Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > Official DIY HALOGEN to XENON Conversion!
      01-11-2008, 12:26 AM   #67
ScheerSpeed
ScheerSpeed's Avatar
Drives: '13 F30 Estoril M-Sport 335i
great DIY, i just used it yesterday
      03-15-2008, 12:54 PM   #68
Excellence
G-STAR
Excellence's Avatar
200
Drives: E90 to A5
This is the connector diagram. #1 should be angel eyes.
      03-28-2008, 11:22 AM   #69
a l l a n
Drives: E90 2007 328xi
2007 E90 328xi  [0.00]
How did you guys remove the piece that holds the pins into the plug? (Step 7, picture 6 from this DIY). I spent an hour trying to remove it with no luck.
Also, what kind of wire is used for the ground (#4 and #2, the thick brown wire.) Looks like I don't have that.
Thanks.
E90 2007 / Step / Montego Blue / Black Dakota Leather / Premium / Cold Weather
MODS
: Exterior: Blacklines, debadged, HO ceramic 35% tint, Hoen yellow fogs, matte black grille, OEM style splitters, Halogen-to-Xenon Interior: Alum pedals, CF wrapped trim, V1 and Nuvi hardwire, M-Tech tri-stitched wheel, SMG M5 shift knob Performance: AluFelgen CSL 19" 8.5 ET33/9.5 ET30 with 5mm rear spacers | GY Eagle F1 Asym 235/265, KW V3, BMW Perf exhaust+intake
      08-25-2008, 01:59 PM   #70
BLK E90
BLK E90's Avatar
Drives: BLK E90
Ok...
I have read the DIY Threads on it very carefully and I am still really confused on the whole process...
Anybody who has done it please help me out...
I am going to be basing my questions off of ADHD's Thread http://www.e90post.com/forums/showth...=halogen+xenon
1. Should you put the front bumper on before you start messing with the wires? Or does it not really matter...
2. In step 5 of his DIY he mentions "First we need to add a Ground to the chassis! this is connected to hole #2 on the plug. The best ground is the one noted in pic#4 (green wire running up the black wiring harness bolted to the silver NUT that holds the ground box!"
-When it says first we need to add a Ground to the Chassis... Where do you get the ground? Do you have to buy one? Or is it that "(green wire running up the black wiring harness bolted to the silver NUT that holds the ground box)"... And then do you just pull if off of that? Or do you have to splice it as well?
3. "6. Splicing the high beam wire to add the bixenon shutter wire!
First cut the high beam wire#6 in half! add a but splice at the end of the wire coming from the car and crimp it in place..Then take an ADDED wire and twist it together at the end so u can put it in the butt splice together and crimp! Now u should have two wires coming out of the one connection as shown in pic#5"
- So are you supposed to slice open wire #6's plastic wrap and pull the two wires apart to create this seperation...?
- Where do you get the "Butt Splice" to add to the end of the wire coming from the car? (Cramp it into what place?)
- "Then take an ADDED wire" were do you get that from? #6?
I am not very good with mechanics or wiring... So I just need a little extra help...
And I don't feel like paying 500-750 Dollars to get it done...
Any information will help...
Thanks!
" I Have A Fever... And The Only Prescription... Is More Cow Bell...! "
      09-06-2008, 04:08 AM   #71
Sui
Drives: BMW E82 123d
Hi,
some people may already know me.
I am a friend of ADHD, who supplies the german OEM lights.
I have one set AHLs in stock again.
They are in very well condition, not scratches, marks, broken tabs.
They will come without bulbs and ballast, so just to make a conversion from amber to white side markers.
I will Sell these lights for 980$ fix.
At BMW, the lights costs $1,205.28 each one!
Shipping from Germany will take appr. 10 working days.
Below you will find pics just from the lights which are up for sale.
Feel free to contact me or AHDH, but i will be on vacation (in US!) from 10-26 September.
      12-22-2008, 11:05 AM   #72
DrPowers
10
Drives: 2006 325i
I'm having some trouble with this mod.
I've done the wiring internally to the headlight and have spliced the black lead from the ballast to the brown lead (existing ground wire) using butt splices.
Everything seems to function correctly but I not only get a warning when the car starts but also once a minute while the car is on.
I dont mind the warning when the car starts but I do mind the warning that appears every minute or so... is there something I can do to repair this?
      01-25-2009, 09:14 PM   #73
exclusivo
exclusivo's Avatar
126
Drives: race car
Anyone know if this is required when doing an aftermarket kit install (Mtec), with xenon assemblies?
