Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      05-29-2016, 05:32 PM   #1
RocketBoots
RocketBoots's Avatar
Drives: Horse Drawn Carriage
Reduce Hood Gap
I was doing my Sunday morning car wash, and wiping down the engine bay. I accidentally hit this little plastic hex bolt and kind of knocked it loose. As I was putting it back on, I realized it's used to adjust the amount of "gap" between the top of the bumper and the hood. You can tighten it down by hand. It seems to be a stop for how low the middle of the hood rests. I did about one turn, and the hood sits more flush with the bumper
Appreciate 4
      05-29-2016, 07:30 PM   #2
nineofspades
45
Drives: SSII F80 M3
Great find, thanks!
      05-29-2016, 08:28 PM   #3
///F80M3
///F80M3's Avatar
Drives: 16 AW M3
Thanks, I just noticed the gap yesterday. Will try later tonight.
2016 M3
Alpine White / Sakhir Orange
BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount)
      05-29-2016, 08:36 PM   #4
Dr. Who
Drives: Tardis
Excellent Find!
      05-30-2016, 06:51 AM   #5
aboulfad
aboulfad's Avatar
1593
Drives: 2015 M4 MG/SO
2015 BMW M4  [10.00]
I guess you missed reading the mega thread few months ago on that topic I posted many documents related to gaps and adjusting the bonnet in post #36 at http://f80.bimmerpost.com/forums/sho...php?p=19530510, there's more adjustments to the bonnet.
      05-30-2016, 01:47 PM   #6
RocketBoots
Oh man, totally missed that thread! It's a lot more comprehensive
      05-23-2021, 01:06 PM   #7
Frözpeed
Klappe zu, Affe tot
Frözpeed's Avatar
Drives: 2018 Frozen White M4 ZCP 6MT
2018 BMW M4  [10.00]
So I hate to dig up old threads, but I found this while searching for how to align the center of my CS hood (which sits too low relative to the front bumper), and noticed that my 2018 does not have this center hood stop. I have two on each side of the hood itself, but not the center one. As I looked through this thread, https://f80.bimmerpost.com/forums/sh....php?t=1774179 , I noticed that some have it and some don't. Looks like they removed it either 2017 or 2018?
I had wondered if I bought the part if it would work on mine, but it looks to me like the attachment points of the part won't work on mine.
Thoughts, anyone?
2018 Frozen Brilliant White Metallic ///M4 Competition 6MT
IG: frozen_white_m4
      05-25-2021, 12:58 AM   #8
RocketBoots
Thoughts, anyone?
I'd buy the part and give it a try; I'd imagine it's relatively cheap. Also, aftermarket hoods always seem be less than 100% perfect.
      05-25-2021, 01:10 PM   #9
Frözpeed
Klappe zu, Affe tot
Frözpeed's Avatar
2018 BMW M4  [10.00]
I am considering buying one just like you said, they are not terribly expensive.
In my case, however, the hood is OEM CS, so I should be able to get the fitment pretty perfect. Everything is good right now on mine except that the center is too low. Gaps are good everywhere, and the height at the corners of the hood by the headlights are fine. Some adjustment where this stop would be would likely eliminate my issue.
IG: frozen_white_m4
      05-25-2021, 03:02 PM   #10
coldsteelrain
driver
coldsteelrain's Avatar
Drives: G80 xdrive
I converted my OEM hood to a CS carbon hood a while back. The problem was that my 2017 M3 didn't come from factory with that plastic Hex nut or an opening for it. But it is partially precut. (See second picture)
What I did is just cut out the metal (follow the outline and cut right up to it).
Drop the plastic hex nut in it and do a bit of adjustment on the nut and now there is no more gap. It's flush.
I didn't realize until now that that's where that nut was supposed to go so thanks for this post
This can help the folks that don't have the opening for the nut but still have a gap on the hood where the center section is lower
Bellow you can see what the gap looks like and the opening where you would have to cut open the hole
(I couldn't find on realoem.com a hex nut that could fit in there without having to cut the hole)
Frözpeed144.50
      05-25-2021, 04:08 PM   #11
Frözpeed
Klappe zu, Affe tot
Frözpeed's Avatar
2018 BMW M4  [10.00]
Thanks for this! Now I know what I need to do and that it will work as I suspected.
Looks like I am going to have to do some cutting to make this work. Can you tell me what you used to cut out the hole?
IG: frozen_white_m4
      05-25-2021, 04:29 PM   #12
coldsteelrain
driver
Drives: G80 xdrive
Dewalt rotary saw with rotozip steel cutting bits (have a few in case one breaks)
I am sure you can use other options but that's what I had. Including drilling, test fitting hood it took me about 15min if you have everything ready
      08-28-2022, 04:21 PM   #13
mpower79
mpower79's Avatar
51
Drives: 2019 M4cs
number part
51767183752
Ajustador
Supersedes:
51767348121(01.11.2012 — 05.05.2014)
JAI///M3528.00
      02-27-2024, 09:36 AM   #14
Stronie
Stronie's Avatar
Drives: 2017 F80M3 Comp. 6MT
Dammit! I know I was missing a piece.
2017 Atlantis Metallic F80 | Silverstone Interior | 6MT | CF Mirror Covers | CF Front Splitters | CF M Diffusor | CF M-Performance Spoiler | RKP IND Side Skirt Extensions | IND Paint matched Reflectors | KW HAS Springs | Instagram: Atlantis_S55
f80post
