BMW M3 Forum (E90 E92)
  TireRack
      04-28-2011, 05:43 PM   #23
Daft
Daft's Avatar
384
Drives: 2021 M2C
Car: 2011 E92 ZCP
Wheels w/ Offsets: Stock ZCP (winter setup)
Spacers: Macht Shnell 15mm (F), 12mm (R)
Tires / Miles: Bridgestone Blizzak LM-60 - (F) 255/35/19, (R) 275/35/19; New Tires
Suspension: B&G springs
EDC Setting: Normal/Sport
Alignment: Don't know. I should have asked the shop!
Fender Modifications: (F) None (R) None
Rubbing?: (F) None (R) None
      05-03-2011, 08:58 AM   #24
shake&bake
OZ
Drives: 10' E92 M3
Car: 2010 E92
Wheels: OEM 220 - (F) 19x8.5 +29, (R) 19x9.5 +23
Spacers: (F) 15mm, (R) 12mm
New Offset: (F) +14, (R) 11mm
Tires / Miles: PS2's (F) 245/35/19, (R) 265/35/19
Suspension: Stock
EDC Settings: Normal/Sport
Alignment: Stock
Fender Modifications: (F) None. (R) None
Rubbing?: (F) Slight rubbing at full lock. (R) none.
'10 M3 E92 | Alpine White| DCT| BBS CH-R 20" & Eibach Springs| Dinan Stage 1|M.S. Key Hole Delete|Angel iBright V3.0| LED upgrades
Others:10' Landcruiser|09' Ducati 848|10' Tundra 5.7| 97' 993 Cab
      05-03-2011, 11:28 AM   #25
shake&bake
OZ
Drives: 10' E92 M3
Useful Thread
Your car looks great. Nice set-up. I have been looking for these wheels for a set of p40 for my car, and the information you provided is very useful. BTW, is that the OEM carbon fiber trunk spoiler?
Great thread.
Originally Posted by Daft View Post
Car: 2011 E92 ZCP
      05-03-2011, 11:19 PM   #26
11' AW M3
Drives: 11' ZCP E92 M3
I'll add mine. I'll post twice for both sets of wheels (summer/winter)
Car: 2011 E92 ZCP
Wheels w/ Offsets: HRE P40 - (F) 20x9 +22, (R) 20x10 +22
Spacers: None
Tires / Miles: Michelin PS2 - (F) 255/30/20, (R) 285/30/20; New Tires
ADDED 5mm spacers all around = slight rubbing on sharp low speed turns.
DAFT: when you added the 5mm spacers, where do you rub? in the front or rear?
2011 AW/FR Extended E92 M3... fully loaded
      05-06-2011, 11:26 AM   #27
PIMP "E"
PIMP "E"'s Avatar
Drives: AW 2011 M3
2011 M3  [0.00]
wow i cant believe all these 19" wheels are having rubbing issues....
MONEY IS THE SAIL TO MY BOAT
      05-06-2011, 06:52 PM   #28
slicer
slicer's Avatar
2740
Drives: 'E46 M3 Race Car, '23 X7
Don't be surprised. It has little to do with the diameter of the wheels. Rubbing is due to the overall diameter of the tires, width, and offset. The car doesn't know whether you have 18's, 19's or 20's. 18's will rub with the aggressive offsets and tire widths/diameters that some of us are running.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      05-06-2011, 08:38 PM   #29
Daft
Daft's Avatar
384
Drives: 2021 M2C
Great thread.
Yup it's the BMW cf performance spoiler.
Just in the front. I'm surprised that just a tiny half cm can cause rubbing issues. I may remove the front spacers if it starts to bug me lots.
