TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      01-20-2022, 12:52 PM   #23
XRatedM
XRatedM's Avatar
Drives: 11' X5M - 19' VW GTI
Originally Posted by GregWX5 View Post
My lower pan on my ‘10 X5M is leaking pretty bad with evidence that my upper is too but was going to just do the lower to see how bad the leak really is. Anything special I need to know before removing and replacing the lower pan? Is it just the new gasket and bolts? What the torque on the bolts?
Refer to this thread;
Something Every X5M owner should check every 80-100k miles. https://f15.bimmerpost.com/forums/sh....php?t=1847303
IG @E70_XRatedM | YT: E70M Garage
      01-20-2022, 04:35 PM   #24
GregWX5
18
Drives: 2010 BMW X5 ///M
Wow! That's a very useful link! Thank you for sharing regarding the oil pan gasket and now will check my chain.
This also made me realize that the ISTA+ has all the repair manuals included. I previously purchased a pre-configured harddrive with the ISAT+/INPA to code a larger battery capacity/register and to code a new EMF module, but forgot about the manuals!
XRatedM136.50
      03-17-2024, 09:35 PM   #25
askjeeves
Drives: e92 m3/spece30
anyone still around that has diy'd the upper oil pan gasket? I am working on preparing a parts list. I wish ISTA would provide part numbers to make this easier, but getting by referencing realoem. Ista diagrams shows 27 bolts for the upper oil pan, but realoem only shows 26. Should bolts be reused with loctite, or better to just replace with new? Also, ISTA says to remove the oil pump, but from the little info I can find online, it seems that is not necessary? I know some of this will make more sense when doing the work, but trying to be prepared before hand.
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10
      03-20-2024, 12:33 PM   #26
JellyStyle
Builder of Special Cars
JellyStyle's Avatar
202
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
Have you looked at TIS to find out the instructions or is that your ISTA?
      03-20-2024, 08:40 PM   #27
askjeeves
Aren’t the service instructions in ISTA the same as would be found in TIS? I have gone through the instructions from ista in detail.
ED 6/29/10
xbimmers
