*** Review - Quaife LSD on E92 335i ***
03-03-2010, 05:20 PM | #177 |
Rep 48
Just read the whole of this thread and decided an LSD is the mod I most want on my car! (after ditching the RFT's)
Think that an LSD will be much better than a remap as the power can then be used properly although the remap would probably be next on the to do list. Have started saving up, but sounds like my car will be a welded version so will take that little bit longer!
335i M-Sport Coupe Titanium Silver, Saddle Brown leather, Alufelgen alloys, M3 spoiler, Electric sunroof, Adaptive headlights, Pro Sat Nav, Bluetooth, Logic 7/DAB/USB, Heated seats, Sun protection glass, Climate windscreen, Electric sunblind, F&R PDC, Folding Mirrors... and an amazing soundtrack! |
03-03-2010, 06:48 PM | #178 | |
Evolve tuned...
9
Rep 291
03-04-2010, 08:55 AM | #179 |
Rep 8,972
Aside from the massive road traction improvements,
Having had the Quaife for 6 months, and having used it successfully to lose E36 / E46 M3's out of corners on a track day (when without it I was left floundering) I can vouch that standard 306bhp is quite a lot. God knows what it will be like with a map.... |
03-05-2010, 09:03 AM | #180 |
263
Rep 2,563
It's even better with a remap. Currently running 400+hp (tendency increasing lol) and cornering out of bends was always a time for christmas lights on the dashboard - that has changed now, although it's still not optimal due to the cold weather and my winter tires.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
03-05-2010, 11:23 AM | #181 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
sorry for sounding really stupid....but what is the difference between a quaiffe lsd and switching off the DSC completely? same outcome???
03-05-2010, 01:28 PM | #182 |
Evolve tuned...
9
Rep 291
A limited slip differential (LSD) or automatic torque biasing LSD as Quaife call it transfers engine power to the rear wheel with most traction. DSC cuts engine power and/or applies the brakes when one of the wheels looses traction. Not quite the same.
03-08-2010, 05:28 AM | #183 | |
Rep 8,972
Have a read - http://en.wikipedia.org/wiki/Limited_slip_differential |
03-08-2010, 01:12 PM | #184 | |
Rep 7,690
otherwise people like you and Tony or anyone else wouldn't spend £1500 on a quaiffe lsd when they can simply switch off the DSC by pressing a button for 5 seconds... I wanted to understand how the car reacts with an LSD v/s DSC off... what sort of differences etc?... Last edited by zltm089; 03-08-2010 at 01:15 PM.. Reason: to be clear |
03-08-2010, 01:18 PM | #185 |
Rep 7,690
guess I got a bit confused with the DSC off debate and was thinkin that the LSD was somewhat related to wheels spinning/ oversteer ....where DSC also comes into play with wheel spin and oversteer...
03-09-2010, 03:05 AM | #186 | |
Rep 8,972
DSC comes into play to PREVENT wheels spinning and oversteer from happening in the first place by REDUCING engine power output and BRAKING individual wheels as necessary, So turning if off will allow you to do whatever you wish (or don't wish) to happen. LSD alters the way the wheels will provide driving force to the road, it stops just one wheel spinning aimlessly and wasting all the energy (or DSC cutting in very easily) as a standard diff does and makes the power always split between BOTH wheels, with most power going to the wheel with MOST grip instead. So in simple terms, neither wheel will spin until so much power is being transfered that BOTH wheels start to spin, this is quite hard to do and allows you to get TWICE the power down before wheel spin occurs. This also helps with drifting etc for those that wish. But for mere mortals like me is just means much more power down before DSC needs to intervene. So the LSD just allows you to accelerate much more quicky with triggering the DSC. |
03-26-2010, 11:02 AM | #187 | |
General Nuisance in a Private Conveyance
77
Rep 1,907
Drives: like it's rented
On an open diff, which every non-M, 3-series possesses, power is equally distributed to both wheels....all the time! Never mind that one wheel would lose traction. When that happens and you push the accelerator, the wheel with no traction continues to spin, albeit, uncontrollably, while the other wheel with the same (torque) power hunkers on. Sensing this, the DSC applies the brakes to the wheel with traction to even out the power--essentially slowing down your car at the most inappropriate times--in order to regain control of the car. So, when you enter a corner or sweeping ramp and hit a wet spot or lift the inner rear wheel (thus, losing traction) with DSC on, the nanny controls brake the outer wheel and rather than accelerating through the ramp, you slow down to watch everyone else pass you by if you are tracking. When you turn off DSC, you now have the ability to spin out because it can't control the loss of traction to one wheel. The wheel with the grip now has the ability to induce oversteer and eventual loss of control if you don't know how to control oversteer (which every drifter relishes...and wants). When I make a sharp turn with my mechanical Quaife LSD, I can feel the diff shift most of the power to the outer wheel with traction, while minimizing the torque to the inner wheel, and I can accelerate harder out of the turn, rather than slowing down until both wheels regain equal traction. I also make a tighter turn, which allows me to explode through the turn if both rear tires maintain their grip...and this is with DSC on! No lights, no epilepsy-inducing strobes, just complete control. With LSD and DSC off in the wet, the ride is both exhilarating and stressful if you are new to the physics of vehicle dynamics. Now the vehicle behaves the way older cars did before the invention of nanny controls and threshold braking was part of every student driver's education. LSDs should also be touted as a mechanical safety feature, because they ensure complete predictability beyond the limits of adhesion. My ride with Quaife approaches M3 performance without the M3 price and expense. Call it .... M3 Lite .... hahaha ... because I don't plan to track, but I want the comfort of enhanced performance in smaller doses, knowing that I could outmaneuver an equally powerful, open-diff 3-series ... if I wanted....like an M3!
