11-20-2008, 11:01 AM | #1 |
891
Rep 2,556
Drives: Z4MC-X3-35i-525i, Corrado G60
What fuse is for the headlight washers?
I have a 2007 with headlight washers and want to disable them since the other day all it did was soak the entire hood of my clean car with fluid. I looked at the card in the the fuse panel and it showed symbols that looked like headlight washer and windshield washer with fuse number 13, 38 & 40. I pulled 13 which took away steering wheel controls. I now have 38 out and I'll see what that does. If someone knows for sure, please post the fuse number. I just hope that this fuse doesn't effect any other operations except the headlight washers.
11-21-2008, 07:58 AM | #2 |
Rep 15
Should be Fuse # 40 -- see chart below...
I'll be disabling mine as well just as soon as the dealer gets around to replacing my missing headlight washer cap (but that's another story). |
11-21-2008, 08:45 AM | #3 |
136
Rep 2,120
Drives: ///M Roadster + E92 335i 6MT
Easier alternative,
pop the hood, In the headlight washer tank you will see 2 pumps plugged in, The one closest the front bumper/radiator is the one for the headlight jets, Just unplug it, No error messages on the dash and its easier to get to than the fuse option, thats what I did on mine, Hate those little things
Imola Red Roadster |
11-21-2008, 02:08 PM | #4 | |
891
Rep 2,556
EricMCoupe- Thanks for the fuse chart, that should come in handy. I printed it out and will keep it in the closebox, I think it might even fit in there
11-25-2013, 12:11 PM | #6 |
My other car is on Mars
636
Rep 3,124
Water pressure raises the jets, just like pop-up lawn sprinklers.
Either unplugging the pump or removing the fuse will stop them.
Warning: May contain traces of nuts.
11-25-2013, 05:04 PM | #7 |
891
Rep 2,556
Holly 5 year old post resurrected.....
12-04-2013, 07:40 PM | #9 |
Ammar
73
Rep 406
ermmmmm, so I dont know why I did this.... but I put the fuse back in and now it wont spray the headlights anymore
E85 ///M Roadster -SapphireBlack/Imola - Garage Queen
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
12-04-2013, 07:47 PM | #10 |
636
Rep 3,124
It only sprays them every 5 or so times that you use the windshield washer.
Try some more. Then be sorry you did when they break
12-04-2013, 08:05 PM | #11 |
Ammar
73
Rep 406
Ill try some more, my regular windshield pump is screwed too... Ill try the fuse on that one too. But I feel like the problem is a little deeper than a little fuse.
12-04-2013, 11:14 PM | #12 |
636
Rep 3,124
Pumps going out is a common problem.
Usual symptom is a puddle under the car. Cheap and easy to replace.
12-04-2013, 11:40 PM | #13 | |
Ammar
73
Rep 406
