Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      01-18-2017, 10:28 AM   #1
Maltman
Maltman's Avatar
Germany
230
Drives: BMW M4
2014 BMW M4 F82  [0.00]
DIY Roof rack for M3/M4 with CF roof
BIMMERPOST
     Featured on BIMMERPOST.com
In this short DIY i want to show you, how to get a roof rack on your M3 / M4 with carbon fiber roof.
To install a roof rack on your BMW you basically need 4 attachment points. These attachment points are missing on the M3 F80 and M4 F82 with carbon fiber roof; but all M3/M4 have the necessary thread under the carbon fiber roof - inside the rear side panel - covered by a screw plug (13).
Disclaimer: I cannot take responsibility for any damage caused during installation or usage of roof racks. Also please forgive my medium english skills
Before we begin: make sure you want to do this! Its a painful moment when you drill a hole in your roof.
Step 1. Remove both roof mouldings, they´re just clipped.
Step 2. Now you can see the area, where the required mounts should be.
Step 3. Take a small drill bit (2 or 3 mm) and drill in the middle of the red marked area. A correct position is very helpful for step 4. In best case you drill the hole exactly centered above the screw plug head.
Step 4. Take a lip and spur drill bit to „mill“ a hole in your CF roof. Why a lip and spur drill bit? With the small hole from step 3, you have a perfect centering. Also you can „mill“ the CF without drilling to deep and harm the hidden screw plug connection surface.
Step 5. Now you can see the screw plug. Maybe you have to enlarge your drilled whole with a Dremel. You can now simply unscrew and remove the screw plug.
Step 6. Fill the hole with a bit of Sikaflex or other, sealing and securing material. Insert BMW star screw with internal thread (part number 07 14 7 153 767) and tighten it. Make sure, the screw lies completely on the side panel - there should be no cf between your screw and panel.
Step 7. Seal the star screw with Sikaflex or similar.
Et voila - you´re now able to use a roof rack!
As you can see in the last pic, i completely removed my roof lining. You don't need to do this - its just hours of work and doesn't help.
Appreciate 26
backagain345.00
Zermatt88.00
Jadar1752.50
SYT_Shadow11490.00
ando2002.00
aboulfad1592.50
njw58.00
pbar1400.00
Cooltones241.00
davem3fan185.50
Agent11br449.50
azn_fcuk176.50
IM2C2066.50
Jeffe199.50
FR00ZN24.50
Mikecom32149.50
JustChris17489.00
DCG783.00
      01-18-2017, 01:47 PM   #2
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
THANKS!!!! I nominate this for a feature!
Brake_Late1937.50
DCG783.00
      01-18-2017, 02:31 PM   #3
///Mongo
///Mongo's Avatar
Drives: 2016 M4 Coupe
I wonder why BMW didn't do this from the factory...
seis-speed2430.50
DCG783.00
      01-18-2017, 10:15 PM   #4
ktc
30
Drives: blue beast
2017 BMW M3  [0.00]
Any risk of cracking the CF when you're drilling?
      01-19-2017, 02:59 AM   #5
Maltman
Maltman's Avatar
Germany
230
Drives: BMW M4
I dont think so. Only risk of cracking is caused by force through the CF - look at Step 6
      01-19-2017, 07:46 AM   #6
firedown31
Drives: '16 AW M3
This. Awesome that this can be done, but wonder if long term stress on the roof can have an effect.
      01-19-2017, 08:04 AM   #7
Maltman
Maltman's Avatar
Germany
230
Drives: BMW M4
Remember - the E92 M3 with CF Roof had these attachment points. I asked some BMW engineers i know personally. None of them told my why BMW made this, but also none of them said its a risk. At the end of the day we won't have a 100% guarantee - but for me i don't see a risk. All forces go directly in the side panel.
      01-19-2017, 10:00 AM   #8
CRtoE92
CRtoE92's Avatar
Drives: 2020 Melbourne red
Id rather take my truck to haul something Drilling a hole onto CF roof is just way too painful to tolerate for me lol
But nice write up for those who DDs their M3/M4!
Appreciate 3
      01-19-2017, 10:01 AM   #9
M3 Adjuster
Albania
7908
Drives: 1M, X1 M Sport, E46 325ic
They did do it from the factory. As OP has shown, all the hardware is there on the chassis of their vehicles for decades.
In the case of the M cars with A CF roofskin
... BMW has to guarantee the integrity of the roof... for whatever the heck an owner does driving it for several years. There's no warranty for the roof once you do this to your car.
In truth.. as a manufacturer.. the roof needs to be secure indefinitely, not just 4 years and 50k (or less ). What happens if a 7 year old BMW M car starts getting stains in the alcantara headliner Why take the risk as the manufacturer? It's the same reason that lots of cars are delivered with a big wing that comes in the trunk.
Whether or not @Maltman experiences cracks in the CF or leaks will take time to tell but precision counts here. I would think all should be fine. Nice work.
