11-25-2013, 12:40 PM | #1190 | |
Rep 1,673
Also remember our fuel rating is not the same as yours. Our 93 is equal to your 97. IMHO ethanol is another factor is the fuel quality, running ethanol fuel is like running one step lower crappier gas. Running 89 no ethanol is about the same as running the 91 with ethanol. Running higher octane fuel retards timing so if crappy fuel is used it adds timing and increases the percent of cycles that get to peak cylinder pressure before tdc You cant look at a set of rod bearings and say that detonation is bad unless you see the rest of parts. I explained this with the pictures of the back of the shells and the pinbores.
Electronics Junkie, Engine Builder.
11-25-2013, 01:03 PM | #1191 | |
Rep 4,381
Its interesting that if you search the M5board S85 forum using the keyword "pinging" you get a surprising number of hits, especially considering the engine had the first generation ionic current antiknock system. As best as I can tell the Vanos and slipping SMG clutch were cited as the fix most likely to resolve the issue. Explains why BMW invested so much in revising the Vanos and antiknock for the S65. Last edited by SenorFunkyPants; 11-25-2013 at 01:09 PM.. |
11-25-2013, 01:24 PM | #1192 | |
Rep 1,673
11-25-2013, 01:29 PM | #1193 | |
Rep 413
The design of the VANOS HP pressure pump requires a backlash setting of .06-.08mm on the helical drive gears to optimize noise vs. wear and IMO results in a lot of the S85 "sounds like a diesel" effect on idle. I always believed the high pressure system (120 bar) of the S85 was unnecessary, but according to BMW literature, was necessary for the high number of actuators and valves of the S85. Clearly, with a 0% reduction in the number of actuators and a 20% reduction in the number of cam-to-valve interactions, it wasn't necessary. That pump has to be nearly equivalent in parasitic drag to a supercharger with little of the benefits of the latter. I think the M5 design team as whole suffered a but of the USS Enterprise (CVN type, not starship) syndrome when designing it. Much as they felt 8 reactors would be "necessary", ///M felt we needed 4 oil pumps on the pan with 2 controlled by a lateral accelerometer. INPA allows near-real-time monitoring of combustion quality along with timing information and injector pulse-widths. Doesn't seem like it would be too hard to test that theory with someone willing to run various grades of fuel. Don't look at me...I don't even have time to put the front axle back under mine right now. |
11-25-2013, 01:56 PM | #1194 | |
Rep 7,326
How do you explain the S54 bearing wear being identical in pattern to the S65 and S85 bearing wear, and the fact that it has occurred in the UK along with using a completely different type of knock sensor? Sounds to me like your theory is a red herring. |
11-25-2013, 02:10 PM | #1195 | |
Rep 4,381
"This pre detonation lots of people are getting may well be down to the VANOS not moving fast enough. Predominantly people complain about this at low rpm and sudden heavy load application. The VANOS tries to move the cams quite a bit at low rpm. If the VANOS does not move fast enough for what ever reason (low oil pressure, weak solenoids) etc then the ignition target will be too high. The DME can only retard so much timing. If the valves are in the wrong position at any given time the timing will be too high and the system will not be able to retard fast enough. If you are getting pinging then we would recommend getting a VANOS test done. Keep the oil clean and topped up also." After that I came across at least one post where a vanos repair fixed the issue. |
11-25-2013, 02:11 PM | #1196 |
Rep 4,381
11-25-2013, 02:13 PM | #1197 |
Rep 4,381
11-25-2013, 02:17 PM | #1198 | |
Rep 1,947
I hope you guy's a little more experienced than Rocco from Angel's Tuning Group. |
11-25-2013, 02:23 PM | #1199 |
Rep 1,673
That will come in the next segment when I post specs of the new bearing fitment, along with a few older ones
11-25-2013, 02:27 PM | #1200 |
Rep 1,947
Didn't that car have an NA stroker motor for about 22k of the 24k miles? How did it get turned into 24k supercharged miles? And now it supposedly ran with 0.0008" less cleaerance than standard, which means it was running with about 0.0004" clearance. Wow!
