European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      04-05-2021, 09:56 AM   #23
Djdnav
227
Drives: F80 M3
I installed one of these last night without a hitch.
Thanks Tom!
///M3
      04-05-2021, 10:21 AM   #24
VChenz
181
Drives: 2015 M3 Base
Big thanks to Tom @ EAS for saving current and future f80 drivers a solid $1000 when out batteries decide to bite the dirt.
Tom is there a an even cheaper or lighter option without the built in jumper option?
tom @ eas8224.00
      04-05-2021, 01:57 PM   #25
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
You can go lighter, at the risk of losing CCAs for only shedding a couple of more lbs. I wouldn't recommend it on a street vehicle.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
EGbeater116.50
      04-05-2021, 03:20 PM   #26
pbelvis29
pbelvis29's Avatar
Drives: BMW M4
How much are the batteries for M4?
      04-05-2021, 03:22 PM   #27
N1rve
Racecar Driver
N1rve's Avatar
1289
Drives: BMW M4
2019 BMW M4  [9.63]
OEM is over $1000. This is like half that. You cannot go to Autozone or Costco and grab a battery.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension
      04-05-2021, 03:27 PM   #28
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Dealer is about ~$1800 on a replacement LiFePO4 battery, and rarely dealers will have any in stock.
      04-06-2021, 12:10 PM   #29
VChenz
181
2200 in Canada. If you can find one.
      04-09-2021, 10:17 AM   #30
bimmerboyE92
Drives: BMW
Tom, can you update with a track only battery option?
      04-09-2021, 12:33 PM   #31
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
You can run the ATX-30 (5.75lb), but will need a custom mounting solution to fit within an H8 footprint. Battery type/registration will need to be changed as well.
EGbeater116.50
      04-09-2021, 12:41 PM   #32
bimmerboyE92
Drives: BMW
Thanks!
tom @ eas8224.00
      05-03-2021, 09:55 AM   #33
FatHulk
FatHulk's Avatar
128
Drives: F82 M4 zcp, G05 x40i
Great post! When my battery needs replacement will be ordering one!
tom @ eas8224.00
      05-18-2021, 04:52 AM   #34
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
Can we re-use the original IBS cable when installing a new battery?
      05-18-2021, 10:52 AM   #35
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
No, we provide the needed cable.
      06-12-2021, 07:02 PM   #36
verruckt
108
Drives: F82 M4, G05 X5, Gen 2 Raptor
Question on the programming part.
In this section it shows "70 AH AGM"
In the next one it shows "70 AH"
Which one are we programming the car with when using this battery? The 70 AH AGM option or the 70 AH option? Also, if I check it after programming / registering it, does it show as "70 AH" or "70 AH AGM"?
Kind of confused so hope its just an error with the screenshots.
      06-14-2021, 12:07 PM   #37
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Choose 70Ah AGM.
      07-23-2021, 12:34 PM   #38
mashimarho
mashimarho's Avatar
2111
Drives: E92 M3 & F80 M3 & G82 M4
Edit: sorry it’s upside down. Posted it from my phone. Says: electrical power supply limited.
Just installed it. Everything is great and followed the write up with the same battery and setting. Now I get this error, anyone seen this or know a remedy? Currently On hold with EAS after talking with Tom, so figured I’d post.
Mashimarho.com /// Instagram /// Facebook /// Youtube /// sales@mashimarho.com /// (425) 582-7939
      07-23-2021, 12:37 PM   #39
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Has coding/registration been performed yet?
Edit: Just spoke on the phone a short while ago, you're missing the battery cable w/ IBS sensor.
      09-28-2021, 09:55 AM   #40
M5D
M5D's Avatar
303
Drives: 2016M4
Hi Tom: I have my 2016, M4 on a battery tender designed for lithium batteries. I bought the car a month ago and the battery has not been replaced. How can I figure out the health of my current battery? Thank you for your post and how do I go about getting a battery from you with the proper cable? Thank you again!
      09-28-2021, 12:08 PM   #41
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Are you experiencing any issues with your current battery?
      11-29-2021, 02:07 PM   #42
phoenx
Drives: E46 M3, F80 M3, Tacoma, GT4 RS
Just wanted to bump this and vouch for this battery! Saved some good money as opposed to going with the expensive OEM battery. Had my car serviced at the dealership recently as well and didn't have any issues! Been running this battery for about a month now.
tom @ eas8224.00
CruzM3284.00
      12-06-2021, 01:46 PM   #43
srwhitman
Drives: BMW M3 (2016)
I did this over the summer after a lot of frustration. I registered my battery with Carly. I see Tom didn't recommend that - I just said it was the same type as what was in the car already (Carly didn't give me an option). I assumed its close enough (70).
Is that going to be a problem?
I then realized 2 additional issues:
1. What if the battery does drain below the threshold and my restart remote doesn't work? I'm screwed - can't get into the car right? I ask this because where I ordered the Antigravity they only gave me one remote! I don't know if that was right - a friend got two. I have 2 keys so would ideally want a remote for each key.
2. I am getting an issue with Parking feature not working. I didn't even know this car had some sort of fancy parking thing and I could care less about it - other than that this warning message is causing a problem. When I put the car in reverse, it forces me to hit "ok" every single time to see the rear camera! I didn't know what was going on the first few times and if the wife or kids drive the car, they might forget and I really want this thing remedied. I can't imagine why replacing the battery causes this problem but this problem wasn't there before and now is and I did nothing other than install this battery. Thoughts?
      12-06-2021, 02:00 PM   #44
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
There are numerous reports of Carly not registering the battery properly (or not at all), which is why you should use Bimmercode.
You should get 2 FOBs with the battery. If something is draining the battery, you would be in the same situation as if you had the stock battery installed, that's not really a battery (Antigravity or OEM) issue - but a vehicle issue that needs to be looked at. You can still get into the cabin, pop the hood and jump power to open the trunk and press the REStart button on the battery itself to start the vehicle.
Not sure about your other issue, a battery swap doesn't cause these things to happen. Try using a different key to see if its related to specific options programmed to the driver profile stored on the key.
antigravity, battery, eas, lifepo4, lithium
f80post
