Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      09-26-2023, 04:22 PM   #89
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Originally Posted by WitchDr View Post
Went through everything again and the problem is solved! Thanks.
Awesome, thanks for following up.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      10-05-2023, 08:48 AM   #90
massimo 1299
Drives: Bmw M3 F80 Competition
Bimmercode battery values
Hello guys,
I just signed up to this fantastic site and I apologize in advance if I don't post my question in the right part of the site.
Can any of you tell me what the original lithium battery values ​​for BMW M3 F80 Competition year 2018 are that you read when you connect Bimmercode? The values ​​I'm looking for are that of the original lithium battery that can be seen with Bimmercode connected.
Unfortunately I forgot to save the original values.
Thank you so much
Massimo
      10-05-2023, 12:34 PM   #91
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Originally Posted by massimo 1299 View Post
Hello guys,
Thank you so much
Massimo
Battery shows 60ah, but registered at 70ah:
      10-06-2023, 03:27 AM   #92
massimo 1299
Hello Thom,
Thank you very much for your quick answer.
Massimo
tom @ eas8216.50
      11-01-2023, 07:07 AM   #93
mikel2818
mikel2818's Avatar
28
Drives: 2017 M4
Sorry for the dumb questions, but for the coding section why are we selecting AGM? Why is there not a lithium battery option? Do AGM batteries have the same charging and discharging settings as the lithium ion batteries ?
Thanks in advance!
      11-01-2023, 01:08 PM   #94
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Thanks in advance!
AGM is the best option in this case as there is no Lithium selection in the available choices on coding software.
      01-21-2024, 11:24 AM   #95
ninekrpm
ninekrpm's Avatar
539
Drives: F80M3 (Track) / E92M3 (Street)
hey Tom...I never got to this, but want to add the battery. do you have the 40a in stock? I would like to come pick it up...
2015 M3 - GT4 replica
Ongoing build thread https://f80.bimmerpost.com/forums/sh....php?t=1802471
For Pics / Video's visit Instagram https://www.instagram.com/ninekrpm1/
      01-22-2024, 01:58 PM   #96
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
In stock, drop on by and pick one up.
      01-22-2024, 02:27 PM   #97
Akkord29
Drives: F80, G20, E46
Can I use a h7-40-rs in my f80 street car or would I need a 60ah?
      01-22-2024, 02:40 PM   #98
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
40ah is suitable for the track, but small for a daily.
I would recommend at least a 60ah. We're only talking about a ~3lb weight difference for peace of mind.
      02-04-2024, 08:13 PM   #99
ninekrpm
ninekrpm's Avatar
539
Programming and Registration
After installation is completed, the battery needs to be registered like OEM using AGM/LiFePO4 profiles either through ISTA, your favorite 3rd party device (Bimmercode/Bimmerlink), or BMW independent shop. For the H8-60-RS, choose 70Ah AGM setting while H8-80-RS will require the 80Ah AGM setting. This can be done at your local dealership or independent or as we'll describe shortly - at home using your iPhone.
IMPORTANT: Do not skip these steps or it can damage your battery long term. For the DIY user, you will need the following iOS apps and OBD reader:
Bimmerlink
https://www.bimmerlink.app
Bimmercode
https://bimmercode.app
Veepeak OBDCheck BLE OBD2 Bluetooth Scanner
https://www.amazon.com/Veepeak-OBDCh.../dp/B073XKQQQW
Bimmercode - Select vehicle and go into Front Electronic Module (FEM_01), select "Battery Type"
Bimmercode - Change battery type to "70 Ah AGM"
Bimmerlink - Select 12 V Battery
Bimmerlink - Select "Register New Battery"
Bimmerlink - Select "Same Capacity and Type"
Bimmerlink - Select "ok"
Bimmerlink - Battery registered successfully - you're done!
Job complete! Enjoy your new battery. If you have any questions, please ask in the thread or PM.
for coding, are both apps required in the sequence noted above, if not, I have bimmercode, what do you do after you "select the new battery type??
      02-05-2024, 01:28 PM   #100
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
What size Antigravity battery are you replacing your OEM with?
      02-05-2024, 02:41 PM   #101
ninekrpm
ninekrpm's Avatar
539
40
      02-05-2024, 02:57 PM   #102
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
40
PM incoming.
      03-12-2024, 12:01 PM   #103
bokiboki
Drives: F56 Mini Cooper JCW
Hi Tom@EAS - I have a BMW M 0.5 (2019 Mini Cooper JCW) with BMW B48 engine and factory AGM 80Ah battery. I'd like to order the AG-H7-40-RS from you - can you please PM me the price and can you please tell me what would you suggest me register it as? I have the Bimmerlink, so should I put 40Ah AGM or maybe 70Ah AGM? Thanks in advance.
      03-12-2024, 01:53 PM   #104
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
You have PM!
      04-23-2024, 12:10 PM   #105
JBravoM3
Drives: 2007 Alpine White M5
Antigravity for 2018 F80 M3
Hello Tom,
I had a ton of error codes come up on my F80 M3 and believe my battery to be on the way out. Can you PM me please on price for the correct replacement battery?
Thank you,
John
      04-23-2024, 01:35 PM   #106
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Originally Posted by JBravoM3 View Post
Hello Tom,
Thank you,
John
Sure thing, PM incoming.
antigravity, battery, eas, lifepo4, lithium
f80post
