Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      07-18-2017, 05:37 PM   #1
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
▀▄ eas | DIY: LCI Tail Light Upgrade for F82 M4
The BMW M4 has been on the market since mid 2014 (2015 model year) and this year we get the LCI tails on the 2018 models. Our M4 LCI Taillight consists of OEM BMW parts and is an upgrade is a simple taillight swap that can be accomplished by the DIY type.
The release of the 2018 LCI (Life Cycle Impulse) introduced some minor improvements to the vehicle. On the exterior side, most noticeably with the taillights. This DIY will give a quick overview for those to update their lighting to update the rear of their 2015-2016 M4 Coupe to appear like the LCI models.
An LCI Upgrade from EAS consists of Inner/Outer taillamps, trunk lamps (4 total) and Plug and Play (PnP) harnesses.
History
EAS has been performing R&D on taillight retrofits for a number of years, leading back to the E46 M3 models. We were at the forefront of the E92 taillight swap back in early 2010, continuing onward with open Q&A sessions to fully explain the steps and show a bit behind the scenes on R&D:
http://www.m3post.com/forums/showthread.php?t=382162
http://www.e90post.com/forums/showthread.php?t=372215
http://f80.bimmerpost.com/forums/sho....php?t=1180839
Let's begin:
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
dkhm31881.50
      07-18-2017, 05:39 PM   #2
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Our LCI Taillight kit will include 4 OEM BMW taillights (inner/outer) and Left/Right harnesses. Coding is required once installation is completed.
Pre-installation
Kit contents
- Left LCI Outer Taillight
- Left LCI InnerTaillight
- Right LCI Outer Taillight
- Right LCI Inner Taillight
- Left/Right Drip Rails
- Wiring Harness Kit
- Detailed instructions
Tools required
- 3/8" Ratchet
- 10mm socket
- 12mm socket
- Phillips screwdriver
- Trim removal tool
Installation
1. Open Trunk, remove battery cover
2. Remove Drip Rails, outer taillight, unplug and set aside
3. Remove taillight. Use masking tape (optional) to protect paint surface
4. Remove both trunk support arm plastic covers, 2 clips hold each cover on
5. Remove plastic trunk felt liner screws and inner trunk release (glow-in-the-dark) handle
6. Set handle and felt liner aside
7. Unplug inner trunk tail lamp
8. Install new LCI inner Trunk Lamp
9. Reinstall new LCI outer Tail lamps, Drip Rails and bolt into place
10. Almost done! Verify alignment and repeat steps for other tail lamp
      07-18-2017, 05:40 PM   #3
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Wiring
12. Plug in Harness connectors to the inner trunk tail lamps as shown on the image below.
Orange Long Wire – DRIVER Side Trunk Tail lamp
Grey Long Wire – PASSENGER Side Trunk Tail lamp
Route wire alongside existing harness and secure neatly into place using zip ties, while routing down passenger side of trunk support arm into battery location.
IMPORTANT: Be sure to leave enough wire and check clearances for trunk opening/closing before securing into place.
13. Remove WHITE connector on REM module, located just above battery on passenger side
14. Remove housing from WHITE connector
15. Insert wire terminals from PnP harness connectors into the following locations. Connector will need to be separated in order to see numbers imprinted with wire location numbers
PIN13 empty socket location, insert Grey wire (Passenger Side) into this location
Orange Wire (Driver Side): PIN 5 empty socket location
16. Reinstall WHITE connector back into REM module (note orientation) and lock back into place. Reinstall Trunk liner, handle, support arm covers, screws and verify wire has enough slack to properly open/close trunk. Use zip ties to secure wires cleanly out of obstruction.
Reinstall battery box cover and close trunk.
      07-18-2017, 05:40 PM   #4
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Coding
Coding is necessary in order to activate inner tail lamp blinker/reverse lamps. Outer lamps will work normally without coding.
1. Add “HELC” (without quotes) to HO-WORT of Vehicle Order.
2. VO Code REM module. No other coding is necessary.
Note: If coding does not activate inner lamps, it may be possible your M4 is on a very early I-Level (typically on early model MY15) and needs to be updated. Most have already been updated at dealer at some point of service or have compatible i-level software.
