04-12-2010, 09:09 AM | #1 |
Rep 8,023
Autocar's first impressions of the RS5
What is it?
Not only is the RS5 is the latest Audi to wear the RS badge, but it looks every bit the modern-day version of the original Ur-Quattro. And thirty years on, the concept of a fast four-seat, two-door Audi has matured into something very serious indeed. Powering the RS5 is a new naturally aspirated 4.2-litre producing 444bhp mated to a seven speed dual-clutch gearbox, the first time a RS product has used such a system. The RS5 also has a revised version of the Audi’s four-wheel drive system, with a new centre differential and a new torque vectoring system (which brakes individual wheels), plus the option of a sport rear differential. Naturally our test car has this fitted, along with the optional ceramic front brake discs, sports exhaust and crucially, Audi’s Dynamic Ride Control. In Germany this is an option, but in the UK it will be standard. What’s it like? At this point I could tell you how welcoming and downright easy to drive the RS5 is in mundane everyday traffic. But let’s skip all that and get straight to the point where you’re sat in an RS5 looking at a deserted, arrow-straight piece of road. Because one thing Audi’s dual-clutch ’box will do that a conventional automatic won’t is full-on launch control. Select dynamic mode on the Drive Select system, switch the ESP off, stand on the brakes, floor the throttle, release the brakes. Cue a perfect standing start, with hardly any transmission shunt or wheelspin, just forward motion. Rest to 62mph takes 4.6sec, and after not much longer the RS5 will hit its limiter at 155mph (or 174mph, if you tick yet another option box). Okay, you could argue that it’s irrelevant, but this one exercise does illustrate the RS5’s approach to performance: accessible, repeatable, controlled and brutally effective. But also, in its own way, emotional. There are other 400bhp-plus coupés and saloons that are more involving, chiefly because they demand more of their driver to extract maximum performance. But the RS5 is in no way short on entertainment. How could it be with a V8 engine, one that mixes low-end warble with an 8500rpm redline? Left to its own devices, the gearbox uses both extremes of the engine’s range, but move the lever over to manual mode and the choice is yours. Apply full throttle from low revs in a high gear and there is no kickdown, only V8 bass. The advantage of Audi’s Drive Select system is that it gives the option to ‘mix and match’ the car’s settings rather sticking to the preset groupings. Deciding on the perfect combination could take a lifetime, but I settled on dynamic for engine and ’box (for the faster gearshifts and downchange blips), comfort for the steering (dynamic doesn’t offer any more feel, just weight) and dynamic for the sport differential (through faster corners it feels more like a rear-driver). And the suspension? Actually, left in automatic it does a pretty good job of balancing compliance with control, because – and here’s the surprise – the RS5 is a fast Audi that rides well. I’m going to throw in the old caveat that this is based on a German test, where the roads are super-smooth, but I did put the RS5 through a few potholes and it coped pretty well, even on optional 20in wheels. But perhaps this shouldn’t be such a surprise because the previous RS4, which used an earlier version of the hydraulically controlled Dynamic Ride Control, also rode well. In the RS5 the comfort setting offers the best bump absorption, but the trade-off is a fraction too much body roll if you really throw it at a corner. Switching to dynamic solves this but robs the RS5 of the suppleness it will need in the UK. However, automatic shuffles between the settings, subtly enough that you’ll hardly notice, for the best of both worlds. Is the RS5 a car you would drive with no destination in mind? Like almost every other Audi, it feels like a piece of heavy machinery, one with deep reserves of engineering capability, but it is also one of the rare Audis that also has a fluidity and delicacy to it. I’d stop short of saying it would be a car I would choose to take on a track day, but for a non-stop return trip from London to the top of Scotland, there are few cars I would be happier to be in. Partly that’s because of the beautifully finished cabin, and partly it’s because the RS5’s gearbox is so well rounded. But the real reason why the RS5 is so compelling is that when the roads offer entertainment, the RS5 entertains in spades. Should I buy one? If you want a super-coupe with outstanding all-round abilities then yes absolutely. For the RS5 is a car with an exceptional breadth of abilities and the type of car that gets better and better with every journey. Jamie Corstorphine |
04-12-2010, 09:38 AM | #2 |
Crack Addict
84
Rep 759
Interesting read, the RS5 seems like the jack of all trades but specializes in none. I'm sure it is a fun car, but from what I read, not worth the pricetag.
2009 - Titanium Silver - Steptronic - 135i - Nasty
04-12-2010, 10:22 AM | #3 | |
Rep 8,023
Everything you have read is pure speculation and opinion but based on no hard evidence, for edmunds' $104K figure to be correct then I doubt Audi would sell one, never mind the quota they intend to export so I doubt they are that stupid. In fact if you look at the percentage difference between the S5 and RS5 in the UK and then using the US S5, adding the same percentage difference you end up with an RS5 in the US at $73K. I hardly think Audi will premium the RS5 by another $30K do you. |
04-12-2010, 11:05 AM | #4 |
Crack Addict
84
Rep 759
Granted, even at 73k. That is some heavy coin for a car that really isnt particularly good at any one thing. That isn't a bad thing for some, as a matter of fact I bet that would be a fantastic GT or cruiser for road trips. But I think it is a different kind of animal than a track inspired car, which is what I am more attracted to. It is more of an 'all around' good car in my opinion, still a little pricey even at 73k. I would consider buying one if base started at 65k.
