07-06-2014, 03:17 PM | #1 |
Rep 1,114
Msport Brakes Vs. Stock BMW Brakes
Has anyone had any experience with both brakes? Did the Msport brakes really do a better job at stopping? Did they fade less?
Any specs on each, ie stopping distance?
My Ride! : 2015 428i GC (F36) - MSport, Alpine, Black Leather, MBrakes, Adaptive, Sport Seats, Hex. Alum w/Piano, HK Sound, 400m's, Comfort Acc. When I’m not Driving: https://youtube.com/shorts/ViKD_Hj5htE?feature=share
07-06-2014, 03:30 PM | #3 |
70
Rep 327
They're supposed to be be more fade resistant, looks alone warrant the 600 euro option though :-) There is a big difference between the M sport brakes and true bigh brake motorsport kits, the M sport brakes still have tiny brake pads, nothing like the big pads in true motorsport big brake kits.
07-06-2014, 09:45 PM | #5 |
Rep 1,730
No brainer upgrade for $600, you'd realize the difference pretty quick if you took the car to a track day.
source: http://f30.bimmerpost.com/forums/sho...87&postcount=6 |
MSportTune280.50 |
07-06-2014, 10:00 PM | #6 |
Rep 1,086
Dumb question...
I got a 2013 335i M-Sport, and the breaks are really large, how different are they from the 2014 base & $600 option?
2016 M3, Mineral White, SO Leather, MANUAL - ED 11/26/2015
2013 335i, Blue, M-Sport, Auto w/Sport Trans - ED 06/10/2013 |
07-06-2014, 10:10 PM | #7 |
2006 TIME Person Of The Year
9720
Rep 6,445
The M Sport brakes are absolutely a better braking system than the standard system.
Questions like: Do you need it... Is it worth it... Are subjective. I'll add the M Sport brakes are the one thing about my car that everyone complements. For $650 it's a no-brainer for me.
07-06-2014, 10:13 PM | #8 | |
Rep 951
(Net is that on a 335i the M Sport brakes are identical to the M Performance brakes, except for the dimpled rotors.) |
07-06-2014, 10:18 PM | #9 | ||
Rep 1,086
07-06-2014, 10:19 PM | #10 |
54
Rep 341
To add. the rears on the m sport are pots compared to the stock are not. The looks alone justify the price. Keep in mind that you cannot fit 17s over the fronts m sport. So if you are looking for winter setup you will need 18s.
07-06-2014, 11:06 PM | #12 | |
Rep 103
Or maybe only 435I has the BMW on the standard M sport brakes. Anyone know? |
07-06-2014, 11:48 PM | #13 |
16
Rep 234
07-07-2014, 12:13 AM | #14 | |
Rep 1,502
Original Brakes on "high power" models (335i) Front rotor: 340mm brake rotor with 4 piston caliper Rear rotor: 330mm brake rotor with 1 piston caliper Original Brakes on "low power" models (320i/328i) Front rotor: 312mm brake rotor with 1 piston caliper Rear rotor: 300mm brake rotor with 1 piston caliper M-Sport Brake Option (2NH) (Blue “M” calipers) Front rotor: 370mm Brake Rotor with 4 pistons (for on "high power" models) Front rotor: 340mm Brake Caliper with 4 pistons (for "low power" models) Rear rotor: 345mm Brake Caliper with 2 pistons (on all models) M-Performance Brake Kit (Yellow, Orange or Red “M” calipers) For a "high power" car (all that have 4 piston front brake calipers as factory standard): Sizes are the same as M-Sport 2NH option but all rotors are dimpled and slotted For a "low power" car (all that have 1 piston front brake calipers as factory standard): 370mm front rotors, 345mm rear rotors - all dimpled and slotted |
07-07-2014, 01:32 AM | #15 | |
Rep 5,140
07-07-2014, 03:30 PM | #16 |
Rep 1,114
Ok I heard the LEDs don't throw the light as far?
07-07-2014, 03:31 PM | #17 |
Rep 1,114
Thanks gentlemen for your replies, it does help a lot!!
07-08-2014, 08:10 PM | #18 |
18
Rep 80
wait, if i order m-performance brakes during my initial purchase. When it's time for rotor replacement, they will replace with m-performance rotors as well????
holy shit that's the deal of a lifetime if that's true. |
12-15-2014, 03:11 PM | #19 |
Rep 1,114
Yeah they will.
12-15-2014, 03:21 PM | #20 |
pew pew
166
Rep 6,781
I just replied to this on another thread, but I would say that it's worth it for the cosmetics but don't expect a huge increase in performance even on track. I had our car on the ring with the factory brakes and now have the M Performance brakes that I just bedded in yesterday. The difference is not huge in absolute braking performance. Fade - possibly. The M Performance brakes still faded by about the 8th hard stop while bedding in, which is to be expected. But as others have said, for $650, it's worthwhile if only for cosmetics.
The brake pads are even the same shape and size so the rotor sweep area is the same, even though it scrubs the rotor farther away from the hub.
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
12-22-2014, 08:29 PM | #22 |
Rep 1,113
Has anyone looked at the braking benefits of the larger rotor in relation to rotating mass added?
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