      05-06-2011, 09:44 PM   #30
JJM335
Drives: 2008 E92 M3
2008 E92 M3  [0.00]
Car: 2008 E92 (my autocross setup)
Wheels: OEM 219 - (F) 18x8.5 +29, (R) 18x9.5 +23
Spacers: (F) 10mm, (R) 10mm
New Offset: (F) +19, (R) +13mm
Tires / Miles: Hankook RS3 (F) 265/35/18, (R) 285/35/18
Suspension: Dinan stage 1 w/ camber plates
Alignment: -2.0 deg camber all around
Rubbing?: (F) None so far (R) Outer tire edge on fender liner "nub"...none w/out spacers
      05-06-2011, 11:23 PM   #31
rbk1115
rbk1115's Avatar
Drives: Acuras & BMWs
Car: 2009 E90 M3
Wheels: OEM 220 - (F) 19x8.5 (R) 19x9.5
Spacers: (F) 15mm (R) 12mm
Tires: Michelin Pilot Sport PS2 - (F) 245/35/19 (R) 265/35/19
Suspension: OEM (NON-EDC)
Alignment: Factory Specifications
2009 BMW M3 Sedan
2013 BMW 535i M Sport Sedan
2014 Mazda3 i Touring Sedan
      05-07-2011, 11:56 PM   #32
Chowster
E60_to_E90
Chowster's Avatar
36
Drives: 2011 E90 M3
Great thread. With some very interesting positive rubbing results. I would consider mine also quite surprising.
Car: 2011.5 E90
Wheels w/ Offsets: OEM 220
Spacers: MS (F) 15mm; (R) 12mm
Tires / Miles: Pirelli P Zero OEM sizes 265/35/19 245/35/19, brand new
Suspension: Dinan Stage 1
EDC Setting: all
Alignment: Dinan stage 1 specs
Rubbing?: (F) No. (R) Yes, both sides, outside corner of tires rubbing the plastic nub on the wheel well liner mostly on bigger bumps at speeds over 40mph. Also over larger rounded speed bumps (not the small pointy ones). I have smoothed down the plastic significantly via my rubbing, and have also used a Dremel to smooth it further. I'm still rubbing, albeit not as much as immediately after the simultaneous suspension and spacer install.
2011.5 E90 Dinan M3, SS II, M-DCT, EDC, M Drive. 20" MORR VS8.2 wheels
Performance Mods: Dinan St.1 suspension, exhaust, intake; TTPs; BPM St.II, DCT, servo tunes
Cosmetic Mods: OEM CF splitters, mirrors, center console, spoiler; Arkym CF diffuser; LUX; tint
      07-20-2011, 07:28 PM   #33
persian54
persian54's Avatar
Drives: M760/G83M4
great thread
So from my understanding, 295/30/19 AD08 in the rear will rub 100%, even if one max's out the rear camber
No one here has run a 265/30/19 AD08 in the front? From my understanding it shouldn't rub... (even if your fron camber is only -1.1, with pins intact)
      07-20-2011, 07:31 PM   #34
persian54
persian54's Avatar
Drives: M760/G83M4
Car:2011 e93
Wheels w/ Offsets: TE37SLs - (F) 19x9.5 +22, (R) 19x10.5 +22
Spacers: None
Tires / Miles: Pirelli P Zero Trafeo Tires 265/35/19 285/35/19; 50 Track miles
Suspension: Stock
EDC Setting: ALL
Alignment: (F) -1.1 camber (R) -1.7 camber
Rubbing?: Front: 100%, on full lock, on half lock, over a pump... cracked my fender liner
Rear: yes, over a bump at 30mph, a dip at 30mph.
Unless going perfectly straight, it rubbed on my e93.
Strange as these cleared the E90M3 that I got it from (and they tracked too..)
      07-25-2011, 10:28 AM   #35
nchan50
Drives: 2009 JzB/FR e92 M3
Just got my tires changed this past weekend so adding my details. Unfortunately, I think I'm going to switch out my spacers b/c of the rubbing in the rear. May just switch the front to 12mm and get 5mm's for the rear.
Car: 2009 E92 M3
Wheels: OEM 220
Tires: Michelin Pilot Sport A/S+ (F) 255/35/19 (R) 275/35/19
Suspension: OEM
Alignment: Factory specs
Rubbing?: (F) Barely (R) 100% on full lock and sharp turns
      07-25-2011, 11:24 AM   #36
mpm3
mpm3's Avatar
Drives: 2007 M coupe
2007 BMW M coupe  [10.00]
2011 BMW M3  [0.00]
Car: 2011 E90
Wheels: OEM 219 - (F) 18x9.5 +23, (R) 18X9.5 ET 23
Spacers: (F) None, (R) 10mm
New Offset: (F) 23 et , (R) 13 et
Tires / Miles: BF goodwrench (F) 255/35/18, (R) 275/35/18
Suspension: Eibach
Alignment: Stock
Rubbing?: (F) none. (R) none.
going to have to give an update when my kw club sports come in ! !
