Diesel Fuel Additives?
03-31-2018, 03:24 PM | #89 |
Tim
54
Rep 206
What facebook group? Can you send me a link? I have a few of the quart things but haven't tried it yet in my car or my truck (F350 7.3 diesel). Can you speak more to the results people are seeing? Thanks.
03-31-2018, 05:32 PM | #90 | |
Rep 1,157
Facebook group is https://www.facebook.com/groups/NABDOG/ Make sure you answer the question when you request to join, or your request won't be accepted. This is to cut back on spam. I moderate that group and you will see me on it frequently. |
04-02-2018, 03:09 PM | #91 | |
Tim
54
Rep 206
Thank you very much. I am already in that group.
04-03-2018, 03:15 PM | #92 | |
Rep 866
If you believe additives will help, find some real data and show it to us. In the scientific world, anecdotal information doesn't cut it. Cheers, PL |
04-03-2018, 04:31 PM | #93 | |
Rep 1,157
04-04-2018, 08:24 AM | #94 | |
107
Rep 202
I am sincerely interested in your point of view that diesel additives may be harmful. What, other than BMW & MB's recommendation, do you know about that indicates these products are harmful to our cars' fuel system? I'm generally against taking people's word for it, so if BMW recommends against something, I'd like to know why they recommend against it. They may in fact be recommending against it because they can't vouch for a product that isn't theirs, whose efficacy they haven't tested, and thus can't recommend, out of an abundance of caution, their use because 1) it's a unknown to them and 2) they stand by the design and quality of their own product and it would look bad to tell their customers to use an aftermarket product to possibly improve the long-term function or reliability of it. |
Torqu3321.50 |
04-06-2018, 02:25 PM | #95 |
Rep 580
You guys are probably paying too much for fuel adds. My 335D has been running with 2-stroke oil at a treat rate of 1oz/gal as a fuel additive for about 5 years. The emissions equipment has been absent for a couple years, but the suspension, injectors and maintenance items like filters, tires, brakes, etc. is the only stuff on the car not factory original, including the belts - now at 125k miles. The injectors were replaced as part of the CBU repair because they were dirty, not worn.
The injection pump is normally the 1st thing to go when fuel issues arise. |
04-06-2018, 05:03 PM | #96 | ||
Rep 866
I would really like to accept the "advantages" of additives, but my truth detector requires more. Cheers, PL |
04-06-2018, 05:34 PM | #97 | |
Rep 866
PL |
04-07-2018, 11:13 PM | #98 | |
Rep 1,157
EDIT: Here is a direct link to the diesel extreme data: https://www.hotshotsecret.com/wp-con...l-FULL-min.pdf And a direct link to the EDT data: https://www.hotshotsecret.com/wp-con...liner_6.7L.pdf It took a little digging, but the data was there. Last edited by Torqu3; 04-07-2018 at 11:21 PM.. |
04-08-2018, 02:10 AM | #99 | |
43
Rep 281
Having said that, I have tested a few additives in the past, and some demonstrably DO increase power output. I can't speak to fuel economy gains because I did not test that.
SLOW & SMOKEY. My car loses to every Chevy Malibu unless I mash the throttle.
Mods: *ATM 304SS Turbo-back exhaust, w/ ox-cat *ATM stepped intercooler *ATM silicone tubing kits (hot & cold sides) JR 2.8 tune *Whitbread CP3R90 HPFP *AArod EGR racepipe*Execuhitch hidden hitch *Stage 3 transmission tune Last edited by nicklockard; 04-08-2018 at 02:15 AM.. |
04-09-2018, 09:18 AM | #100 | |
Rep 1,157
I can definitely attest to the fuel mileage, because I have tested it. |
04-09-2018, 04:25 PM | #101 |
Rep 866
Sorry, not my idea of anything valid in the "data" link. Two trucks only. Only number of regenerating cycles measured. This is what I call salesmanship. Its almost comical as anecdote is made to look scientific.
Imagine if any other scientific research was performed on only 2 subjects what the reaction would be. Its good wishful thinking. Would love to have a magic diesel potion to use on my own cars.... What really is going on here is that a company won't share their "real" data on the product(s) with the public (i.e. from their own development or the company that came up with the product- internal data). Haven't seen this more than once or at all if criteria are used for validity. PL |
04-12-2018, 10:28 PM | #102 |
Rep 3,361
I have been using hot shots for 40k miles now, injectors are quieter at 110k miles than they were at 65k miles and not a single injector code since I started using it.
04-14-2018, 08:50 AM | #103 | |
92
Rep 370
There is more to it... Synthetic, Conventional, Brand... Cant really find what Tdiwyse is using!? |
04-15-2018, 09:33 PM | #104 | |
Rep 44
i can actually be on board with that assessment. power output wasnt as much as one would expect to be but it was enough to make a different in the system operation. now, mind you that i have stock everything. nothing in my car is tuned or modded. although to me, the additives didn't work immediately after you pour it in but rather it takes few cycles in order for me to feel slight differences in my cars behavior. also, i think the type of fuel that you add with the additive do matter the most. |
04-15-2018, 09:36 PM | #105 |
Rep 44
04-15-2018, 09:42 PM | #106 | |
Rep 44
additives certainly not for everyone but also it doesn't prove that it makes your car worst. because if it does, then everyone that have used additives on their cars would have a broken down bmw by now and you will see a whole bunch of negative comments coming out of that camp about additives. |
04-16-2018, 04:57 PM | #107 | |
Rep 866
- the placebo effect exists - the biggest ingredient in additives is diesel fuel which by itself will increase the "mileage" infinitesimally. Claiming improved "fuel economy becomes technically and legally correct. Notice its always "up to" as a disclaimer. Like weight loss pills that fill the stomach slightly would decrease appetite etc. but not to any meaningful degree. - proprietary information is not published about ingredients and effects to any quantitative extent. - a friend who was a chemical engineer and looked up all of the MSDS sheets of products he sold for his private business - he found that many products after they had created a market share were later changed (diluted) to the point of being ineffective. My personal preference is not to waste my time, money, or have throw-away plastic bottles to go into landfills unless I get a real benefit and it is cost effective. Improving my engine's longevity from 300,000 miles to 310,000 miles, for example, will not do. Cheers, PL |
04-16-2018, 05:00 PM | #108 | |
Rep 866
PL |
04-17-2018, 03:23 PM | #110 |
36
Rep 122
What would we do without Pierre Louis telling us about his disdain for fuel additives?
Hotshots EDT is what....$16 for 16 oz. Basically an extra dollar every fill-up. While I agree that there may be some placebo effect to how well additives really work, I will never understand why some people get so bent out of shape over people spending what amounts to an extra $1 a week (for me) for something they feel will/may benefit their car. Its worth it for any amount of peace of mind someone may derive from using it even if it may be false peace of mind. |
