04-07-2020, 11:01 PM | #1 |
Rep 68
Radio change for BT
Hey guys, hope everyone's doing well under the circumstances. I have a 2011 128i (09/10 production) with combox and usb/aux both factory installed. I have a BMW professional radio (has sirius XM sticker on it) and I've installed the BT module and managed to get BT phone showing on the radio (still need to install a mic and do the wiring for it).
I've been playing around with NCSexpert to try to get BT streaming for music going without much luck. I then found out that apparently I can't BT stream and I'm not exactly sure why. From what I see on my radio, the radio itself doesn't appear to have BT since I don't see any BT logo or details. I have some questions that I would appreciate some help with: 1) Will replacing my radio with a radio that has BT help solve this problem? I found this as an example https://www.ebay.com/itm/BMW-1-3-Ser...-/274072412450 2) What do I need to be mindful off in replacing my radio? 3) What will it take to get the new radio working on my car? Thank you Last edited by unk045; 04-07-2020 at 11:24 PM.. |
04-12-2020, 05:30 PM | #2 | |
Rep 55
04-14-2020, 11:34 PM | #3 | |
Rep 68
I'm not going to say 100% guarantee that I did my NCSexpert coding right, but I'm fairly certain. Short of something off with the coding, I'm pretty certain at this point the issue is with my radio itself not actually having BT to enable BT streaming. Isn't your media device connecting with your radio after all? Hence, I would assume BT needs to built into the radio. But then again I can't explain why a separate BT antenna that connects to your combox is needed for BT phone. I'm assuming they serve separate BT functions/purposes which would make sense since your 'combox' is working as your 'communication box'...the same box that allows SOS, data, etc. I'd appreciate further insight. |
04-17-2020, 09:12 PM | #4 | |
Rep 55
So im looking back at my note from when I did my retrofit. I did BT Phone and then i did the streaming. I installed a CIC from a professional radio, and I had to edit the trace file from the CIC to tell the combox that BT streaming and BT Phone were on. Once you edit the TRC file you write it back to the radio which should turn on the features. The Radio you have is the early style without BT phone, but thats fine since the combox will control that as well. Once you install the mic and do the wiring behind the glovebox itll work. I was also trying to do some more searching for you. But i thought BT streaming was only for CIC units. But i could be wrong. That might be the later style radio like you first posted. |
04-17-2020, 10:15 PM | #5 | |
Rep 68
Except that there are no BT markings on the radio sticker. My radio sticker is shown above. |
04-29-2020, 11:00 PM | #6 |
Rep 68
Bump...any insight here would be appreciated. Been working on this for some time now and I know I'm close.
The only question is should I go for a radio swap similar to this which already has BT to enable BT audio streaming https://www.ebay.com/itm/BMW-1-3-Ser...-/274072412450 |