      01-19-2017, 10:13 AM   #10
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
FEATURED! Thanks again for this tutorial Maltman I'm definitely doing this.
Maltman230.00
      01-19-2017, 10:19 AM   #11
bim2er
bim2er's Avatar
Drives: '18 Mineral Grey M2
Possibly becasuse....
Possibly because the point of a carbon fiber roof is to take weight off of the highest point of the car and not add significant weight above the height of the car.
For those that want the standard rack mount points, they could choose to forgo the carbon fiber roof.
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
Yeineken1300.50
      01-19-2017, 10:35 AM   #12
Powerbeast
Powerbeast's Avatar
Drives: F80 M3 RarriRot
Looks awesome!!!
      01-19-2017, 10:41 AM   #13
Serious
1M advocate
Serious's Avatar
Drives: 2018 S4. 2011 M3. 2012 S1000RR
I do aerospace composites for a living. With this kind of structure and how its bonded to the chassis you wouldn't see any performance decrease drilling a few holes, like a previous poster said the e92 m3 has these holes in the roof from the factory.
In all likelihood BMW eliminated the holes in the CFRP roof as a cost savings measure. Drilling holes in carbon panels can be a source of defects, scrapped parts, tooling cost, added machining time etc. Keep in mind they're making a lot more of these now then they did back in 2005/6 timeframe (development of e92).
Be careful drilling at home though, drilling carbon fiber is not the same as metals. The feeds/speeds required are much higher to reduce fiber breakout (drill bit snagging fibers). I would suggest drilling a pilot hole initially and progressively opening it up to size. Only use new drill bits. You also want to seal the holes after drilling, you don't moisture getting in there and compromising the matrix (resin). I would also make sure there isn't a possibility of allowing moisture ingression into the roof & cabin area.
That said I would probably feel comfortable doing this to my car if I owned the CF roof. Stupid BMW forces you to get the moonroof to have roof rack mounts.
2012 BMW S1000RR
2011 BMW M3
Appreciate 7
Zermatt88.00
cncmastr1590.00
x.shell6580.00
davem3fan185.50
VCP1390.00
      01-19-2017, 10:43 AM   #14
technik330
Drives: STi
Needs more ///M stripes.
I'm kidding.
Nice write up though, well done.
Technik 330 Past Projects:
'05 BMW 330Ci ZHP - Technik's ZHP *Sold*
'07 Subaru STI - *Sold*
'18 Subaru STi Type RA #350
'19 Honda Civic Type R #31191
      01-19-2017, 11:16 AM   #15
3M TAPE
3M TAPE's Avatar
350
Drives: M3
Didn't the E92 M3 had these features from factory? I can't remember.
      01-19-2017, 11:41 AM   #16
BEMR
BEMR's Avatar
Drives: 15 M4
Be a good place to put grandma (@family vacation)
Got It: F82 2015 M4 Alpine White / Silverstone
With integrity nothing else matters, without integrity nothing else matters.
      01-19-2017, 11:49 AM   #17
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
Great writeup!! I am so impressed OP! Good work!
Maltman230.00
      01-19-2017, 11:57 AM   #18
Maltman
Maltman's Avatar
Germany
230
Drives: BMW M4
I agree 100%. I guess BMW just saved some costs, they thought "its an M4, its not supposed to be used for ski holiday" - and thats the sad point. I used my E92M3 for ski holiday and i want to do the same with my M4.
Thats exactly what i suggest. Drill with 2mm a pilot hole, then with the help of a 15mm wood drill bit you can easily "carve" an exact hole to remove the screw plug.
      01-19-2017, 12:07 PM   #19
C_Treadwell
Boost
Drives: 2015 Alpine White M3
What splitter is on your F82? I love the unibody form rather than three separate pieces.
P.S. I'd be too concerned drilling into the carbon fiber would compromise the integrity of the roof under extreme stress. I really wish the engineers hadn't omitted this as a roof rack is very useful for skis, and bikes.
2015 M3 DCT | Dinan Stage 3 Intake, Exhaust, Anti-roll, Mid-pipe, links, Heat Exchanger, Pedals, Coil-overs | Vorsteiner 106 CG 19-10.5 | Yokohama AD08R 305/30ZR19 | Aspen White/Black | M Flat Bottom Steering Wheel, CF Spoiler, Diffuser, Splitter Mirrors and Black Kidney Grills
      01-19-2017, 12:25 PM   #20
PARTS@STBMW
PARTS@STBMW's Avatar
2702
Drives: BMW
Well done, came out great!
      01-19-2017, 01:10 PM   #21
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
It's a bumper replacement made by 3D Design. The splitter is integrated into the bumper. It costs some serious coin. I love it but I'm drooling over the 56 Nord roof box more.
      01-19-2017, 01:40 PM   #22
jwzimm
jwzimm's Avatar
Drives: '16 M3
Time for some 5-95
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!!
2011 e92 X-Drive Coupe - SOLD!!
f80post
