02-09-2014, 06:33 PM | #89 |
Rep 7,642
02-09-2014, 07:29 PM | #90 |
Rep 4,021
Drives: F32 Coupé
So on a more performance oriented note, I have a question regarding my Cobb Tune...
I'm running the Stage 1 Aggressive /ST Map and I'm noticing a bit of a flat spot at around 3800RPM... Now I understand that an OTS Map will never be perfect and I was ready to put it down to needing a ProTune but the other day I noticed something interesting: When I change the traction control mode to MDM the flat spot goes away...BUT I'm not getting any traction control lights in standard mode... Thoughts? |
02-09-2014, 10:05 PM | #91 | |
Rep 707
In regards to flat spot, haven't noticed it with my stage 1 aggressive FMIC+ map but I get more of a jerky hesitation power output when I WOT. I'm not bother about it yet as I haven't yet done a track day to see how bad it is.
My 1M journey - http://www.1addicts.com/forums/showthread.php?t=734281
02-09-2014, 10:10 PM | #92 | |
Rep 7,642
Odd though, that the christmas tree is not lighting up in standard mode.. |
02-09-2014, 10:16 PM | #93 | |
Rep 4,021
Drives: F32 Coupé
Sorry... Wasn't really clear... Scenario 1: All traction control aids on. ///M button on. 3rd gear pull. No traction control light coming on. Flat spot at about 3800RPM. Scenario 2: MDM Mode active. ///M button on. 3rd gear pull. No traction control light coming on. NO flat spot at about 3800RPM. My point was that I initially thought that in full "nanny mode" it was a lack of traction that was causing the flatspot in the power but its not triggering the TC light on the dash. And yet it doesn't happen when I am in MDM mode... (the flatspot, that is. I'm not expecting TC light in MDM mode unless I'm about to kill myself...) |
02-09-2014, 10:20 PM | #94 | |
Rep 4,021
Drives: F32 Coupé
M button still works fine with the Stock Throttle Map for me... That's why I'm not using the LT map... I know I need to do some logging and take a look at the curves... It's just hard to do in this Police State called Queensland... |
02-09-2014, 11:13 PM | #95 | ||
Rep 4,021
Drives: F32 Coupé
I notice it most on a good road surface... Yeah.... as I said above, I know I need to do some logging.... will have to see if I can make it a priority... |
02-10-2014, 01:23 AM | #96 | |
36
Rep 167
02-10-2014, 02:05 AM | #97 | ||
22
Rep 319
Drives: BSM e82 135i
This is what you get for owning 1M's. But I don't use the ST map anyway because no ///M button |
02-10-2014, 08:28 PM | #98 |
Rep 4,021
Drives: F32 Coupé
That was a constructive post...
02-10-2014, 08:29 PM | #99 |
Rep 4,021
Drives: F32 Coupé
Will be very interested to see what new rubber does for you mate. Might be the nudge I need to shell out for some SuperSports...
02-10-2014, 08:40 PM | #100 | |
European Editor
10628
Rep 22,992
@Harlequin
Other thing that comes to my mind is your clutch could be starting to slip. Don't forget the clutch is not rated for STOCK HP level. The trans too. lol But BMW just took a calculated risk - with warranty claims. So far so good. But time will tell. Also there were some 1M's which had bad rear crankshaft seal. They leak oil(or somethings just make a fluttering type noise on decell). Just FYI.
02-11-2014, 03:08 AM | #102 | ||
36
Rep 167
Doesn't feel like the clutch to me... And I hope I'm right haha. |
02-12-2014, 07:46 PM | #103 | ||||
Rep 4,021
Drives: F32 Coupé
Yeah... I'm thinking that maybe it's pulling the timing or something. Only way to know is Logs. Just got no time at the moment... |
02-19-2014, 02:45 AM | #104 |
Rep 4,021
Drives: F32 Coupé
So, big thanks to Quang for pointing me in the right direction. Couple of weeks ago I managed to pick up one of the last of these limited edition Stencil Prints originally commissioned for 1Addicts Members...
Managed to get it on sale.. There's still a few left if anyone's interested. Only VO and AW available now... Can't insert a link because for some reason the site is blocked on here but do a search for Manual Designs if you want one... Found the perfect frame for it too... |
02-19-2014, 03:00 AM | #105 |
Rep 707
Very nice!
I still haven't framed mine yet.
02-19-2014, 05:19 AM | #107 | |
Rep 4,021
Drives: F32 Coupé
[edit: for 20 bucks, why not ] |
02-19-2014, 05:27 AM | #108 |
Rep 4,021
Drives: F32 Coupé
Can't. Bimmerpost censors the link... turns it into: www.*****.com
If you PM me your mobile I will TXT it to you... |
02-19-2014, 05:29 AM | #109 |
Rep 4,021
Drives: F32 Coupé
You really should mate. It's awesome up on the wall...
Thanks again for showing me where to get it... |
02-19-2014, 06:16 AM | #110 | |
Moderator
29882
Rep 13,153
///M is art ↔ Artemis
1m coupe parts, gtb performance |
