BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > New Rev3 user question
      07-02-2013, 05:41 PM   #1
ptwob311
ptwob311's Avatar
13
Drives: 335i Sedan
called and called and called Vishnu...
I just got my Rev 3 (upgraded from 2) and the flex fuel ECU flash. About to put the ECU and PROcede in the car and go for a drive
Where are the new maps, firmware, etc. The last post I can find on Vishnu's site is dated June of 2010????? Pretty sure I am gonna need newer than that.
I have added FMIC and DPs to the car and remember that at one point you had to load the maps based on mods done to the car.
PLEASE help clarify
Thanks guy
Rides
2015 Toyota Tacoma 4x4
2003 Yamaha YZF-R1
SOLD 2007 335i Sedan Titanium Silver Metallic
      07-02-2013, 05:45 PM   #2
E90Company
E90Company's Avatar
196
Drives: Car
Last I heard Shiv hasn't updated maps in a long time for stock turbo guys.
      07-02-2013, 05:48 PM   #3
Robert@vishnu
Drives: Corvette C6 Z06
If you call many times we are on the phone or out testing. Please feel free to leave and message and we will get back to you.
The new "NEW" maps and firmware will be release on July 4th by Shiv. If you want our lastest firmware and maps to what we have available to the public right now its located here: http://www.procedetuning.com/BMW/n54...downloads.html
*Base on the mods you have you will be running a stage2 maps. If you want us to dial your car in remotely. Perform a couple datalogs going from 3rd to 4th gear WOT pulls and send those datalogs to sales@vishnutuning.com for evaluation. Base on your results we may have you make some adjustment to gain more power and/or better driveability.
Robert@Vishnu
      07-02-2013, 06:24 PM   #4
ptwob311
ptwob311's Avatar
13
Drives: 335i Sedan
Robert lined me out
Thanks!!!!
Rides
2003 Yamaha YZF-R1
      07-02-2013, 09:34 PM   #5
ptwob311
ptwob311's Avatar
13
Drives: 335i Sedan
OK, new issue...
Cant get windows 8 to go online with the PROcede. I see it in the port 2 in the device manager but it claims "The drivers for this device are not installed. (Code 28)
To find a driver for this device, click Update Driver."
any ideas???
Rides
2003 Yamaha YZF-R1
      07-02-2013, 09:37 PM   #6
ptwob311
ptwob311's Avatar
13
Drives: 335i Sedan
I get a CP2102USB to UART bridge controller message
Rides
2003 Yamaha YZF-R1
      07-02-2013, 10:15 PM   #7
Jeller
Drives: 2007 335i E90 ZSP
Did you download the drivers http://procedetuning.com/BMW/n54/dow...downloads.html
directions from the read me file:
o install these drivers, follow these steps:
1) Turn off WIFI. If your computer has access to the internet, Windows will automatically try to update to the newest version (v6.x) of this driver which will not work with the Procede. The Procede requires version 4.40.1.0 which is what this installer will install.
2) Double-click on "Preinstaller" .exe. Nothing will appear to happen. This is okay.
3) Connect the Procede to you Laptop via USB cable. Turn ignition fully ON. Windows will give you an alert and start to update to the necessary driver.
4) Go to device manager->Ports (COM&LPT). You should the necessary driver (2P210x USB to UART Bridge Controller). It will be assigned to a Port. Make sure this port # is between 1 and 9. If it's greater, reassign it to a lower port.
5) Double-click on the driver to see driver properties. Go to "Driver" tab and confirm that the driver version is 4.40.1.0. If it's 6.x, you will need to remove the driver and start again. The Procede will only work with the 4.40.1.0 version of the driver.
6) Open up the users software. Click on the COMMS menu. Go to COMMS SETUP and select the appropriate COMM # found in Step 4.
7) Now you should be able to communicate with the Procede. Just go COMMS-> Go Online/Offline to establish/end communication.
      07-03-2013, 12:10 AM   #8
ptwob311
ptwob311's Avatar
13
Drives: 335i Sedan
I got it, feeling like a retard over here
hahaha
thanks for the help guys
Rides
2003 Yamaha YZF-R1
