04-15-2018, 05:10 PM | #90 |
49
Rep 139
What do you mean ARC? WOT before box has been warmed up properly?
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth Insta: Tommy_turb0 |
04-16-2018, 07:12 AM | #91 |
61
Rep 294
It has been confirmed by bmw and ssp that the issue is caused by metallic wear acculumation to the mechatronic magnetic sensors causing the sensors to loose reading accuracy over time as more wear dirt accumulates.....fix is to clean sensors or install new trans+ 2018 bmw firmware updates
04-17-2018, 10:19 AM | #92 |
49
Rep 139
Booked in for bmw update next wednesday
F10 M5 2013 Sakhir
04-17-2018, 10:46 AM | #93 |
61
Rep 294
Keep us posted......so I gather from your last post that after some hard runs you started getting the rod shift error?
***remember the oem BMW flash update will erase your ECU tune....you will have to reflash the aftermarket tune after oem flash
2019 F90 M5 Competition - Marina bay Blue Pearl - Executive and Bowers & Wilkins package
Gone:2013 F10 M5-DCT-Montecarlo Pearl Blue-BBMR 800 Stage 1 system 700whp+(93oct) 2004 Lamborghini Gallardo-Manual-Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
04-17-2018, 12:27 PM | #94 | |
Rep 1,244
Drives: 2013 F10 M5
Factory tools won't allow you to modify these areas of memory at all. There are third party tools which allow you to do it, but you usually have to pull apart the module and connect directly to the chip on the board to perform a low-level rewriting of the EEPROM. |
M5Rlz248.50 |
04-17-2018, 04:03 PM | #95 |
Rep 1
Drive train fault
Hi. I recently experienced the same message and after getting my local dealer to have a look, they are looking to replace metatronic sensors. The warranty will be covering the costs so will update you if it fixes the problem.
04-17-2018, 05:31 PM | #96 |
61
Rep 294
Yes keep us posted on technical details thanks....
04-17-2018, 09:12 PM | #97 | |
40
Rep 65
Is the TCU integrated with the solenoids or are they separate parts? I'm just trying to get a handle on how people are going to deal with these problems as the cars age, and replacement with a new DCT is either unavailable or too costly. |
04-18-2018, 12:57 AM | #98 |
Rep 657
interested to find out what the issue is and if its fixable for the future. Knowing BMW they will just say replace
540i
GTR-R35, F90 M5, X3MC, RS3, RS7, M5, S7, S3, RS3, RS6, GTR R35, 996 Turbo, M5, RS6 V10, Cayenne Turbo S |
04-18-2018, 12:46 PM | #99 | |
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1090
Rep 1,968
05-29-2018, 11:21 AM | #101 |
61
Rep 294
bump
08-14-2018, 04:31 PM | #103 |
61
Rep 294
The only info I have is that the latest 2018 BMW software updates combined with the specific Mechatronics transmission cleaning will resolve the issue (per SSP)
08-16-2018, 01:12 PM | #104 |
Rep 466
Guys, update on this issue.
The BMW's plagued "Rod code issues" can be resolved now... Almost all of the Rod Code issues result from a transmission clutch relearn or adaptation. This happens because the parameters of the transmission have changed due to clutch wear and metallic debris accumulating on the shift fork magnets. Solution: Update latest 2016 transmission firmware before doing any adaptations Clean all shift fork magnets during service Clean Megatronic unit including internal filters SSP Performance |
schnell1982345.00 |
08-17-2018, 08:49 PM | #105 | |
Rep 70
Is this a solution you guys have came up with or is this also a bulletin @ BMW dealerships? As my car is going to dealer Monday for this issue and I am wondering how they will approach it. thanks
2014 M5
08-18-2018, 09:47 AM | #107 |
40
Rep 65
08-18-2018, 12:08 PM | #108 |
Rep 608
When updating software I believe it wipes away the tune at the same time. That's what I heard.
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
08-18-2018, 12:31 PM | #109 | |
40
Rep 65
I'm downloading the latest psdz files currently, they are 2018 files so it should have the 2016 dct firmware. |
08-18-2018, 03:24 PM | #110 | |
40
Rep 65
