT handles without issue. And I am on stock clutch pack, more than 65K miles.
WRT tuning, MHD should download your stock map, which you can then Tweak in tuner pro.
Are you on the stock turbo?
      06-30-2023, 11:18 AM   #42
ByeByeVTEC
24
Drives: 2012 135i
The DCT is in many different cars that come with much more power than the 135i, such as the F series m3/4, some m5s, etc, so it is capable of handling a lot of power. My torque comes on later as well which the DCT handles without issue. And I am on stock clutch pack, more than 75K miles.
Thanks for the reply!
I am indeed on the stock turbo. I just got the car this month but the previous owner had installed an ETS intercooler & charge pipe and a full turbo-back exhaust (I guess essentially FBO).
First time owning a RWD car after always having tuned Honda's..... This thing is fun as hell. Nice to be able to power oversteer, brings flashbacks of my FSAE days.
houtan707.00
      07-30-2023, 08:29 PM   #43
domohockey
Drives: 2013 135i
2013 BMW 135i  [0.00]
Is this turbo the new Pure 750 turbo that they just released?
      07-30-2023, 08:30 PM   #44
domohockey
Drives: 2013 135i
And are you built motor with this power?
n55, ps3, pure stage 3, stage 3
