Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY Powered seat retrofit (WIP)
      04-28-2011, 01:33 AM   #89
Radu83
Drives: E90 320d M Sport Aut.
Originally Posted by woodpecka View Post
My seat belt tensioners were deployed during the previous car crash. I replaced them with the old ones.
When the root cause is resolve, you can remove the airbag error with INPA (coding)
I did the same with mine , the seat i bought were from an US spec car , 2008 335i and i mounted them on euro E90. Airbags and seat belt tensioners were deployed so i put the old ones on . When i scan my car for the airbag light i get an OC3 sensor error , that the presence sensor in the passenger seat and as far as i know that sensor is now part of the seat cushion and its a pain to replace it
      08-15-2011, 03:03 PM   #90
digitalfx
Drives: 2013 BMW 328XI
hey everyone, i just purchased sport seats. I installed the driver's side yesterday, i didnt do anything with the wiring, i just unplugged the battery first and then plugged in the harness to the seat. Positioning is the only thing working.
Here is some back information about my car. My original seats were heated/powered w/ lumbar & memory. The sport seats I bought have memory, lumbar, and are powered, i am not sure about the heating.
currently side bolsters and lumbar are not working and possibly the heated although i do not know for sure if the seats have heating. So from what i have gathered on this topic is that i need to add some pins to the harness that connects from under the seat that comes out of the floor. Or do i still need to access the fuse box and run wires all around and behind the console?
I really hope i do not have to do anything that crazy, the only difference the sport seats have are the side bolsters. Any suggestions/thoughts?
Thanks in advance!
      08-15-2011, 03:42 PM   #91
woodpecka
woodpecka's Avatar
68
Drives: E91
Thanks in advance!
As you already had the power seat, the only thing you need to do is to jump the power from the heating wires to the bolster wires. (Positive and Negative)
All the info is in the topic.
If you see a module under the passenger seat, this mean the seat is heated.
      08-15-2011, 06:55 PM   #92
digitalfx
Alright so my car is a 2006 325xi - 4 door. So what you mean is, I have to connect PIN4 to PIN9 and PIN8 to PIN13. or pin 7 to 4, i am not sure what year the seat came from car, if that matters. I plan on doing all this work when it stops raining, connecticut is sucking right now, so hopefully before the end of week. I am just making sure I have everything and not screw something up. bmw already got a lot of money from me this month lol
i checked my connector and i have the small pin on pin7. so im assuming the seat was in a car after 3/2007. my car was produced 3/2006. I wonder if this is going to cause an issue, i have to take the seat out and check the connector that is attached to the car to see what wiring it has connected to the harness. hopefully i can get to that tomorrow. thankfully the bolsters are in a good position and the seat is comfortable, but the lumbar is deflated and not so much comfortable at the moment, defiantly want to get that going again. i checked and i do not have the heated seats . my original seats have them and ill prob retrofit those before the winter.
i really appreciate your help and this topic is defiantly a huge help.
      08-15-2011, 08:19 PM   #93
woodpecka
woodpecka's Avatar
68
Drives: E91
Normally you should be ok with PIN4 to PIN9 and PIN8 to PIN13. Anyway, look at your connector and diagrams before and you will see. The color codes are written in the diagrams.
Sorry, I can't tell you more as I don't see the items.
      08-17-2011, 02:05 PM   #94
archaicbark
archaicbark's Avatar
Drives: 2011 335d Sedan
Replacing seats.
Searched forever for this, and nothing but typical snide remarks. Hope this helps someone.
Must replace seat bolts when replacing seats in car, part number 07 14 7 146 686.
See this link: http://tis.spaghetticoder.org/s/view.pl?1/08/07/70
Seat bolt torque is 35Nm.
***"Carpet must not get between seat rails and floor pan in area of fastening points (grating noises). "
Hope this helps someone else.
      08-17-2011, 02:12 PM   #95
woodpecka
woodpecka's Avatar
68
Drives: E91
I saw a note to replace the nuts, not the bolts. This seem a little bit overkill. if the car hasn't been crashed.
      09-25-2011, 02:46 AM   #96
_pancho_
_pancho_'s Avatar
Sweden
16
Drives: modified F87 M2 Man -17
My car has non-heated, non electric adjustable standard seats (only cables on pin 14-19)
I have found a sportseat with heating and adjustable + memory.
I have:
1) put 12v + on pin 4 + 9
2) put ground on pin 8 + 13
The electric adjustment works for like 30 sec after I put the battery cables on.
The side adjustment always work.
Do I need to put CAN_L and CAN_H to get the electrical adjustment to work?
At the moment the priority is to get the adjustment to work.
Secondary is memory, and on third prio the seat heating (I don't even have the control buttons yet..)
Seems like the seat module blocks the adjustment in some way..?
regards Tobias
      09-25-2011, 06:37 AM   #97
woodpecka
woodpecka's Avatar
68
Drives: E91
I have:
regards Tobias
Yes we all had the same issue and adding the CAN will solve it.