11-25-2013, 02:30 PM | #1201 | |
Rep 413
There is a VANOS performance test in ISTA (DIS as well probably) which measures "spread too great" and "spread too small" which are stroke time tests for the individual actuators. These can be out of spec also be gumming/fouling of the actuators or degraded solenoid performance. Typically they will manifest themselves as VANOS bank control errors when the "ordered" value deviates by x amount from the "actual" value for more than y amount of time. |
11-25-2013, 03:06 PM | #1202 | ||
Rep 311
Can you also explain this 'slight mistruth' which was written by you about your own car that you appear to be falsifying data on. Or perhaps you were mistaken on thinking 9,000 supercharged miles were in fact only 2,000. Perhaps it was the Texas 7,000 mile This quote is taken direct from your build blog on M5post that you wrote in answer to a question from Pea Quote: Originally Posted by pea Impressive work Robert,how many miles did it take to cause the damage on the rods, perhaps i should check mine. Quote:
11-25-2013, 03:55 PM | #1203 | |
274
Rep 2,665
Drives: Goggomobil
I was not aware of a SB and my only understanding was the change of oil was communicated through a web page. It was not scare mongering, but based on the information I had at hand. As far as I know, there hasn't been a SB on oil change released in Asia Pacific or Europe.
F86 X6///
11-25-2013, 08:55 PM | #1204 | |
Rep 1,947
I stopped by the dealer today to see if I could get the official S65 bearing clearance specs and a list of LL01 oils. These specs don't appear in the official 2008 TIS DVD. The shop forman looked it up and said they still don't exist in TIS. I also asked about switching to LL01. He said their service center will use either LL01 or TWS10W60 on the S65 depending on the customer preference. I asked for the latest list of LL01 approved oils, and got 12 pages of something else. Oh well. I didn't ask him about LL01 and warranty because I didn't think of it. I also didn't ask the foreman about an SIB for LL01 oils. But the foreman did casually mentioned they've recently rebuilt four S65's and had to change the rod bearings but he didn't say anything more about it than that. Not much info to go on. |
11-25-2013, 09:07 PM | #1205 | |
Rep 1,673
It is pretty much a dang mess.
11-25-2013, 09:11 PM | #1206 | |
Rep 1,673
Once again what a dang mess.
11-25-2013, 10:14 PM | #1207 | |
Rep 264
11-26-2013, 12:49 AM | #1208 | |
Rep 1,947
11-26-2013, 12:54 AM | #1209 |
Rep 1,947
Detonation vs. Bearing Wear: Could this be the cause?
By Kawasaki00 Reformatted here, posted on opening page Regular Guy sent me a complete set of rods bearings and pistons to document out of a STOCK engine. The purpose of this post is to address the detonation. What was found is that there is no significant detonation leading to bearing wear on this engine. Not saying some engines may not have it but this engine does not. Examples of bearing wear due to detonation: The first two pictures are reference from another type of engine that has too much timing and detonation. The shiny spots on the rod and silver specs on the back of the bearings are what happens to a rod bearing when it is moving around in the rod under load. The bearing actually lifts off the rod, oil gets behind it and then when it is slammed back down again this is what causes the silver specs from fretting. Comparing to this motor: You can see the picture of the complete set of rods that the oil stain has not penetrated the back side of the bearing and discolored the rod. This means that at no time has the rod bearing deformed to the point that is lifts out of the rod itself. The back of the rod bearing also shows the same thing, there is also no fretting on the back of the bearing. Where does detonation show? The first place that detonation will show up is in the pin bore of the piston and the bushing of the rod. There is no evidence of heat in the pin bores nor rainbow effect in the bushings. What I have circled on the rod pinbore is the area where when the engine is detonating it will beat the brass out the side like mushing the filling out of a doughnut. There is nothing to show this engine has been detonating to the point that is would cause any type of rod bearing wear. Do the piston tops show detonation? As far as the piston tops, well they have alot of build up. This can be from one of two things, too much blowby due to loose rings or on a street engine from the emission system dumping oil back into the intake side. Without having the entire engine to look at it is hard to say. I have noticed in the past that certain oils also do this. I wont place judjment on that as that will certainly erupt a brand war on here. The second ring shows very good seal as it is only worn about 1/4 of the ring. When there is poor sealing that second ring will wear all the way across the face. Conclusions: In conclusion there is no detonation in this engine. Failure analysis and teardown documentation is something we do regularly. The findings are conclusive with other people and they are what they are to put it into a nutshell. In the next couple days i will post the specs from the older rod bearings and will also post the numbers from a fresh set of bearings that are fit up ready to run. Last edited by regular guy; 11-26-2013 at 01:00 AM.. |
11-26-2013, 02:42 AM | #1210 | ||
Rep 311
Anyway just in case you carry on accusing me of falsifying figures, I've quoted your sizes which you wrote. That's a maximum journal size of 52.011mm. And you have the nerve to accuse BMW of getting cranks wrong. (BMW grind to 51.981mm) Last edited by Yellow Snow; 11-26-2013 at 02:58 AM.. |
