01-22-2018, 02:56 PM | #45 |
49
Rep 139
Car is finally sorted, kris cleaned mechatronics and i went to the car today, removed the jb4 and done the clutch adaptations. Didnt work first time but i then done the other three adapations first and reattempted the clutch to which it worked. Put 100miles on it on way home with no problems.
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth Insta: Tommy_turb0 |
01-22-2018, 05:55 PM | #48 |
49
Rep 139
I have reinstalled the jb4 yes, i dont think its jb4 related though as it still didnt work with-it removed at first and it was only set to map4. When my 300mile adapations are done i will leave it hooked up to see.
F10 M5 2013 Sakhir
01-23-2018, 11:51 AM | #50 | |
61
Rep 294
BMW dealer said they have seen this issue and it is caused by internal metal shavings due to wear accumulating in the magnet(?) inside transmission and thus requires a transmission change(interesting)
2019 F90 M5 Competition - Marina bay Blue Pearl - Executive and Bowers & Wilkins package
Gone:2013 F10 M5-DCT-Montecarlo Pearl Blue-BBMR 800 Stage 1 system 700whp+(93oct) 2004 Lamborghini Gallardo-Manual-Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
01-24-2018, 10:06 PM | #51 | ||
Rep 1,300
01-29-2018, 10:06 AM | #52 |
61
Rep 294
I found out that this gear rod issue is caused by metal shavings accumulating inside the trans over time and requires internal cleaning to resolve this successfully 70% of the time....if you ship trans to SSP they can do this procedure
01-29-2018, 10:24 AM | #53 |
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1090
Rep 1,968
Not conclusive. On my previous trans cleaning didn't solve the issue. Maybe that was an exception.
01-29-2018, 11:05 AM | #54 |
61
Rep 294
anyone else try the cleaning procedure?
01-29-2018, 09:17 PM | #55 |
Rep 1,300
Heard a few people try cleaning and nothing.
The Two dealers that i know both service managers at say this is common and they just swap out trans if it occurs 3+ times |
01-30-2018, 02:22 PM | #56 | |
Rep 966
Did you have an issue with installation of the clutch kit ? Was anything installed wrong ? I recently experienced a vehicle that had a previous installation done wrong and was getting the same fault codes after correcting the issue which required installing a new clutch kit. |
01-31-2018, 07:59 AM | #57 |
49
Rep 139
Clutch installation was correct, jb4 and map was not affecting adaptations. Mechatronics was cleaned, oil changed, different version of ista used and all gearbox related adaptations reset sorted it.
F10 M5 2013 Sakhir
02-03-2018, 03:30 PM | #58 | |
Rep 966
The previous DCT we had with the failed clutches, still set the same code but it was random occurrences and only set after and extended drive time. Within 100 miles. We were waiting on feedback from Kris on your transmission issue actually, and we decided to updated the complete car "main focus on transmission software" and the software was very outdated. We updated software with current ISTA, replaced the high flow filter with OEM, set teach-in functions and car has almost 500 miles on now with no issues. |
02-03-2018, 06:37 PM | #59 | |
Rep 881
2014 "AW/SO"me M5
Mission Performance/3.5 Bar RK Autowerks/ CSF ICs SSP Spec-R KW V3/ Corsa Axle back |
02-05-2018, 05:08 PM | #60 |
49
Rep 139
In my case the ssp filter was never used. Gearbox software was updated but did not resolve in my case. About 800miles covered since fixed problem free
F10 M5 2013 Sakhir
schnell1982345.00 GAINZ39.50 |
02-05-2018, 05:23 PM | #61 |
61
Rep 294
So I gather the only fix so far is a trans swap? Maybe there is a revision that corrects this issue? maybe the 2015 trans?
The latest BMW part number appears to be B28.00.7.843.840 ? The ideal is to find a used one.....then what is the process to swap it and vin match it to your car?
02-05-2018, 11:11 PM | #62 | |
1090
Rep 1,968
02-06-2018, 09:19 AM | #63 |
61
Rep 294
Whats the involvement to swap the mechatronics?
02-06-2018, 05:59 PM | #64 |
1090
Rep 1,968
02-07-2018, 04:50 PM | #65 |
61
Rep 294
problem is what guarantees that the used 2014/2015 trans wont have the same issue.....only if we buy new at a large cost
04-08-2018, 03:25 PM | #66 |
49
Rep 139
I got the 5-7 rod fault yesterday. Was at 1/4 mile strip for first time on mt's and was throwing dtm at top of fourth. Never seen the 5-7 issue before just had the adaptation issues earlier in the year. I full throttle my car alot but usually from 2nd upwards never really from a stand still which is when this occured. At the end of the day on my last run i also got a high trans temp error whilst warming tyres but no 4th issue on that pull. Ive done the adaptations again today at 75c and going to see how long she holds out for. My oil and filter is only few months old and mecha has been cleaned
F10 M5 2013 Sakhir
