09-01-2017, 03:43 AM | #1 |
Rep 1,295
Anti-roll (Sway) Bars Options study
I've put together a table of the available ARBs for our platform, BMW has quite a lot of options depending on engine, suspension, M Sport, M Adaptive or standard.
In a nutshell: - 6 cyl get weaker front bars than 4 cyl engines - M Sport has slightly stronger bars front and rear - 440i LCI have stronger bars (same as M235i) than non-LCI 435i - Xdrive have weaker front bars but same rear bars. Aftermarket: I've tried the H&R but they're too stiff on the rear. I've now put on the M235i bars now and they're too weak on the front. The sweet spot is probably the KW or Eibach, which I might try next. (I always put bars in pairs because they're designed as pairs) Some vendors (Hotchkis, Dinan) have hollow bars so you can't directly compare diameters with plain, non-hollow bars, hollow bar will be weaker than plain for same outer diameter. Hope this helps...
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
09-01-2017, 11:33 AM | #2 | |
Rep 3,482
09-01-2017, 12:21 PM | #3 |
Rep 1,295
Indeed, for those who are more math inclined the stiffness is calculated as a proportional to (D^4 - d^4) where D = outer diameter and d = inner diameter (and d = 0 if the bar is plain), while the weight is proportional to (D^2 - d^2).
09-06-2017, 02:41 AM | #5 | |
Rep 1,295
And to make it a little more complex, most aftermarket parts are adjustable at the front, sometimes at the back like Dinan. I'll try to update this table with the info I can find on this to try to paint the full picture. Data I have for the 6 cylinders: - KW and Eibach have front lever arm lengths 250 and 270mm (two way adjustable each side = 3 possible settings - Short/Short, Short/Long, Long/Long) - H&R have lever arm lengths 250 and 265mm for the 6 cylinder version All 3 are 150mm at the back.
09-06-2017, 06:54 PM | #6 |
25
Rep 127
Is it difficult to put a front bar on these cars? (Xdrive). I know in my Mini Cooper, it would involve dropping entire front subframe.
2017 330i Wagon | Glacier Silver/Black/Anthracite, M-sport, Nav, Tech, Premium, DA, DA+, Cold, LED's, Carplay
09-07-2017, 08:13 AM | #7 |
Rep 1,295
Yes BMW has adopted the same architecture on the F2x/F3x subframes, so quite a pain indeed, although my shop has done that quicker last time, altogether I was there for 5 hours for 2 anti-roll bars, rear subframe bushings, intercooler and downpipe.
09-07-2017, 09:20 PM | #8 |
25
Rep 127
I just got my car on Tuesday (2017 f31) and am on the lookout for whatever the consensus is on a good anti roll bar setup to tame the xdrive body roll. Coming from a Mini and then a Focus ST, it was actually kind of alarming..
09-08-2017, 03:23 AM | #9 |
Rep 1,295
The difficulty with bars is finding the right balance between taming roll and keeping suspension independence: with bars that are too stiff, potholes and similar bumps will upset the entire car balance, instead of leaving the single wheel / damper absorb the shock, it will be transmitted to the entire body.
Springs and coilovers do not have the same inconvenience so it's a better place to start in my opinion, and if not enough then use bars as a stage 2.
09-08-2017, 08:25 AM | #10 |
Rep 1,468
do you have to drop the exhaust to install front an rear ARBs on an xdrive? (435)
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
09-08-2017, 08:45 AM | #11 |
Rep 1,295
Yes for the rear but that takes literally 5 minutes.
09-08-2017, 09:37 AM | #12 |
Rep 1,468
5 mins for normal people, my exhaust barely fits (xdrive problems) I cant imagine how much work i would be adding to realign the whole damn thing.
09-08-2017, 10:04 AM | #13 |
Rep 3,954
09-19-2017, 09:44 AM | #15 |
Rep 1,295
I found the Dinan install guide for their anti roll bars to be good
RedSectorA37.50 |
09-29-2017, 02:37 PM | #16 |
179
Rep 331
I'll second this, just installed a set of Megan Racing sway bars on my 335. The Dinan instructions are excellent, but make no mistake the install is a huge pain in the ass. The rear is relatively easy, but maneuvering the front bar into place took some time.
2017 F80 M3 - Mineral White/Amaro Brown
2003 E46 M3 - Jet Black/Cinnamon |
09-30-2017, 08:45 AM | #17 |
Rep 3,954
You had access to a lift and transmission/diff jack right?
09-30-2017, 09:47 AM | #18 |
Rep 1,574
Doesn't the type and condition of the swaybar bushings have some degree of impact on the bar performance (i.e. Rubber vs polyurethane, etc)?
10-02-2017, 11:46 AM | #19 |
20
Rep 99
10-12-2017, 11:31 PM | #21 |
Rep 1,295
Yes or m135i/m140i ; probably best to start with springs or coilovers.
10-12-2017, 11:57 PM | #22 |
20
Rep 159
Already have Dinan springs and shockware, body roll still there.
f30bmw340i24.50 |
