04-07-2020, 09:03 PM | #23 |
Rep 518
I got the plugs and ready to test. Mine is a little scary too because my wgdc goes to 100% at 19psi. Face shield and catchers vest time.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
04-08-2020, 11:37 AM | #24 | |
14
Rep 38
Unfortunately, I blew up the turbo inlet pipe last night at ~12 PSI. I'm guessing mine had more heat cycles making it brittle. I have a new one on order, but in the mean time, I'll try to get hooked up directly to the turbo to test up to 15 PSI. It'll probably take me a couple days to work through both items, but I'll report back when I know more. |
04-08-2020, 12:16 PM | #25 | |
Rep 7,611
The main reason the STFT would be off is a leak after the MAF when under boost - the DME has already metered that air and when it leaks out there is too much fuel for the amount of air that makes it into the engine so the fuel trims are trying to correct for that. I suppose to could be a O2 sensor or something on that side, but that wouldnt really be consistent with the issue appearing right after the IC+CP install. Dang, i didn't thing that would happen... I might be more careful of that in the future. Was it the accordion piece or the actual turbo inlet? The later is more difficult to replace, and you might want to just consider an upgrade while you are in there. |
Alpine-F80201.50 |
04-08-2020, 01:57 PM | #26 | |
14
Rep 38
It was a little exciting when it popped. Definitely be careful if you do any additional testing! I believe it was the actual turbo inlet because the whole thing is loose now. I was too frustrated last night to pull it out because removing those small CCV hose nuts were hard to reach. I ordered a pure turbo inlet last night - hopefully it comes quickly |
04-08-2020, 03:15 PM | #27 | |
Rep 7,611
I would say be careful with the inlet install as well, because you are introducing another variable. If you have a leak around the inlet (e.g., after the MAF but before the turbo) you can actually cause the opposite problem - letting IN unmetered air. That would have the opposite effect on STFT as leaking OUT unmetered air (as in from a boost leak). There have been some threads about potential gains using pure inlet on stock turbo application so maybe you will come out of this on top after everything is resolved. I forget exactly how that inlet is designed but it might make it easier to do the pressure tests as well. |
04-08-2020, 10:02 PM | #28 |
Rep 518
Thanks for all the help guys! I found most of my leaks but couldn't raise the pressure in my system over 14 psi because t bolt clamps sucks. I'm going to switch to worm clamps and raise it up to 25 psi.
Testing for boost leaks https://f10.5post.com/forums/showthread.php?t=1710112
04-09-2020, 10:46 AM | #29 | |
14
Rep 38
As a quick update - the turbo inlet pipe literally just popped straight out of the turbo housing (some good news). It broke off the plastic tab that holds the inlet pipe to the turbo and ripped off the CCV tube connection since it's bolted to the engine block (I think the tube itself is OK). I can post pictures if anyone is interested. One other thought on the STFT - is it worth throwing new plugs at it? Maybe it's not burning completely at higher RPMs? I'll get some stock tune logs once the new inlet pipe comes in. Thanks again for the help! |
04-09-2020, 12:23 PM | #30 | |
Rep 7,611
Your STFT was <1 right? That means it is pulling fuel. If you have incomplete combustion you will have unburned O2 in the exhaust. This will cause the AFR to read lean. STFT would then be positive (>1) because the DME would be trying to add fuel to compensate for what it thinks is a lean condition. So, i dont think that theory holds up. |
04-13-2020, 11:22 PM | #31 | |
14
Rep 38
That's right (STFT < 1). I also noticed that the AFR goes up at the same time the STFT goes down. That might also track with a boost leak if the AFR is based on the MAF sensor (i.e. MAF is showing more air than is making it to the engine) (I'm not sure, I'm still learning). The new pipe should be here tomorrow. Hopefully I'll have more info soon. |
04-14-2020, 08:48 PM | #32 | |
Rep 7,611
1. MAF reading tells DME how much air is coming in, it calculates required fuel. (If you have a boost leak after the MAF, there is going to be too much fuel because not all this air made it into the engine). 2. After combustion, the O2 sensor is used to determine how much O2 is still in the exhaust (calculates AFR). DME compares this AFR to target and adjusts STFT to either add fuel if too lean (STFT > 1) or pull fuel if rich (< 1). |
05-04-2020, 11:00 PM | #33 | |
14
Rep 38
After getting the inlet installed, I was able to flash back to the stock tune and grab a new log. I basically don't drive any more, so this is still on the same fuel from my very first post. The the boost control, timing, and STFT seem better overall (still not ideal from my uneducated perspective). Any other inputs? Car config: VRSF CP + IC, Dinan air intake 1st log (BM3 stage 1, 91 oct, boost leak at CP coupler): https://www.bootmod3.net/log?id=5e89...729b33bc694c05 2nd log (BM3 stage 1, 91 oct, fixed boost leak at CP coupler): https://www.bootmod3.net/log?id=5e8b...729b14ca1ecde9 3rd log (stock tune, Pure Turbo inlet): https://www.bootmod3.net/log?id=5eac...90c6392c2ea609 |
05-04-2020, 11:48 PM | #34 | |
Rep 7,611
In the 2nd log, the boost control actually looks pretty good. Timing looks even but only 6.5 deg seems low... maybe becuase you let off early. However STFT still very negative in the 20-25% range. No obvious reason why to me... if you had a huge boost leak letting out metered air i would think you would see it in boost control and WGDC, but i dont. The only other thing i noticed is that MAF seems pretty unsteady... I looked at my logs and its just a smooth curve. Some people have good luck cleaning their MAF, might be something worth trying. I forgot the exact cleaner used, but its very delicate, so make sure you read up on that if you are going to try that. Inaccurate MAF readings could cause the STFT to need to compensate if the actual amount of air going into the engine is much different than what was expected. Just a hypothesis since nothing else stands out to me. |
05-21-2020, 10:43 PM | #35 |
22
Rep 55
Drives: 2015 BMW 335i xDrive
Boost Leak Test
So after upgrading the the MHD stage 2+ map on my shakedown runs I was getting a really weird howling sound like letting the air our of balloon slowly while pulling the edges. I made a video of the noise and the tester I used to pressurize the system.
