03-31-2024, 06:33 AM | #23 |
J
370
Rep 700
Drives: BMW 128i
Shifter in... But... Seems like it's leaning a little too far towards the passenger seat? I dunno. It shifts into and out of all the gears so we'll see what it looks like when the center console is all back together.
Special note to anyone doing this swap. There is a bracket for the back of the shifter carrier that is hidden. There is a second bracket further back in the tunnel. I think that's for the 135i shifter carrier because when I tried to use it I found it was way to far back. I dug around and noticed the same bracket further up but hidden under the insulation. I cut it away and boom, there it was. I installed the new bushing and was all set. See pic below. |
Brian_10.50 cerealwars79.50 |
04-06-2024, 07:19 PM | #25 |
J
370
Rep 700
Drives: BMW 128i
Yeah it is definitely not OEM fitment, but I've seen it used in this application. I don't love the lean but I haven't actually driven it yet so I'd like to get some miles in with it before I go in a different direction. I know the 330i e46 zhp shifter has been used too and I may try snagging one of those. Regardless I'm ordering a regular 128i shifter cup just in case.
04-10-2024, 04:08 PM | #27 | |
J
370
Rep 700
Drives: BMW 128i
Today I decided to attack the driveshaft bushing and it's torturing me. I'm hoping to do the water pump as well since that's leaking. Everything except for coding and wiring. Lol. I'll get to it. |
likhitkod6.50 |
04-10-2024, 09:03 PM | #28 | |
Rep 8
Luckily my drive shaft bushing was good but I wished I had a chance tackle more things under there while i had the chance too. |
Blau369.50 |
04-11-2024, 12:05 PM | #29 |
J
370
Rep 700
Drives: BMW 128i
Yeah man, I wish I took less time, but it's been cool to knock out an hour here and there since I've got kids and a job that requires quite a bit of my time (teacher). I'm supposed to be done by now but May will have to do.
Honestly, the hardest part so far has been the exhaust. The amount of burned hours nearly crushed me. |
04-12-2024, 04:19 PM | #31 |
J
370
Rep 700
Drives: BMW 128i
After many hours and tools, I finally removed the driveshaft bushing. I didn't know how long the old driveshaft sat at the bone yard so it seemed like a good idea to do it. What a monster.
This swap must go 1000x faster if you don't live in rust prone areas... Old driveshaft bushing vs new one for comparison. |
05-01-2024, 08:44 PM | #32 |
J
370
Rep 700
Drives: BMW 128i
I moved the football down the field... That's my way of saying I'm not there yet, but I'm getting closer.
Today I ran the clutch line to the pedals. Ran the clutch switch to the new ground. Plumbed the master cylinder. Make sure you run the clutch switch wiring through the clutch line grommet before you put the carpet back and reinstall your gas pedal... Next up is opening the appropriate modules to complete the wiring. Then: Coding Test run Reinstall all the stuff I had to take off... Super close. |
