12-16-2021, 11:24 AM | #45 |
Rep 59
12-21-2021, 11:30 AM | #46 |
303
Rep 279
12-21-2021, 11:32 AM | #47 |
8223
Rep 18,823
Drives: BMW
I wouldn't worry about it unless you are having issues starting. Or any shop with proper equipment can perform a load test for you.
05-24-2022, 03:42 PM | #49 |
8223
Rep 18,823
Drives: BMW
HP has no effect on CCA. 60Ah would be fine, 80Ah would be better.
07-21-2022, 12:20 PM | #50 |
Rep 59
Looks like this battery weighs significantly less than oem for f8x. Is the capacity similar? Looks like I need a new battery as I have been getting some low voltage codes and the control unit opened the protection relay. Jump restarted and is still ok at the moment.
Can you point to the specific battery to order for m4 and current pricing? Thank you. |
07-21-2022, 04:35 PM | #51 | |
8223
Rep 18,823
Drives: BMW
Can't post links in this section, sending via PM.
07-22-2022, 09:32 AM | #52 | |
Rep 1,945
Have you guys checked this? |
07-22-2022, 06:54 PM | #53 |
8223
Rep 18,823
Drives: BMW
We use Autologic for coding, but there might be a way to change battery type in eSys. You'll need to contact the Bimmercode developers to issue a support ticket.
07-23-2022, 08:18 AM | #54 |
Rep 1,945
Have tried esys as well. It shows the AH but Ista registration shows it's not correct. Have you double checked your Autologic with ISTA?
10-24-2022, 01:46 PM | #55 | |
Rep 26
Drives: 2018 BMW M3
10-24-2022, 02:48 PM | #56 |
8223
Rep 18,823
Drives: BMW
If you're simply replacing a stock battery, battery type does not need to be changed - only registered.
F80_Moe1.50 |
10-25-2022, 08:56 AM | #59 |
Rep 3
10-25-2022, 12:48 PM | #60 |
8223
Rep 18,823
Drives: BMW
Got your email this morning, replied.
01-04-2023, 02:36 PM | #61 | |
Rep 6
Replacing OEM battery
or should I put it like the Antigravity one to 70AH AGM? Thanks |
01-04-2023, 02:40 PM | #62 |
8223
Rep 18,823
Drives: BMW
Are you installing an OEM battery or Antigravity?
01-04-2023, 03:07 PM | #64 |
8223
Rep 18,823
Drives: BMW
Shouldn't be using Bimmercode as this is for changing the battery type. Use Bimmerlink to register an exact replacement battery.
01-04-2023, 03:11 PM | #65 |
Rep 6
01-04-2023, 03:33 PM | #66 | |
8223
Rep 18,823
Drives: BMW
Best to email the app owner for support since you had an odd reading, as this thread is primarily for Antigravity swaps.
antigravity, battery, eas, lifepo4, lithium |