My tester is from an old 300zx TT that I used to have and thought it would work great for this application. I was a little small at only 3.125" OD so I added some chrome plating masking rubber that I happened to have around which worked great to seal up the inlet for the most part (see video end). I did not have to plug the pcv system or the outlet bung from the CP to the transmission breather line. The only line that leaked was the vacuum fitting from air box which I plugged with a 3/16 vacuum fitting that was laying around. I ended up using my tire inflator that locks onto the valve stem so I can keep the system pressurized while I check for the leak. Worked great as the system will bleed down once unplugged. This is a video that I took which shows the noise clearly and how just moving the clamp slightly changed the sound so I knew the leak was there. https://youtu.be/wzH9WGP-2cg So far I have only driven the car about 3 miles since fixing and still have not been WOT since flashing as I'm taking it slow and checking for these small issues. I plan to get a good 100 miles in the next day or two so I'll know if everything is working fine and I'll be creating some logs as well. Last edited by obeeone; 05-21-2020 at 10:48 PM.. |
05-21-2020, 11:08 PM | #36 | |
Rep 7,611
I also had mine blow out once or twice lol |
05-22-2020, 09:38 AM | #37 | |
22
Rep 55
Also, yeah it's quite the surprise when that tester blows out and reading back about dalderks inlet breaking I don't want to have to test too often. |
05-22-2020, 10:21 AM | #38 | |
Rep 7,611
05-22-2020, 01:13 PM | #39 |
22
Rep 55
Yeah, that's true, could potentially cause and issue blowing out seals so I'll probably disconnect those if I ever have to do this again.
05-25-2020, 04:39 AM | #40 |
1083
Rep 2,358
How fast should pressure drop to consider the system leak free?
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
05-25-2020, 02:50 PM | #41 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
If you pressure test to 20 PSI or more, it should take 30 seconds to a minute to leak down past the piston rings.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
harkes1083.00 |
06-08-2020, 11:19 PM | #42 | |
14
Rep 38
First off, thanks again thejeremyman9 - I've read lots of your posts on other threads which have helped me a lot along the way. From previous post: Car config: VRSF CP + IC, Dinan air intake + "92 octane gas (WA state)" 1st log (BM3 stage 1, 91 oct, boost leak at CP coupler): https://www.bootmod3.net/log?id=5e89...729b33bc694c05 2nd log (BM3 stage 1, 91 oct, fixed boost leak at CP coupler): https://www.bootmod3.net/log?id=5e8b...729b14ca1ecde9 3rd log (stock tune, Pure Turbo inlet): https://www.bootmod3.net/log?id=5eac...90c6392c2ea609 New info/logs: Cleaned MAF sensor - did some quick logs to check MAF sensor reading and it looked worse.... Decide to go back to the stock intake and filter. 4th log (stock tune, Pure Turbo inlet, stock airbox and panel filter): https://www.bootmod3.net/log?id=5ec9...90c60b01ec0350 Finally, a slight improvement in the STFT - only pulled ~11-12% fuel (so still not great). Didn't see much improvement in the MAF readings. Boost looks good and smallish timing correction. Decided to try a new MAF sensor. 5th log (stock tune, Pure Turbo inlet, stock airbox and panel filter, new MAF sensor): https://www.bootmod3.net/log?id=5ecd...0b4373874eeb82 A short log, but STFT only pulls ~6% fuel. I thought the MAF reading looked smoother (still kind of choppy). Timing is even across all the cylinders. 6th log (stage 1 ACN91, Pure Turbo inlet, stock airbox and panel filter, new MAF sensor): https://www.bootmod3.net/log?id=5edd...90c60722a9a16d STFT pulls 5% at one point, but closer to ~2-3% throughout . MAF readings the wavy boost characteristic is back (maybe it's a stage 1 thing? I don't see a lot of stage 1 logs), and I still get some timing corrections. I found another post by trialmountain having a similar octane issue in Washington State (same neighborhood)... How can they claim it's 92 octane if the 91 ACN is still pulling timing... Long story short, it appears that I've solved my STFT issue, and I don't think I have a boost leak any more (still not 100% - I can't bring myself to try the pressure test again). I'm not 100% satisfied with the boost characteristics (just seems weird), but that's probably a topic for a different thread (worth trying MHD?)... Thanks for the help, and let me know if you have other suggestions. Last edited by dalderks; 06-08-2020 at 11:25 PM.. |
06-08-2020, 11:39 PM | #43 | |
Rep 7,611
I looked at the ACN log and it does look good for the most part, but timing is so low, you are leaving a lot of power on the table. It would also be informative to see how boost control it on the stage 1 91 map compared to the ACN, all else being equal. Also, not sure if you followed some of the other threads recently but two other people with dinan air intake had oddly low and erratic MAF readings. I would keep the stock intake with a dry drop-in filter. |
06-09-2020, 12:01 AM | #44 | |
14
Rep 38
I haven't seen that - I'll have to do some searching. I did read about it on other intakes before purchasing the Dinan one (before looking into tuning) - I guess they weren't immune. Definitely got too excited one day and spent way too much money on a sound box... live and learn I guess. I'm looking at the afe pro dry s, but haven't pulled the trigger. |