The engine + drivetrain does sound fantastic though.
04-12-2010, 11:17 AM | #5 | |
Rep 5,501
This impression means absolutely nothing. The only thing useful are the pictures of the car inside and out. I for one believe that this RS5 will beat the M3 in most tests, just because it's being released almost 3 years after the E9x M3. Also you do pay for a little bit of exclusivity and there won't be nearly the amount of RS5's on the road compared to M3's. It's a gorgeous car and depending on the pricing for Military car sales, i may be looking at my next ride. That Audi interior....
2007 E92 Montego Blue 335i
04-12-2010, 11:57 AM | #6 | |
Rep 1,756
It breaks my heart that this car comes only with the DSG tranny.
Originally Posted by corneredbeast
An engine from a Z06 Corvette. A differential from a Vespa. Damn Quote:
04-12-2010, 01:49 PM | #8 | |
Rep 12,445
I don't see how it "really isn't particularly good at any one thing".
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
04-12-2010, 02:19 PM | #9 | |
Rep 8,023
The question is, whether all these other areas where it might be superior but lose out in involvement is worth it to you. If the answer is no then there is few better cars than an M3 but for those seeking a worthy alternative then you could do a lot worse than an RS5. |
04-12-2010, 02:24 PM | #10 |
Rep 4,013
So at this point, it's a clearly all rounder. A really good one at that. What I want to know now is which aspects is is better than the M3 and if by comparison, as well as the C63, ISF and CTSV
04-12-2010, 02:26 PM | #11 | |
Rep 1,756
I cant wait to see the price...but being honest better bang for the buck elsewhere(and Im an Audi guy)....The rs4 was priced way too high...while the M3 was 30K cheaper(Im not an option guy). I have a certain feeling that they will not overprice it this time...the S4(well the a4 3.0T cough*) is 17K cheaper base than the outgoing B7 S4 which was starting at 70K. Let's see if they can sell this car for 80-85K
04-12-2010, 02:46 PM | #13 |
Rep 4,013
04-13-2010, 01:48 AM | #14 | |
Rep 3,288
04-13-2010, 02:35 AM | #15 |
Steve Forte Rio
149
Rep 2,393
04-13-2010, 06:06 AM | #16 | |
Rep 8,023
04-13-2010, 11:33 PM | #17 | |
Rep 1,305
they had to spend 18 weeks in training to learn all technical aspects of their full line and its competition. When they pass a two hour exam....they work from home 10hrs a day....4 days a week.....NICE GIG!!!
2009 Jet Black E92 M3, DCT, Nav, Novillo Leather, PDC, EDC, BBS CHR's 20", Yokohama Advan Sports Tires, Eiback Pro-Kit Springs, Dinan Pullies and Dinan Stage1 software, black grills, black side gills, alcantara shift and ebrake boot.
04-14-2010, 09:35 AM | #18 |
Crack Addict
84
Rep 759
I can gaurantee you this car will not handle as well as the M3, that is why I said it is not geared toward the streep/track crowd. I think it is more of a cruiser type GT because of its:
1. weight 2. suspension/ride Acceleration in a straight line is probably very good which is what I had mentioned earlier, but there is more to a car than straight line acceleration, we of all people should know on a BMW forum. Hence I stand by my word, that car will be good at a lot of things, but not shine in any one particular category which can be a good thing for some or a bad thing, depending on what type of driver you are. That is all.
04-14-2010, 09:40 AM | #19 | |
Crack Addict
84
Rep 759
Handling will suffer due to weight, but will be marginally improved because of AWD. Gas mileage will suck ass in this car. AWD V8. Im not trying to bash the car, this is just my opinion. I like this car a lot, I think I would own one no doubt, maybe in a couple years. It has a great exterior design and interior, but for THOSE PEOPLE that are attracted to track inspired cars, this car will not satisfy that niche, that is my point. It seems more like an aston martin type car, big, heavy, powerful, cruiser that is pretty good at everything. If you guys dont see it, then go test drive one and tell me it out handles or out accelerates an M3 or M5. If you prove me wrong, no harm done, this is my speculation and everyone is entitled to their own.
04-14-2010, 09:48 AM | #20 |
Rep 4,013
DBFIU, I see where ur coming from and I honestly think you might be right. If they could have cut say an additional 200-300lbs off the car, I'm certain it would be more "track worthy". Still tho, a great gt cruiser with awesome acceleration and handling is right for me
04-14-2010, 09:50 AM | #21 |
Rep 4,013
Tom Ford's Top Gear Blog on RS5 @ the Ascari Circuit
http://www.topgear.com/uk/car-news/n...ord-2010-04-13 |
04-14-2010, 10:02 AM | #22 | ||||
Rep 8,023
I would have to agree that on the track this car like the GTR will not sustain continuous lap at lap without either tyres or brakes over heating, unless the swap to ceramics and proper r-compound rubber is used. Maybe, and I am only thinking out loud here, but maybe it would be best to wait until proper track comparisons are conducted before writing this car off. Quote:
P.S. Just to answer the critics that the RS5 isn't a little bit better than the M3, here is a small paragraph for Tom Ford (Topgear) after driving the RS5 on the track. Quote:
