FSTOOL2 problem Error when executing Job [1000] CIC Retrofit
02-05-2024, 02:27 AM | #1 |
Rep 12
Hello, I have an issue with Fstool2. I've performed a CIC retrofit, and my CIC is the C1A version. The Navigation is grayed out because I need to input FSC codes. I've entered the VIN into my CIC modules using Tool32. However, now when I try to generate the Patch FSC codes, I encounter an error in FsTool2. Whatever I attempt to do with Execute results in the same error. Attached are some images.
https://prnt.sc/rSZLXuPaUHEX |
02-05-2024, 11:30 AM | #2 |
310
Rep 269
Drives: Green '07 & Arctic '08 335i's
Java?
Looks like it can't find Java, do you have it installed and in the folder FStool is looking at?
02-05-2024, 07:21 PM | #3 |
10
Rep 15
Drives: 2011 BMW 135i M Sport 6MT
Where did you get fstool?
02-06-2024, 10:49 AM | #4 |
Rep 12
I installed Java 1.4.2_06 and 1.5.0_22, tried both.
I found FsTool on the internet, maybe my version of FsTool is not good. Does anyone have a working version? https://prnt.sc/HwF-uXdjBofs |