      07-25-2011, 11:30 AM   #37
mpm3
mpm3's Avatar
2011 BMW M3  [0.00]
also had another set up
Car: 2011
Wheels: Volk te37- (F) 19x9.5 +22, (R) 19x10.5 +20
Spacers: (F) none, (R) 10mm
New Offset: (F) et 22 , (R) et 10
Tires / Miles: PS2's (F) 255/35/19, (R) 275/35/19
Suspension: Eibach
Alignment: Stock
Rubbing?: (F) Slight rubbing at full lock. (R) very slight rubbing over bumps and with passangers / without spacer no rubbing at all.
      07-25-2011, 11:32 AM   #38
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
08 e90 m3, stock supsension
vmr v710 19x9.5 et 22 all 4 corners
advan ad08 265/30/19
spacers none front 12mm rear
rubbing none
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      07-25-2011, 11:33 AM   #39
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
Car: 2009 E92
Wheels: APEX ARC-8 (F) 18x10 +25, (R) 18x10 +25
Spacers: None
Tires / Miles: Dunlop Direzza Star Spec (F) 275/35-18, (R) 275/35-18
Suspension: Dinan Stage 1 plus Dinan Camber plates
EDC Settings: All
Alignment: (F) -2 degrees camber (R) -1.7 degrees
Rubbing?: (F) None. (R) none.
M3 with new wheels and tires by dcstep, on Flickr
      08-09-2011, 08:45 AM   #40
aka_phox
aka_phox's Avatar
Drives: 2011 M3 Convertilble
bump
'11.5 SG E93/6MT/ALL BOXES CHECKED
BLACK GRILL/BLACK SIDE GILLS/15% TINT/PAINTED REFLECTORS/SPACERS/ANGEL iBRIGHTS/20'' VOSSEN CV3/VINYL WRAPPED SHADOW LINE TRIM/ETS-POWER TUNE/
///M-FLIGHT MEMBER
      08-09-2011, 10:44 AM   #41
mindless.spades
13
Drives: 2009 E92 M3
Car: 09 E92
Wheels w/ Offsets: HRE P40S - (F) 19x9.5 +23, (R) 19x10.5 +28
Spacers: None
Tires / Miles: Michelin Pilot Super Sports - (F) 265/30/19, (R) 295/30/19; New Tires
EDC Setting: Comfort/Normal/Sport
Alignment: Will post soon (1.5 Camber Rear)
Rubbing?: (F) None (R) Yes, only with 4 people in the car with EDC on Comfort/Normal
Notes: Originally, I had ET-23 all around. Rear PSS 295/30/19 would rub over every bump. PSS seems to run wider than stated.
      08-09-2011, 10:54 AM   #42
ben@tirerack
M3Post Supporting Vendor
87
Drives: 740i
I think I'm gonna sticky this. So many people post 'will I rub?' threads, this might help us build up a database.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions.
      08-09-2011, 11:50 AM   #43
fastrack
fastrack's Avatar
42
Drives: 11 MW e92 M3
2021 M2c  [0.00]
Originally Posted by persian54 View Post
great thread
Not true, mine don't rub.
2011 e92 M3
HRE P40 19X 9.5 +22 19X10.5 +22
265/30/19 295/30/19
H&R Springs
no other modifications, no rubbing at all
Mineral White + HRE + Brembo + Eisenmann + Challenge = Perfection
      08-09-2011, 12:16 PM   #44
roy@acuteperformance
roy@acuteperformance's Avatar
Drives: 2015 AW M4 6MT
Car: 2011 E92
Wheels w/ Offsets: OEM ZCP + Spacers = 19x9 +19 / 19x10 +25
Spacers: 12mm Front, No spacer in the rear
Tires / Miles: 245/35/19; 275/35/19 AD08
Suspension: H&R
EDC Setting: None
Alignment: -2 Front, -2 Rear
Rubbing?: No
m3post
