03-13-2024, 03:53 PM | #133 | |
Rep 417
You were a huge help, WhiteFox! It's sometimes a challenge to be an early adopter, as we were with this Bimmer Tech display adapter, but I have to say that it is easily the best mod I've done so far. OEM+++.
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
03-13-2024, 03:57 PM | #134 |
108
Rep 237
Indeed think we may have been their first customer in sometime as they took apart their own car which has the same mod to check a few things I had questions on as were not sure themselves. I’m doing the G series mirror with garage opener retrofit in two weeks and will post on this soon.
03-13-2024, 04:31 PM | #135 | |
Rep 417
03-15-2024, 01:39 PM | #136 |
Rep 26
Well, I'm glad you got it to work properly, although not feeling so well about the fact that I have the same screen as you and the bimmertech adaptor ready to go into my car.
I have NBT EVO_Y which I hope will make a difference and not require remote coding...... |
03-15-2024, 03:51 PM | #137 | |
Rep 417
But I will say that the map resolution is higher now than it probably should be. The map contains much more viewable data, so I get the impression that the map displays its data at 1920x720 while the other display content (menus, etc.) is larger, likely 1440x540. Makes me think that Bimmer Tech forced the map data to display at the native MGU resolution. I personally think it looks great.
03-19-2024, 12:20 AM | #138 |
Rep 26
I might be better off just getting an earlier version of the display and selling off the one I have. Was less than $200, less than the adapter from Bimmertech!
03-20-2024, 09:40 PM | #139 |
Rep 417
Suit yourself, but the MGU display is great if you like higher resolution output. It’s especially useful when using the navigation.
beefyman7.50 |
03-21-2024, 07:57 AM | #140 |
Rep 26
Appreciate your comment. I'll see what happens when I install the CID I have, and then go from there depending on how it works out. If I sell off the one I have and buy one known to work out-of-the-box I'll only be out a few $$ total, which I'm sure will be far less than an hour of Bimmertechs time.
Plus I have a shitty battery and no power access outside (street parking only) to connect a charger. (Which I also don't have!) |
03-21-2024, 08:00 AM | #141 |
444
Rep 2,049
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
My screen arrives today gonna install later on. I’ll report back. It’s xtrons
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
03-21-2024, 09:33 AM | #142 | |
Rep 417
beefyman7.50 |
03-23-2024, 03:37 PM | #143 |
Rep 26
Oh, thanks for the info, I thought it had to be ignition only. That should make a difference. I am waiting for a battery charger to be delivered. May as well have one, won't go to waste.
03-23-2024, 06:59 PM | #144 |
Rep 417
Which display did you end up buying? The 10.25” display makes a HUGE difference in the F8x because the BimmerTech adapter brings the display closer to the driver (about flush with the top of the trim).
jaylazy2020256.50 NORAGRETS444.00 |
03-23-2024, 09:42 PM | #145 |
444
Rep 2,049
Can we get some part numbers listed here for guys who got OEM BMW screens and installed them?
03-23-2024, 10:26 PM | #146 |
Rep 417
If you are interested in the final version of the MGU 10.25” display, it is part no. 65509826394. Its native resolution is 1920x720 so it will need special coding/flashing for the BMW maps to display properly.
03-24-2024, 05:49 AM | #147 |
Rep 26
I bought the same part number that you have, so will likely face the same coding requirements. I'm not sure I want to spend the $$ for an hour of Bimmertechs time, so might buy an earlier part, but am interested in the higher resolution also.
03-24-2024, 07:05 AM | #148 | |
444
Rep 2,049
Is the only difference between mgu and scaler the coding? Is part number 65508715339 gonna work?
03-24-2024, 07:06 AM | #149 |
444
Rep 2,049
I can’t believe that adapter costs $300 smh I bought one tho
03-24-2024, 07:07 AM | #150 | |
444
Rep 2,049
03-24-2024, 05:11 PM | #152 | |
Rep 417
And it’s apparently not coding that makes it work. It’s more involved than that. kubax86 has an idea of how BimmerTech did it.
04-02-2024, 01:13 PM | #154 |
444
Rep 2,049
There’s tons for sale on ebay
