03-28-2008, 10:42 AM | #67 |
formerly izzo/comeback
289
Rep 3,382
btw saw this on m3 boards...
good reviews of the TR's bmw center caps are nice touch from his post "I bought TRMotorsport MT1 wheels 18x9.5 with 265/35/18 Michelin Pilot Sport Cup all around. I'm using 10mm RE spacers on the rears. wheel as per TireRack are 19lb and according to Michelin 22lb for the tires so 19+22=41, I got 43.20Lb so the rest might be for for the wheel weighs, air, scale error, etc"
BMW CCA # 418268
03-28-2008, 11:53 AM | #68 |
BMW ONE
15
Rep 630
Drives: 93 RX-7 R1, 135i
Mikeo can't wait to see pics when you get them on
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
03-28-2008, 04:55 PM | #69 |
Moderator
369
Rep 4,745
I'm headed out for the weekend guys. Talk to you on Monday.
Gill
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
03-28-2008, 08:38 PM | #71 |
Santa Fe Concorso
104
Rep 2,984
Bad news! The TRMotorsports 18x8.5 et44 wheel mounted with 245x35 'Stone RE760s do NOT make a happy fitment in the front of a 135i. The wheel will spin but there is less than 1mm clearance on the strut and steering arm. Spacer use is not a solution because the wheel and tire already extends outside the front fender.
It must be said that I did not test drive the car or have photos of the fitment. But from my experience, this was not a workable street wheel/tire setup. I did not drive the setup as I want to return it to TireRack un-used and go for a better, to be determined, setup in the front. I'm thinking 18x8 et40-45 and a 225 tire will be about it for street in the front. And, 'gasp', I may have to forego my prejudice against staggered setups and go with a 18x9 rear wheel as I can't bear to drop to 18x8 rear.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
03-29-2008, 02:38 PM | #72 |
Resident Cacodemon Expert
Rep 209
Thanks for the info mikeo. Sorry to hear that 18x8.5s won't fit in front. Looks like I too will probably be running 18x8s in front and 18x9s (or wider, if possible/necessary) in back.
BMS JB4 | BMS DCI | ETS intercooler | ETS charge pipe | HKS SSQV III | CP-E downpipes | BMWP exhaust | P3Cars vent gauge | LUX V3 angel eyes | Weisslicht smoked LED sidemarkers | Blackline LCI taillights | Slek Designs front lip | BMWP grills | Seibon M3 hood | iCarbon CSL trunk | iCarbon rear diffuser | BMWP suspension | Yokohama Advan Neova AD08s | Work Brombachers - FLOSS edition | H&R spacers | TC Kline studs | Project Kics R40 lugs |
03-29-2008, 08:35 PM | #73 |
104
Rep 2,626
Same here. At this point, I'm think 18x8/235 up front is about as extreme as you can go for a steet setup.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
03-30-2008, 11:50 PM | #74 | |
Rep 657
Here are some shots of the wheel on the e90: http://www.e90post.com/forums/showpo...7&postcount=59 I was hoping for Morr as well, but I figure it will be awhile before the 18's are available, and I wanted something now |
03-31-2008, 09:03 AM | #75 |
Moderator
369
Rep 4,745
If anyone is curious, here's an 18x8 and 18x9 ASA AR2 setup on my 135i. The rear tires are worn to the tread bars.
18x8 ET40 225/40/18 18x9 ET45 255/35/18 Fits and drives fine. Looks aggressive. Neither the front or the back sticks out of the fender but it is close. Some here are thinking about a 9" ET40 on the rear. This will give you a visual what it might look like pushed 5mm further out. Gill
03-31-2008, 11:56 AM | #76 |
104
Rep 2,626
Think you could fit 235s up front with that setup?
03-31-2008, 12:27 PM | #77 |
Moderator
369
Rep 4,745
Yes, but I'm not sure I'd like it. The 235/40 would be about .5" taller than the rear at 255/35 and I'm not convinced 265/35/18 would stay under the fender.
Gill
03-31-2008, 12:38 PM | #79 |
Moderator
369
Rep 4,745
Significantly less options but the size should work fine.
03-31-2008, 12:45 PM | #80 |
Moderator
369
Rep 4,745
Here's a side view.
04-10-2008, 08:50 PM | #83 | |
grebo guru
Rep 64
Do you have a link for that wheel offset/tire size calulator? I looked around the site credited with the app, but couldn't find anything using their search fn. This looks like a very useful app. Thanks, Shane (still no signature) |
04-10-2008, 09:13 PM | #84 | |
Santa Fe Concorso
104
Rep 2,984
04-10-2008, 09:23 PM | #86 |
grebo guru
Rep 64
Shane | def.con.one Racing |
04-10-2008, 10:06 PM | #87 | |
grebo guru
Rep 64
Are there any other suggestions out there or is it not possible to fit 255s on the front?
04-11-2008, 08:50 AM | #88 | |
Santa Fe Concorso
104
Rep 2,984