Install completed. Enjoy your new LCI Taillamps!
      07-18-2017, 05:41 PM   #5
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Videos / Pictures
Thanks for reading, if you have any questions - please feel free to ask!
      07-18-2017, 07:13 PM   #6
shawnsheridan
General
shawnsheridan's Avatar
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
tom @ eas8224.00
      07-19-2017, 08:46 PM   #7
cigarsmoker
47
Drives: 2015 F82 MG
Pls PM the cost for F82.
BM3 OTS Stage II (Fall / Winter) / Paul Johnson Custom E85 tune (Spring / Summer)
      07-20-2017, 11:16 AM   #8
kevin @ eas
kevin @ eas's Avatar
Drives: 2015 BMW M4
PM sent
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
      07-23-2017, 04:13 AM   #9
super_fla
Drives: f36
can this set used for F36?? pm price please
      07-23-2017, 08:50 AM   #10
robertg
Drives: 2015 F80 M3
Why no coding for "bulb check" like in the M3's?
      07-23-2017, 11:35 AM   #11
LOW4LYF
LOW4LYF's Avatar
2163
Drives: E92 M3 & F85 X5M
Because the HO-Word manipulate the coding.
      07-23-2017, 02:19 PM   #12
aboulfad
aboulfad's Avatar
1593
Drives: 2015 M4 MG/SO
2015 BMW M4  [10.00]
These are really nice, but sure they are crazy expensive ...
      07-23-2017, 06:16 PM   #13
alpina-527
35
Drives: E92 M3
Not on the reverse lights. They still flicker after adding HELC
      07-23-2017, 07:17 PM   #14
LOW4LYF
LOW4LYF's Avatar
2163
On a F82 or F80?
      07-23-2017, 08:20 PM   #15
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
On a F82 or F80?
M3 LCI still uses bulbs for reverse, M4 uses SMD LEDs, you can see them in the video on Post #5.
No additional coding other than was is already listed in the DIY is required for M4
      07-24-2017, 01:38 AM   #16
alpina-527
35
Drives: E92 M3
On a F82 or F80?
Additional coding other than was is already listed in the DIY is not required for M4
Hence the additional fdl Led reverse light coding when using HELC on an F82.
      07-29-2017, 11:14 AM   #17
JB M4
107
Drives: BMW M4
Coding
PM sent
Coding
[IMG]
View post on imgur.com
[/IMG]
You will also need to fdl code reverse lights to Led to stop flickering.
I coded and everything is working except the inner blinkers...any ideas and what is the vo code REM module step
      07-29-2017, 11:15 AM   #18
JB M4
107
Drives: BMW M4
Coding
PM sent
Coding
[IMG]
[/IMG]
      07-30-2017, 05:53 PM   #19
alpina-527
35
Drives: E92 M3
Coding
[IMG]
[/IMG]
[IMG]https://c1.staticflickr.com/5/4210/3...079b5135_b.jpg[/IMG]
PM sent
Coding
[IMG]
[/IMG]
Once HELC is added to the vo, you need to code the R.E.M. Directly before doing the fdl coding
      08-04-2017, 12:07 AM   #20
styler69
62
Drives: M4
installed these tonite. not too hard. might be helpful to add to DIY more details on installation of inner lights - and need for a deep 8mm socket. i had no need for 12mm socket. a headlamp is probably near mandatory and if your a geezer like me some reading glasses. some extra felt liner rivets might be helpful for some - i had a rivet that wouldn't unscrew and had to destroy it to get it out. the wiring was easier than i thought it would be. it really is pnp. it took about 2h for me but i went slow and was learning as i went.
haven't coded yet but the outer lights were functional.
      08-04-2017, 10:03 AM   #21
jck624
jck624's Avatar
15
Drives: f83 fire orange
PM price for LCI tail lights. I have an f83. I'm assuming the lights are identical to f82?
      08-04-2017, 11:36 AM   #22
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Thanks for the feedback. Inner running lamp activation and flickering will be solved once coded.
eas, helc, lci, taillight, tails
f80post
