BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > Pilot Bearing Removal e92 DIY
      12-30-2014, 10:01 PM   #1
335e92
335e92's Avatar
131
Drives: 335i e92
Just wanted to share a quick and easy way to get pilot bearing out.
#1 Go get your self a mini grease gun.[
#2 See the small hole on you pilot bearing?
#3 Stick the tip in nice and firm to the hole and start pumping it up with grease.
#4 Give it nice couple taps with your palm.
Worked for me!
Good luck
GSB38.50
      01-06-2015, 06:42 PM   #2
335iNavyGuy
205
Drives: 07 N54 E92
How the heck did you hold It tight enough for this to work
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV
BBS Lm reps - AFE dual cone intake
      01-06-2015, 07:09 PM   #3
335e92
335e92's Avatar
131
Drives: 335i e92
Pascal's law
GSB38.50
      03-29-2016, 12:31 AM   #4
N54Society
Major Private First Class
N54Society's Avatar
Drives: 2010 E90 335i M Sport
This did not work for me unfortunately. I not sure what will.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs
      03-30-2020, 10:04 AM   #5
Skers 05
Skers 05's Avatar
Drives: '08 1M Clone, '11 328i, '13 X5
Thanks for the post! I used this post to help me with a pilot bearing that was stuck in the input shaft of the transmission. A couple tips from my side that helped aid the removal.
#1 - I purchased this grease gun tip from Advanced Auto Parts (similar tips available at other auto parts stores) and pressed it into the pilot bearing hole.
https://shop.advanceautoparts.com/p/...4216/9240029-P
#2 - I used a heat gun to help expand the input shaft ID to allow the bearing to be extracted easier.
      03-24-2022, 05:53 PM   #6
INDiRector
INDiRector's Avatar
Drives: bmw 335xi
Weighing the options
I went looking for help after I had already destroyed the inner bearing on my 335. I will definitely try the grease trick tomorrow and will post my results.
      03-25-2022, 09:27 PM   #7
INDiRector
INDiRector's Avatar
Drives: bmw 335xi
Grease trick
So, the grease worked slicker than a whistle for my pilot bearing. It was much easier by having two people, one to hold the grease needle and one to pump the grease. You all saved my butt.
Thanks
      02-17-2024, 03:26 AM   #8
GSB
Electronics Engineer
Drives: 2008 335i E92 Coupe (N54 6MT)
Very clever! Thanks for sharing.
      02-17-2024, 07:52 AM   #9
kolopn
23
Drives: E92 325i N52B25
You can always put the head of the screw inside, hold the bearing by head of the bolt, and then just screw something like nut and punch the nut by the hammer, it will come out easily.