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570 |
03-26-2010, 09:33 PM | #188 | |
Rep 7,519
Drives: 2009 E90 335i MT
In the past eight days here in Ccolorado I've been driving in three snowstorms yet not seen the DSC light up once. Hard acceleration on the dry roads is exhilarating while feeling the LSD shift between the wheels. Best mod I've done, even over the ARBs and the brakes.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
04-27-2010, 03:06 AM | #189 | |
Supreme Allied Commander
3886
Rep 54,518
Drives: F80 M3
04-27-2010, 11:05 PM | #190 |
Rep 7,519
From a safety aspect, in my opinion, the application of an LSD is critical in modern driving with the speeds and lack of courtesy and/or attention from other drivers. When trying to enter a fast moving yet not gridlocked road, whether from a sliproad or sidestreet, traffic can change between the time you commit to entering and when you're actually up to speed and that Escalade driver with the cell phone shoved in her ear who was in the center lane suddenly decides she'd rather be in your lane. Now you've got the choice of accelerating away or bailing onto the shoulder to avoid the collision. This is not the time for the car to apply the brakes or cut engine power just because one wheel encountered a patch of broken up pavement, water, ice, or gravel. With the LSD, when that happens the other wheel, instead of sitting idly by, is putting the whole of the available power onto the road. This gets you out of the predicament much quicker and safer. Even with the LSD, when the conditions are ripe, the DSC will still be there functioning as BMW intended. It just takes a lot more for it to show up.
05-04-2010, 10:38 PM | #191 |
77
Rep 1,907
+1.....Well said....and a fact of life for modern day drivers, especially cell phone distracted drivers
Agreed on Safety. The Quaife -- or any mechanical diff for that matter -- should actually be touted as a safety feature that everyone must have. What happens when the software fails on an e-diff? Mechanical diffs would always be there. A Quaife, Wavetrac, Torsen, Drexler, Giken -- you name it -- would be light years better than a software solution that wears down your brakes and could possibly fail! Side benefit 1: the frequency of replacing your brake pads would certainly diminish, especially for you thrill seekers, with the installation of a LSD. Side benefit 2: Your car will become safer, and at the same time, sportier! A pleasant dichotomy of contrasting themes... safer... sportier... yin... yang... balance! Side benefit 3: You would enjoy sleeper car stealthiness to unsuspecting drivers who view your 3er with arrogant disdain.... LSD for safety...and FTW!
05-05-2010, 04:48 PM | #192 |
LSD - No, you're not seeing things
72
Rep 3,302
Another view.
An ATB is not always goign to save your ass on the road. In fact an ATB diff can put you out of shape where an open diff wont. I doubt most of you run on the road with the ATB installed and DSC off? Having owned recently an S2000 with a rear ATB diff and also an R26 with a front ATB diff I can say the results are often unpredicatable. I would never call it a safety feature, more of a track day tool. Cross a white line with the power down on either car and as the torque is shifted violently between wheels it can get VERY squirrely, an open diff car wont do this it will spin up a wheel - no big deal. Go out and play hard in loose conditions, with DSC OFF and report back you still think its a great safety feature |
05-05-2010, 05:25 PM | #193 | |
Moderator
324
Rep 5,493
Virtually all my driving is with an LSD and the DSC system switched off. I don't find the rear end squirrely at all - yes, you can feel the power shift left/right as the wheels find traction over bumps, but the upside in power delivery accelerating through corners and the throttle adjustability that results from having an LSD far outweigh the sometimes lively nature of the rear end.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
05-05-2010, 07:18 PM | #194 |
Captain Kirk
Rep 32
Where can i get one fitted in Northern Ireland ?
Or will i have to go over to the mainland - i'm heading over for the Ford Fair in August. Anyone fit them near Silverstone .
In the days of my youth, I was told what it means to be a man.
05-06-2010, 03:29 AM | #195 | |
Rep 8,972
I always have DTC on, and somtimes DSC off, the Quaife unit never seems to 'violently' shift torque. Best to book into Birds near Heathrow, get it fitted while you wait, no exchange costs or shipping either. Some might say Birds know what they're doing too |
05-06-2010, 10:48 AM | #196 | |
263
Rep 2,563
Alpina_B3_Lux
05-07-2010, 04:19 PM | #197 | |
72
Rep 3,302
Is this just bar room talk then or do you have some datalogger numbers to back it up? Have you compared these cars side-by-side on a circuit? I have had a few cars with various LSD but this would be a big outlay on something that simply 'feels' better. If anyone has some hard data then please post up, thanks as I might be tempted. £1200 fitted is cheap, the ATB unit itself normally retails around the £900 marker. |
05-07-2010, 09:10 PM | #198 | |
Moderator
324
Rep 5,493
The LSD does 'feel' better, as you put it. It also allows a competent driver to extract the most out of a balanced chassis, without the over-exuberant intrusion of DSC systems. And on a track, I'm carrying a good 20% more exit speed through a corner over a similarly specced 3er without an LSD.
335i, birds, diff, differential, e92fan, limited slip, lsd, quaife, torsen |
