04-11-2018, 03:07 PM | #1 |
Rep 3
Engine knock/rattle
Afters months of waiting for the snow to settle it was finally time to let it breathe. On the second day of driving I noticed this noise and knowing I've read a lot of people having issues with the rod bearings it made me really worried, but I don't want to draw any premature conclusions before checking with you.
Very apparent at around 1:20 in the video After starting it again today i found that the noise isn't as apparent when the engine is cold as when driven for half an hour, but still present. Car is a 2009 E92 m3 with around 40k miles. What are your thoughts? |
04-15-2018, 11:33 AM | #3 |
Rep 3
04-15-2018, 12:42 PM | #4 |
2639
Rep 2,145
Drives: 2011 E92 M3
Yes - warm engine and slowly rev up to 3K to 3.5K and then let it return to idle a few times.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
04-15-2018, 02:00 PM | #5 | |
Rep 829
I'm new to this motor and trying to determine what're the normal cold-start noises. My motor is dead smooth/quiet after the initial half second or so after a cold start. I get a quick metallic sound, sometimes, just after the motor fires.... lasts no more than half a second second. Then it's dead quiet there after. Sounds like timing chain or perhaps lifters. This seems normal to me as most motors are a bit noisy at startup since oil isn't flowing to the lifters, etc. My S54 makes a good amount of racket at start up and so just trying to understand what's "normal", and what's indicative of a problem. Sorry for thread jack but related. |
04-15-2018, 03:46 PM | #7 | |
2639
Rep 2,145
Drives: 2011 E92 M3
As for rod knock, it seems like 3K RPM ish is a good RPM range to hear it. Cheers,
Assimilator1595.50 |
04-15-2018, 04:48 PM | #8 | |
Rep 829
I've heard a few videos of the 3k rod knock - very distinct. |
04-16-2018, 06:11 AM | #9 |
Rep 3
Okay, so if I gather this correct it doesn't sound like a rod issue, given that the noise isn't irregular and is present on idle.
If it is the lifters as m3jala suggested, is this something to worry about? Only thing I can say for sure is that i know that the noise wasn't there before. It's at most apparent after the 0:50 mark in the video. |
04-16-2018, 09:56 AM | #10 |
Rep 1,568
It sounds like a ratchet, which seems to be very pronounced when you get around 3K. You can hear it at lower RPM's, but its good to get a sweeping range of RPM.
04-16-2018, 10:01 AM | #11 |
2374
Rep 2,368
Drives: G87 M2; E92M3 MT&DCT; M3 euro
I only hear lifters and injectors.
Pass me if you can.
RocketyMan230.50 |
03-31-2024, 10:41 AM | #13 | |
Rep 1,042
Drives: BMW M3 e92 08 & 330d e90 10
[edit] Only just seen the date of this video, lol.
You wouldn't hear the injectors on these (port injection aka indirect and low pressure). Quote:
Sounds like noisy tappets (lifters) to me too, if that was the first time it was run in months the oil has probably drained out of the lifters and there's trapped air in them. Once fully warmed up give it some sustained mid to highish revs and it should clear itself.
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. Last edited by Assimilator1; 03-31-2024 at 10:49 AM.. |
04-02-2024, 04:07 PM | #14 |
231
Rep 362
Drives: E53 X5, E83 X3, E93 M3
Agreed. I hear the small clickity sound of all 8 injectors.
There does seem to be a bit lazy lifter I think I hear.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
