09-13-2020, 04:51 AM | #67 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
The answer to your question is that you need to use e-sys to update your REM to a software version that is 2016 or newer. When using e-sys, there is a function for editing your cars FA (vehicle order) so that you can add a special option code for LCI Tail lights that instructs the car to use the correct coding parameters when you code your modules. When you are in the FA editor, you expand the section titled 'HO-WORT', right-click into it and add the word 'HELC'. The is what the FA editor looks like, adding in the 'HELC' key word: Description of HELC in the files: The coding steps are laid out in detail in this thread here but again it requires that you already have the right version of e-sys set up and running: https://f30.bimmerpost.com/forums/sh....php?t=1174188 |
09-13-2020, 09:37 PM | #69 |
Arashikage
73
Rep 214
I just coded these with eSys. Really easy. Thank you very much for the help.
09-14-2020, 03:21 AM | #70 | |
Rep 6
I have everything set up software wise with E-Sys 3.33 which as far as I can find is the newest version out there right now. The screenshots you placed are very nice for us newbees Only thing that is unclear to me is your remark that the REM software version needs to be updated using E-Sys. Is this some kind of firmware that is included in any download I need to find? And perform installing this software package before coding the settings. Or is this 'update' you mention just changing the HELC setting that you are referring too. In case the former is the question, does this 2016> firmware for the REM module have a certain name, or version number and where can I obtain it? |
10-10-2020, 09:41 PM | #71 |
Rep 835
Just curious, did anyone with an f82 successfully code the lci tail lights using bimmercode?
F82 M4 AW
Ferrari 599 GTB Fiorano Jeep Wrangler Unlimited Previous BMW: E36 Reiger Custom Green vert E46 ///M3 Cabonblack vert E46 ///M3 AW vert E63 645ci AW Coupe E92 ///M3 AW E93 ///M3 SG Vert |
10-10-2020, 11:18 PM | #72 |
106
Rep 128
10-11-2020, 01:42 PM | #73 | |
Rep 835
F82 M4 AW
10-12-2020, 10:57 AM | #74 |
106
Rep 128
That would explain the silence.
Joking aside - I think the inner lights are the issue for coding with bimmercode 👍 Last edited by Daggers; 10-12-2020 at 11:14 AM.. |
10-13-2020, 11:27 PM | #75 |
Luxury at the redline :)
9105
Rep 7,563
Yes, Bimmercode can code the LCI taillights, however, you need to have a more recent version of software to illuminate the inner light, regardless of which method is used.
10-15-2020, 11:01 PM | #76 | |
Rep 835
Inner light signals are the issue, but I have heard it being done via expert mode.
F82 M4 AW
10-18-2020, 09:15 PM | #78 |
40
Rep 157
Did any of you guys have issues with your trunk/rear cam/inner taillights not working after the install? I haven't tried coding yet, but I figured this has to be a wiring issue if NOTHING on the trunk is working.
04-22-2021, 06:05 PM | #79 |
Rep 4,551
Drives: 2015 328d xDrive
Fortunately, it's much easier to do now. It's all possible in easy mode:
05-23-2021, 09:35 PM | #81 | |
Rep 443
i tried that on my 2015 F83 and didn't work, in fact one of member does coding tried and didn't work i used OEM harness with LCI tail light. any suggestion how can i tap the wiring? thanks! |
05-24-2021, 12:23 AM | #82 |
Rep 4,551
Using an aftermarket harness (EAS) vs the OEM method might work out better (so I hear)
05-24-2021, 12:31 PM | #83 |
8217
Rep 18,823
Drives: BMW
Define "didn't work". Even without coding, most of the lamps are still operational.
05-24-2021, 02:33 PM | #84 | ||
Rep 443
inner piece does NOT flash even after coding or active on bimmercode. |
05-24-2021, 02:35 PM | #85 |
8217
Rep 18,823
Drives: BMW
05-24-2021, 03:56 PM | #86 | ||
Rep 443
Thanks for the info! |
05-24-2021, 04:00 PM | #87 | |
8217
Rep 18,823
Drives: BMW
Now that you know what's needed, finding someone that can perform the task should be relatively easy.
05-24-2021, 04:44 PM | #88 | ||||
Rep 443