      02-26-2009, 08:48 AM   #74
robertmrk
Italy
Drives: BMW E91
Hello, I wanted to know how the connectors are called to enter the pin 4 for the mass, are in dealership. Thanks.
      02-27-2009, 04:36 PM   #75
robertmrk
Italy
Drives: BMW E91
Nobody answer me?
      03-09-2009, 08:57 PM   #76
m5sparky
m5sparky's Avatar
Drives: 2013 BMW M5
whats the best way to get rid of the buzzing sound when i turn the lights off or put the switch for corners only, the buzzing is insane, it stops after i turn the headlights on. please help!
      03-10-2009, 03:20 AM   #77
JayReplay
Drives: E46 M3 6MT Sunroof Delete
Is it possible to do this halogen to xenon conversion using US spec adaptive headlights? Will the xenons still power on? Any errors?
2002 Laguna Seca Blue E46 M3 6MT
2017 White C63 AMG Coupe
2002 Oxford Green E46 M3 6MT - Sold
      06-15-2009, 06:05 PM   #78
exclusivo
exclusivo's Avatar
126
Drives: race car
can someone explain a little more specifically on how to wire the lights internally without cutting the harness. and also what plugs/adapters need to be bought.
      04-06-2010, 06:32 PM   #79
torohandyman
10
Drives: 2006 BMW 325I 6-SPEED
need video on this
Hi can you post some video's on this. like some step by step. some video clips please.
Originally Posted by ADHD View Post
After Further Months of Improvements a couple things to NOTE:
1. The wiring can be done INTERNALLY so that you do not have to cut your Harness wires or even score the wire with a generic Tap connector!!
Tap connectors Have been used and about 80% of the time they worked I suggest using BUTT SPLICES!!
2. Buy the actual plugs that plug into your harness from realoem here
http://www.realoem.com/bmw/showparts...91&hg=61&fg=15
3. Do not ground the GROUND wire to the CHASSIS!! Tap to the wire directly to #4 wire!!
      06-28-2010, 02:16 AM   #80
mikekilpatrick
mikekilpatrick's Avatar
Drives: 2013 BMW F10 550 Xdrive Msport
Ok, now has anyone done this the factory way? Buy the wiring retrofit kit, sensors, new footwell module, light switch, etc and install it?
      06-28-2010, 08:34 PM   #81
mikekilpatrick
Ok, has anyone done this with the kit from roveractive? I want to install my US Xenons the proper way with the new foot well module, headlight module, etc and factory wiring. Has anyone does this? If so, could you post or PM me?
      11-16-2010, 04:07 PM   #82
corleone2b
France
Drives: e90 325D
hello,
Any change on the installation of bi-xenon has the place of the halogen since 2006?
No piece of news short faster way?
Closely kit sold in the business?
Thank you in advance for your answers.
      11-18-2010, 04:13 PM   #83
Sidnito
Sidnito's Avatar
Drives: 11 space 335i
Thats what i would like to know, im about to buy these and was wanting to hear some reviews without doing any mods. if i upgrade to HID kit would it eliminate troubles?
      03-13-2011, 04:06 PM   #84
Horsebox
Drives: 2007 Petrol 325i M Sport Le Ma
Question
Ye know this topic has me totally confused.
I'm sure I am only asking a question that many BMW E90 owners ask themselves.... How do I get the ice white halo angel eye rings fitted into my standard headlamps
1. Cheaply and not silly money
2. Without causing faults
3. Where from.
Every forum reads confusing facts on this topic when all is needed is a basic explaination as to the best way to do this and someone to talk to about it who can do this.
      03-13-2011, 07:19 PM   #85
orangedawg
Drives: 328xi
If you have halogen lights that currently don't have OEM AE in them, I don't believe you can add AE. You will need to get new housings, either OEM or DEPO.
If you have OEM xenons or OEM halogens that have AE, then just change the bulbs. But if, you don't have AE already in your car, there is no cheap solution.
      03-13-2011, 07:55 PM   #86
watabaotnao
Somaliland
13
Drives: 07 328i, #358 metrobus
how does this solve the halogen to xenon Wattage issue?
going 55W(halogen) to 35W(xenon) power draw does trigger error?
i have 2007 328i halogen 55W headlight and i have a pair of U.S. spec Adaptive Xenons from a 2006 325i. Should i be scared to do this DIY because the headlight will be supplied with 55W instead of 35W?
      04-28-2011, 03:00 AM   #87
Yvette
761
Drives: M
this is why you get error.
      04-30-2011, 02:43 PM   #88
orangedawg
Drives: 328xi
Anyone have an answer for this? I've got it too!
