BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: E9X ACC Retrofit
      06-20-2019, 02:20 PM   #23
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
so badass. I want this on my M3 lolll
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
      06-21-2019, 03:54 AM   #24
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
You would have to custom make the trim and retrofit a non m3 DSC pump.
      06-21-2019, 01:40 PM   #25
JonEQuest
JonEQuest's Avatar
246
Drives: 2008 335i Convertible 2007 335
I have a 05/2007 (2007 parts car), and a 09/2007 (2008 car I am driving) pair of E93's. Is the DSC pump the correct one for this?
      06-22-2019, 04:53 PM   #26
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
478
Drives: BMW
can you share the coding from the KOMBI to show D1-D6 ? thanks
      06-22-2019, 06:57 PM   #27
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I didn't custom code the Kombi. I only VO coded $541 to it.
      06-24-2019, 01:25 PM   #28
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
478
Drives: BMW
interesting! so after you coded the ACC function, you get the D1-D6 instead of just D?
i am almost there with this retrofit, hopefully will finish next weekend
      06-25-2019, 03:58 PM   #29
eren2k7
Drives: e92 320d 2007
E92 320d n47
Can this be retrofitted to a 2007 N47 engine 320D.
My E92 has the normal cruise control fitted as standard.
It doesnt brake while going downhill in cruise control mode.
Has anyone attempted this to a european 4 cylinder N47?
      06-25-2019, 04:39 PM   #30
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I believe you will need a new DSC pump and cluster.
      06-25-2019, 11:23 PM   #31
ptpending
ptpending's Avatar
456
Drives: e91
not only pump but sensors on the wheels should be different
so only 4cyl car which can have ACC is with XDrive, because XDrive DSC have these sensors
thats why i sold my kit
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      06-29-2019, 01:22 PM   #32
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
478
Drives: BMW
unfortunately my ACC is not working. after i coded $541 to KOMBI, LDM, ACC, DSC and JBE the car works like before (with $544). i suspect it's because i have a KOMBI from M3 and since M3 never had ACC, it's lacking the sw/hw necessary.
any ideas?
      06-29-2019, 01:34 PM   #33
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
any ideas?
I would try a normal cluster.
      07-01-2019, 08:37 AM   #34
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
478
Drives: BMW
i ve already bought one from 335i ( even though i have a 325d) because i wanted the temp gauge. the long rpm gauge is not a problem, i don t watch it anyways. M3 kombi was perfect , too bad it s not working with ACC. i will install it and report back
      07-05-2019, 04:56 AM   #35
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
478
Drives: BMW
Originally Posted by vilord View Post
Just ordered all the parts for this retrofit.
The ACC sensor I ordered did not come with the three adjuster bolts, so instead of the 3 "nuts" listed, I had to order a "repair kit". The repair kit ($60!!! wtf!) includes three adjuster bolts and 3 nuts.
I also ordered an LDM ($17 from ebay including the chopped off harness) and a combination switch with the active cruise adjuster.
The guy I ordered the combo switch from is here, and he has two more sets:
https://www.ebay.com/itm/362482324584
The part (61319203110) is listed for X6 only, but X6 and E90 share this alternate part: 61319203109, so hopefully it will be close enough that I can use it.
Have you managed to fit the e70 stalks into your e90?
      07-05-2019, 09:33 PM   #36
unrulyteach
unrulyteach's Avatar
Drives: 2011 335i
2011 BMW 335i  [0.00]
Has anyone done a more in-depth diy?
      07-05-2019, 09:40 PM   #37
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
For your car you will need a LDM, ACC, ACC stalk, brackets and trim. You can use a standalone stalk or get a whole new clock spring. The only ACC retrofit cars on earth that I know of are Mashman's, vehicle DIY's, my customers car and my car. These are very rare parts and require making a custom harness. The E90 acc only works well when the people around you do not drive aggressively. People in any city would not like ACC.
You need PT can, 15up, power and ground for all of the new modules. The ACC and ldm take up 5-10 amp so you can take power from a fuse tap, cig outlet or anything with 18 gauge wires.
      07-05-2019, 09:57 PM   #38
unrulyteach
Drives: 2011 335i
Fuse tap can power both ldm and acc? I hav been watch vehicle diy but I'm still confused about what wires he tapped for pt can and wake up. Ik where ground and power goes
      07-05-2019, 10:11 PM   #39
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
The LDM and ACC need power from a 30g fuse. Use any of these fuses:
canara atm near me
For ground you can attach a ground point to a factory ground comb or really any bolt.
      07-05-2019, 10:31 PM   #40
unrulyteach
Drives: 2011 335i
That part i get. And pt high and pt low taps into ? I see the wake up taps into pin 18
      07-05-2019, 10:40 PM   #41
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
https://www.ebay.com/itm/Indicator-W...MAAOSwR6Bb0Y4P
https://www.ebay.co.uk/itm/GENUINE-B...wAAOSw9Sxc5~Lx
https://www.ebay.com/itm/BMW-3er-E90...cAAOSw9mBbd0mv
I would probably tap that into the jbbf.
      07-05-2019, 10:48 PM   #42
unrulyteach
Drives: 2011 335i
Can i tap 34 and 31? For pt high and low?
      07-05-2019, 11:08 PM   #43
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
the cas does not have pt can.
      07-06-2019, 02:50 PM   #44
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I just adjusted a customers ACC sensor remotely. ISTA would not work so I used INPA. The car needs to be on a level surface with the parking brake on and the tires at the factory PSI. The sensor needs to be 1.2 meters away from a large full body mirror. The mirror needs to be perfectly vertical and perpendicular to the car. I measured the distance between the front wheels to each side of the mirror. Once both wheels were exactly the same distance from each side of the mirror you are ready for the adjustment. If you are installing new adjustment screws set all three of them to 43mm.
Load up the ACC module under inpa. Hit F6 (Activate), F6 (justage) and then F3. Start hitting next until it ask you for set up values on the BMW tool. I put in the factory example values (4.2 and 1.3 I believe). It will then show you a alignment gauge that will not move as you turn the adjustment screws; It is not a live reading. Please note the scale will change when you do a new reading. I would run through the entire process two times to make sure the values you get are about the same. The first time I tired adjusting the sensor it keep giving us random adjustment values. I had to re-position the mirror. Then it took three adjustment round to get the sensor values in the green area. The top screw controls the vertical adjustment and the bottom screw adjusts the horizontal adjustment.
I would love to see how close this adjustment is to the one you would get at the dealer.
