Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      05-24-2021, 05:30 PM   #89
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
Originally Posted by jzhu625 View Post
Thanks for the info once again. I checked the conversation last time. Look like REM were updated and still not working
If your REM version is mid 2015 or newer (any older and you will need to update first), you will need to add the word "HELC" (without quotes) to the HO-WORT section of your VO in e-sys and then VO code the REM. Steps for doing that can be found here: https://f80.bimmerpost.com/forums/sh...24&postcount=4
      05-24-2021, 10:26 PM   #90
jzhu625
Drives: f83
thank you! time to hunt for a coder can do the update REM.
thanks once again!
      05-25-2021, 04:42 AM   #91
psyki
E36fiend
2014 X5  [0.00]
thanks once again!
No problem, I did the LCI blackline retrofit in my 2014 F32 with proper harness so it was plug and play except for the coding. My REM was too old and didn't understand the "HELC" code so I had to flash my REM (and a few other modules) to a newer version.
I chose a mid 2015 version of the psdz files deliberately because 2015 was the last year you could code a custom "triple blink" amount, after 2015 you're stuck with 3 no matter what. 2015 also still allowed you to retain the setting of turning on the surround view when you put the transmission into reverse. After 2015 it automatically switches to the backup camera.
There are guys on this forum that can do the coding remotely for you, for what I'm sure is a fair price.
      05-25-2021, 09:20 AM   #92
jzhu625
Drives: f83
PM!
      07-01-2021, 08:29 PM   #93
Tcgaylor
Drives: BMW M3 F80
NICE!!
Excellent info. Thanks for taking the time to let us know.
      09-08-2022, 11:40 AM   #94
Indvdl M
48
Drives: '11 335D, '15 F80
2022 Update
Performed the conversion today using the EAS harness. I tried the easy coding LCI option (not expert mode) in Bimmercodes and it did not function fully. I ended up using the coding provided in expert mode by the OP and all is well.
      09-21-2022, 11:50 PM   #95
Blocke
317
Drives: 2015 AY M3
Do you happen to know what REM you were running? I also have a 2015, but I’m 99% sure that it’s running the same software it left the factory with. I’ve been wanting to convert to LCI, but don’t want to mess with having all the software updated just to accommodate LCI coding.
      09-22-2022, 05:51 AM   #96
Indvdl M
48
Production date for my '15 is 08/14.
      02-10-2024, 08:15 AM   #97
bertocolon
bertocolon's Avatar
Drives: 2019 M4 Comp
Thanks 🙏🏽
f80post
