Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - NBT Retrofit - E92
      08-07-2016, 02:25 AM   #1
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
DIY - NBT retrofit - E92
Posting this DIY to help peeps who may considering doing this upgrade
First up, I cant take credit for these following install. All credit goes to Melbourne based E90 forum member Vtl (Vince aka BMW Yoda)
Top guy who not only does awesome work but also gives up most of his weekends to help peeps with their installs...
Vtl did all the work on this retrofit, I simply took the pictures and documented this DIV
Backstory
My car is a 2008 E92 with a the original CCC unit
One of guys on the forum (Cashy) pulled together a group buy and a pile of information on the NBT retrofit process and the parts needed
The total cost of the upgrade including install was around $3000
TBH its an expensive upgrade and really only worth doing if you want to modernise your CCC system.
If you have CIC already, then this upgrade is probably not necessary
What parts you need will depend on your cars year and model
Do your research and check the part numbers before you buy (realoem.com is a helpful reference)
These are the parts needed for my 2008 E92
1. NBT retrofit kit
Include NBT head unit, LED screen and retrofit wiring harness (pre-coded to cars VIN)
2. CIC front panel
Covers NBT DVD slot. Includes volume knob and radio buttons
3. CIC console trim
Front console trim with hole cut for CIC controller. Check the shape of the hole in the photo below
4. CIC controller
CIC Multi function button Idrive controller
5. CIC controller bracket
Plastic bracket that holds the controller in place and allows it to be fastened to the console trim
6. CIC controller trim
Silver trim that fits neatly around controller to hid gap (optional)
7. Aux/USB cable
Cable and socket that runs from the center console to the NBT head unit
8. Blue tooth antenna
In dash blue tooth antenna. Your old blue tooth module wont work after NBT install, so you need this
9. Reversing camera
Replacement trunk handle with camera (optional)
There are other items that you may require, depending on your car and the NBT options you chose (eg ceramic touch controller)
These are simply the items needed for my upgrade
      08-07-2016, 02:26 AM   #2
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Before and After
      08-07-2016, 02:26 AM   #3
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Step 1 - Removing CIC system
      08-07-2016, 02:28 AM   #4
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Removal continued
      08-07-2016, 02:29 AM   #5
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Removal continued ..
      08-07-2016, 02:29 AM   #6
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
With the CCC system out of the vehicle the next stage is to replace the CCC backlit screen with the NBT LCD screen.
Think of it like pulling apart a TV, replacing the LED screen and putting the TV back together again
In this next section, we walk through the steps for disassembling the CCC screen and the NBT screens, then how you use parts from both the CCC and NBT units, to build a new display screen, that will fit back perfectly into the dashboard
CCC Screen Disassembly
Now to disassemble the CCC screen
We basically want to keep the shell so the new screen will fit back into the dashboard like the original screen
To hold the new LED screen in place we also need to keep the internal structural plates
      08-07-2016, 02:31 AM   #7
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
CCC screen disassembly continued
      08-07-2016, 02:31 AM   #8
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
NBT Screen Disassembly
Now to disassemble the NBT screen
We basically want to keep the new LCD screen and electronics, so we can put it inside the old CCC shell
      08-07-2016, 02:32 AM   #9
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
NBT screen assembly
Now its time to put the NBT screen into the CCC shell
      08-07-2016, 02:33 AM   #10
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
NBT screen assembly continued
Appreciate 4
      08-07-2016, 02:34 AM   #11
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Install
Final step, wiring everything up and fitting it into the dash
It was pretty late in the day, so I did not get lots of pics of this stage
Is basically a reverse of the removal stage and if you following the wiring instructions provided by your supplier, it should be pretty simple
One word of caution, the colour of the the plugs do not always match, so don't be concerned if the plug is green and the socket is blue
Also remember to reconnect and test everything before installing everything in the dash
It is much easier to switch plugs around before you install everything and have to pull it out again
      08-07-2016, 02:35 AM   #12
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Install continued
Appreciate 5
      08-08-2016, 05:39 AM   #13
DR-JEKL
Australia
898
Drives: Space Grey E92 335i 6MT
Thanks for taking the time to write this up and share with the community!
I didn't realise how fortunate we are on here with all the diy guides, I was searching for some simple guides on my other car a vw passat and could not find anything!
It looks really good im very keen to install mine when all my bits arrive
      08-09-2016, 10:52 PM   #14
zmcgr1
Drives: E90 330i 2005
HI mate thanks very much for the guide makes it look simple.
did you get dab with your install and how to you go about getting it to work antenna wise?
      08-12-2016, 02:46 AM   #15
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Not sure I can help with this, we simply hooked up the supplied harness and wiring... PM Vtl he is a genius and may be able to help
http://www.e90post.com/forums/member.php?u=272938
hellokitty2895.50
      08-12-2016, 06:34 PM   #16
N54Twin
N54Twin's Avatar
413
Drives: F85
Nice work.
Getting Nbt install next month on my e60.
Missing 2 cables, display cable & Bluetooth antenna.
Not in the pic but i have the touch module.
Sweet Pie
Socket4542.00
      09-11-2016, 02:19 PM   #17
longnvu
38
Drives: E90 E92 E60 F30
can we use any nbt head unit for this retrofit?
      09-11-2016, 05:18 PM   #18
N54Twin
N54Twin's Avatar
413
Drives: F85
I bought parts from different cars, So yes.
There is one for $221.23 right now on eBay part number 361716225557.
Sweet Pie
      09-12-2016, 04:19 AM   #19
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
as far as I know but you will need to have it coded to your VIN
      11-23-2016, 09:10 AM   #20
ibd12nv
Chief Warrant Officer 4
ibd12nv's Avatar
53
Drives: 335I, E46 M3, X5M
2007 E90 335i  [10.00]
Keeping this. Thanks
      11-24-2016, 02:36 AM   #21
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
ur welcome
      12-01-2016, 04:45 AM   #22
Meso
Yes, I'm proud of myself.
Egypt
Drives: BMW E92 335I
Simply you are amazing bro
Socket4542.00
