New 2009 2010 BMW Z4 - ZPOST
      04-05-2024, 03:46 PM   #1
ClevelandE89
Drives: 2009 Z4 (E89) 30i manual
Angry New Battery, New Starter, New Earth Strap..still no crank no start.
2009 Z4, 30i 6 speed manual E89
Put in a New Battery, New Starter, New Earth Strap.. then bypassed the Intelligent battery sensor from the negative terminal. Still no start. Bump starting the car works and it fires up and runs fine! (6 speed manual) As soon as I turn it off, no crank no start when hitting the start button.
When hitting the start button, I do hear a series of clicks in the dash, and maybe like a electrical motor turning or trying to turn? Seems the starter motor is not engaging. But again, new starter is in there, new battery. I am thinking it has to be a relay or electrical something above my pay-grade? Verified there is power to the starter. (Only thing I have not done is remove the new starter to do a bench test)
As a last ditch attempt I had tech come out and program a new key fob, which he did successfully. The new key fob will open the doors and trunk, and will light up the dash, like the original. All seems normal until you hit the start button and dreams crushed again.
Can it still be a rolling code or immobilizer issue. (I still do not fully understand those two things, nor how to go about diagnosing)
I ran a scan through the OBD...no codes! WTF?
Desperate here. Any ideas welcome. I am on a waiting list at the only shop in my area that I feel can solve this mystery. However they are very back logged and no telling when they can get me in. I have track days and rallys scheduled....feeling a strong sense of doom!
Happy to take video and post if anyone thinks they have any idea for trouble shooting.
Last edited by ClevelandE89; 04-05-2024 at 03:47 PM.. Reason: forgot the put model!
      04-05-2024, 04:19 PM   #2
B21
B21's Avatar
161
When / how did the problem start ?
      04-05-2024, 04:20 PM   #3
KennyP
KennyP's Avatar
Estonia
159
Drives: 2009 Havana E89 Z4 Sdrive35i
hmm...
one potential thing came to mind...
you know how you have to press the clutch pedal to start the car?
well clutch pedal has an electrical switch that tells the ecu that clutch has been pressed.. and then starts the car...
But if this switch has failed ecu never recognizes your clutch press, and car wont start.
Worth a look.. quite common for them to fail.
2009 35i DCT Havana brown with ivory white interior. Mods: Cobb stage 1+FMIC, Wagner EVO1 FMIC, BMS DCI, KW V3 suspension, M3 front control arms, Hardrace RTAB, Michelin Pilot Sport 4S tires.
      04-05-2024, 04:28 PM   #4
ClevelandE89
Originally Posted by KennyP View Post
hmm...
Ah!! I will check into the ASAP. Thanks for the tip. Did not know about that switch.
      04-05-2024, 04:32 PM   #5
ClevelandE89
Started about a month ago and I have been replacing things one at a time. It drove fine all day, then pulled it in the garage, and 10 minutes later went to start it....no go.
      04-05-2024, 04:33 PM   #6
KennyP
KennyP's Avatar
Estonia
159
https://www.youtube.com/watch?v=BaizFW7DHRQ
this video may help...
      04-05-2024, 04:45 PM   #7
KennyP
KennyP's Avatar
Estonia
159
https://www.fcpeuro.com/BMW-parts/Z4...&b=10&d=829&v=
Replacement parts can be seen here...
      04-05-2024, 04:49 PM   #8
KennyP
KennyP's Avatar
Estonia
159
Adding service manual pages aswell...
      04-05-2024, 04:51 PM   #9
ClevelandE89
Kenny! GREAT STUFF! This will be my next move. Thanks for the link to the vid and the part.
      04-05-2024, 05:07 PM   #10
ClevelandE89
ACES! Appreciate you.
zpost