      09-27-2011, 11:45 PM   #98
w00kiec00kie
Drives: '07 E90 328i
Can someone post a picture of where they've found the K_CAN bus wire(s) and possibly how they've wired it?
I am not sure where would be the easiest place to reach from the passenger seat. (The M3 seats I got seem to have pins 2 / 3 just like the driver side, so it looks like that also needs the K_CAN connection as well)
Thanks,
      09-28-2011, 04:38 PM   #99
woodpecka
woodpecka's Avatar
68
Drives: E91
The CAN Bus is everywhere in the car and I have used the radio harness.
      11-24-2011, 07:51 AM   #100
mjojom
Drives: e61
Hi guys,
I recently retrofitted my seats from half electric to comfort seats.
I got 3 errors on the dash, 2 of them are about head restraint pretensioners, old seats did not have them, so I had to run wires from drivers and passenger seats to B-pillar. the third error is restraint system, and it says "resistance too low".
I have used 16 amp wires instead of 5 amp, I am not sure if that could cause the difference.
there are two corners I cut:
first one is K_bus wire (#2 in yellow connector), I connected the wire to center console DSC switch instead running wire to the module behind the fuse box in glows compartment which is anyway connected to the DSC switch.
second shortcut, I run red/green wire (#3 in yellow connector) to the continuous 12V supply from seat supply wire (red 30 amps fuse). By the WDS it should go to relay in the boot connected to 5 amp fuse.
Relay supply continuous 12V too but only when the car is awake, when it goes to sleep mode it cut off.
now both seats actuators, lumbars and side bolsters and memory works fine, only I got 3 errors where one of them is in red.
can anybody help please?
you can see some pictures of driver seat connected on below link, just to see if I am missing something:
https://picasaweb.google.com/jozef.m...IDoluHLuLnYiQE
many thanks for help
      01-03-2012, 06:19 AM   #101
vomheimlin
vomheimlin's Avatar
Drives: 2006 BMW 325i SEDAN AUTO
If anyone has the information, I'd be interested in knowing what I need to do complete a retrofit for seat heaters in my car. It's a 2006 BMW 325i Sedan Automatic w/iDrive, and I appear to have non-sport powered leather seats with memory. I'm new here, but I think my car is also "pre-LCI" from what I gather from other posts here. If you can help me, please post your thoughts here or send me a PM.
      02-07-2012, 11:30 AM   #102
vintagevrs
17
Drives: E92 320d
Almost there
Hi all,
I have an E92 that had standard seats. Electric hieght/tilt adjustment only.
Recently picked up sports seats with memory/heat/inflatable bolsters/electric movement.
I cut the harness from the donor car so that I could see what was needed for the "new" seats.
Currently my seats new seats have everything (heat/movement/memory) working but the side bolsters are not working.
Is it possible this is a coding issue or is this more likely to be a problem with the way I have wired the harnesses??
I find it strange that it is the same for both seats
Any help is greatly appreciated as always
      02-07-2012, 04:03 PM   #103
dasammy
Drives: E92 320D
It is most likely an wiring issue.
The side bolsters just need +12V and Ground for the pump.
The side bolsters have nothing to do with coding.
Check your wiring. I guess your problem is easy to fix.
My E92 Coupé
      02-07-2012, 04:10 PM   #104
vintagevrs
17
Drives: E92 320d
Thanks for the quick reply, is it even possible that it is a coding issue?
      02-07-2012, 05:27 PM   #105
woodpecka
woodpecka's Avatar
68
Drives: E91
As you had electric seats before, no this is not a coding issue.
Have you jump the power / ground on the side bolster connectors?
      02-07-2012, 05:55 PM   #106
vintagevrs
17
Drives: E92 320d
No I didn't jump them, two fresh connections were used. It was installed by a car electronics specialist and he thought it might need coding.might just jump them tomorrow myself
      03-26-2012, 10:33 PM   #107
H20atn
Drives: 320d
I'm sorry to sound dim and im sure it's covered here but is there a straight forward wire swap I need to do to just get my side bolsters working after swapping from non power seats to power ones... My e90 is an 07 reg
Thank you Steve
      04-04-2012, 08:28 PM   #108
Ducati848R
Drives: 06 325i
Does anyone know how to reset the power to the seats? I purchased full power sport seats and put them in my 06' e90 which had non power non sport. The main power worked just fine on driver when installed and havent touched it for a month and have decided to take them out and sell separate from my car which is for sale. Now there is no power at all, I have checked all related fuses, unhooked battery and hooked back and unplugged seats. So if any knows please let me know how to reset. Thanks
      07-27-2012, 07:03 PM   #109
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
If I don't have idrive and don't want to remove the radio...what's the next best option for canbus wiring?
      07-31-2012, 06:11 PM   #110
Ph0zenstone
325
Passenger side done!! I was able tO locate canbus wires right behind the glove box which made the install a lot easier since I didn't have to pull out my dynavin.
