TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > car not starting...because of steering wheel lock?
      12-10-2009, 10:08 AM   #1
jasonintoronto
39
Drives: 2007 335i coupe (sold)
i had a weird experience this morning. when i got into the car, it wouldn't start when i pushed the button. instead it had a weird icon on the dash of the steering wheel with a lock sign on it.
i pulled the fob out and back in a few times, trying to start the car every time, but no life. a very weird problem. the steering wheel lock would release (i heard it) but it would not start.
after about 6-7 tries, i decided to lock the car and then unlock it using the fob. it started right away after that. since i was late for work, i haven't looked up the icon warning light in the manual. anyone know what this is?
2007 Porsche Carrera 4
2007 BMW 335i Coupe (SOLD)
      12-10-2009, 10:13 AM   #2
samchoi604
61
Drives: black on black
I had this problem last month, and learned that it's a common problem which is addressed in the TSB. Just take it in to the dealer and have them update the software. That did it for me. Good luck!
      12-10-2009, 10:15 AM   #3
Kevin@AKMotorwerk
General
Kevin@AKMotorwerk's Avatar
Drives: THE GUY YOU LOVE TO HATE
thats probably possible, older cars with actual keys used to not allow you to turn the key if the steering wheel was against the steering lock, you had to move the steering wheel away from the lock to get the key to turn
      12-10-2009, 10:26 AM   #4
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
FYI it's a common issue on the 06 and early 07 models. In mid-07, BMW stopped putting locks in the steering columns (for reasons unrelated to this problem). Apparently, this problem has to do with the electronic lock power draw when starting the car, and a software update normally fixes the problem. If the software update does not work, BMW replaces the steering column.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
      12-10-2009, 10:41 AM   #5
jasonintoronto
39
didn't know about the TSB. thanks guys.
      01-21-2010, 10:59 AM   #6
kuvesh
kuvesh's Avatar
Singapore
26
Drives: e92 335i juiced
anyone have a copy of the tsb. just had this prob on my e92 and dont want the stealer pulling a fast one on me...
HAMANN FRONT APRON, SIDES, ROOF SPOILER & QUAD DIFFUSER | VORSTEINER VRS TRUNK | CSC3 ON 19” ADVAN RS | BREMBO GT BBK | BASTUCK QUAD | KW V2 | JB3 v1.3s beta | BMW PERFORMANCE STEERING WHEEL | M3 SIDE MIRRORS | M5 SMG SHIFT KNOB | BLACKOUT GRILLS | PARTIALLY SMOKED LIGHTS | WINDOW TINT
      01-21-2010, 12:40 PM   #7
nvez
nvez's Avatar
40
Drives: 2021 GLE63s
was bored so got you this
TSB ID: 61 28 06
SUBJECT
ELV Warning in Instrument Cluster
MODEL
E90, E91, E92 (3 Series)
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
The ELV (Electronic Steering Lock) check control warning illuminates in the instrument cluster and in some cases, engine start is inhibited. Diagnostics reveals fault code A0AA in the CAS (Car Access System) and prompts a control unit replacement.
CAUSE
Low voltages in the vehicle electrical system when cranking/starting the engine.
PROCEDURE
This problem has been integrated into DIS diagnostics. Follow diagnostics and relevant test plan using DIS V49.0 or later.
hope it goes well for you
      01-21-2010, 05:55 PM   #8
kuvesh
kuvesh's Avatar
Singapore
26
thanks. much appreciated.
TSB ID: 61 28 06
SUBJECT
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
CAUSE
PROCEDURE
      01-21-2010, 06:01 PM   #9
hawc
hawc's Avatar
13
Drives: Porsche Cayman
Sometimes all you have to do is just wiggle the steering wheel a few times.
      01-21-2010, 06:27 PM   #10
jasonintoronto
39
curious how this came up today. car refused to start even after moving the steering wheel. tried a number of times over the course of several hours too. roadside assistance towed it to bmw toronto.
      01-22-2010, 12:43 AM   #11
GregoryM
Drives: 1994 Toyota Supra Twin Turbo
Well hopefully they take care of it under warranty. If not check out this post and ready my experiance with this same issue and how I fixed it. http://www.e90post.com/forums/showth...ing+wheel+lock
      01-22-2010, 08:33 AM   #12
jasonintoronto
39
yeah, it's an 07 and still under factory warranty...and it's a CPO car so i'm covered til 2012. if it can't be fixed today the dealer is offering a loaner.
      01-22-2010, 12:04 PM   #13
PLAY
14
Drives: AWE92N54
quick fix, I had mine done for the same problem
sometimes on occational days a quick wiggle while putting the key in worked.
      01-23-2010, 08:31 PM   #14
Oulixes
Oulixes's Avatar
22
Drives: 330xi, 335i
My 330xi (2006, Convenient Access) started behaving from time to time as you describe. The dealer gave the car a software update, which resolved the problem for the car access with one of the two CA fobs. The second CA fob was diagnosed as faulty and had to be replaced. In the end, the true cause of the assess and starting problem had not been established, but I am quite sure that the problem had not been caused by low battery voltage, which is suggested as the cause in the TSB ID: 61 28 06. After repair, the problem has not re-occurred.
      01-24-2010, 05:27 PM   #15
Evolution_GT
Evolution_GT's Avatar
91
Drives: 08A22E93N52
+1
Have had this problem before... but its very rare that it has happened to me... just slightly turn the wheel left or right... it should start afterwards
      04-14-2013, 09:49 PM   #16
bumere90
Grozniy
Drives: Carless
my car is an 07 e92 with 51k miles.
Do you guys know if this TSB applies only to BMW's that are under warranty?
TSB ID: 61 28 06
SUBJECT
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
CAUSE
PROCEDURE
-fatman
      04-15-2013, 03:51 PM   #17
marcvtec
Drives: M5
I bet it's the battery
Test your battery.
If its original its already 5-6 years old.
This is how I fixed my steering lock problem.
I made a thread a few months back, there's some good info in there.
      04-15-2013, 06:17 PM   #18
bumere90
Grozniy
Drives: Carless
I have a brand new battery installed in the car
-fatman
      04-16-2013, 03:22 PM   #19
marcvtec
Drives: M5
I assume it was coded to the computer as well right?
      04-16-2013, 07:48 PM   #20
bumere90
Grozniy
Drives: Carless
nope
-fatman
      04-17-2013, 01:07 PM   #21
marcvtec
Drives: M5
nope
My Steering lock dash light went off right after we coded the battery.
      07-07-2013, 09:52 AM   #22
bumere90
Grozniy
Drives: Carless
haha good one
I'll try that
